kpaul Posted May 18, 2016 Report Posted May 18, 2016 My plane is going to have to sit for the next 3 1/2 months. It is be hangared. Should I disconnect the battery, get a battery maintainer or just let it sit? Quote
gsengle Posted May 18, 2016 Report Posted May 18, 2016 Anyone like your CFI you can get to fly it while you're away? Sent from my iPhone using Tapatalk Quote
kpaul Posted May 18, 2016 Author Report Posted May 18, 2016 14 minutes ago, gsengle said: Anyone like your CFI you can get to fly it while you're away? Sent from my iPhone using Tapatalk I though about trying to find someone, however the one that I did my transition training with is located quite a distance away. I don't want to make it inconvenient for anyone. Quote
gsengle Posted May 18, 2016 Report Posted May 18, 2016 It's not inconvenient if you're paying You'd have to cover flying over to your airplane or driving over... Just a thought Sent from my iPhone using Tapatalk Quote
kpaul Posted May 18, 2016 Author Report Posted May 18, 2016 Yeah, he would not even let me pay him for my transition training. Quote
gsengle Posted May 18, 2016 Report Posted May 18, 2016 Well lucky you! Nice guy. Luckily my CFI is right at my field... I'm sure others will advise on what to do with the engine... Sent from my iPhone using Tapatalk Quote
LANCECASPER Posted May 18, 2016 Report Posted May 18, 2016 1 hour ago, kpaul said: My plane is going to have to sit for the next 3 1/2 months. It is be hangared. Should I disconnect the battery, get a battery maintainer or just let it sit? A batteryminder is always a good idea whether its going to be sitting awhile or not. It keeps some activity going in the battery which extends the life. Quote
kpaul Posted May 18, 2016 Author Report Posted May 18, 2016 Just now, LANCECASPER said: A batteryminder is always a good idea whether its going to be sitting awhile or not. It keeps some activity going in the battery which extends the life. I have the Gill G-35. I was looking on AS at this charger https://www.aircraftspruce.com/catalog/elpages/vdc12248aas5.php It specifically mentions Concord but not Gill. Quote
Bob_Belville Posted May 18, 2016 Report Posted May 18, 2016 6 minutes ago, kpaul said: I have the Gill G-35. I was looking on AS at this charger https://www.aircraftspruce.com/catalog/elpages/vdc12248aas5.php It specifically mentions Concord but not Gill. I don't use a battery minder but from previous threads I understand that there are differences so as you're doing you should confirm match before choosing. I suspect someone here will comment with what you need for your G-35. Quote
bonal Posted May 18, 2016 Report Posted May 18, 2016 I would at least make sure it gets a fresh oil change prior to sitting don't forget the cam guard 1 Quote
LANCECASPER Posted May 18, 2016 Report Posted May 18, 2016 Even though Spruce has the wrong picture, the one you need for the Gill has the "-S2" suffix at the end of the part number, https://www.aircraftspruce.com/catalog/elpages/batteryminder11-14347.php Quote
N601RX Posted May 18, 2016 Report Posted May 18, 2016 I would skip the battery minder and put that money toward a new Concord battery when the Gill dies. The maintainer is 2/3's the price of a new battery. I would be more concerned about the engine and would either find someone to fly it a few times or do a fresh oil change/dehumidifier just before you leave. Also look at the dehumidifier plugs for the cylinders. I would not want to just let it set for that long without doing anything. 3 Quote
MB65E Posted May 18, 2016 Report Posted May 18, 2016 Hi Paul, Dump the oil, put fresh stuff in. You could remove the battery. Maybe have your tech monitor it at his shop on a charger etc. Or just treat yourself to a new sealed concord when you get back. I would not leave it plugged in while you are gone. Take care, -Matt 1 Quote
markejackson02 Posted May 18, 2016 Report Posted May 18, 2016 I would remove the battery from the plane, put it on an acid proof mat on the hangar floor and hook the Gill specific Battery Minder up to it. It's what I do when my plane will sit for two weeks. I would change the oil before letting it sit as well. Quote
thomas1142 Posted May 18, 2016 Report Posted May 18, 2016 Who did you do your transition training with? 1 Quote
DXB Posted May 18, 2016 Report Posted May 18, 2016 2 hours ago, kpaul said: I have the Gill G-35. I was looking on AS at this charger https://www.aircraftspruce.com/catalog/elpages/vdc12248aas5.php It specifically mentions Concord but not Gill. They make many Battery Minder flavors that are battery specific. I have a G35 also but don't have my battery minder model number for it handy at the moment. Just call their customer service- I've dealt with them a couple of times- probably the easiest way to get the right model number. BTW before I bought mine, they did tell me that if I upgrade to a sealed Concorde later, I can send the Battery Minder to them to have it reset. They also said that mine would still benefit a Concorde battery if I didn't do this, just leave it slightly below the maximal charge, but the one for the Concorde could overcharge and damage the wet Gill. Edit: i found the part number: #12248-AA-S2. You might want to double check though. Quote
kpaul Posted May 18, 2016 Author Report Posted May 18, 2016 8 hours ago, thomas1142 said: Who did you do your transition training with? Chuck Ebbecke. He is a Master CFII. His M20J is based out of Bonifay, FL (1J0). He was a MAPA Safety Foundation Instructor and currently a FAASTeam lead for this area. 3 Quote
jetdriven Posted May 19, 2016 Report Posted May 19, 2016 A Blackmax dehumidifier can really help, no moisture no corrosion. The dessicant type units need to be recharged at intervals, but the Black max is an actual electronic dehumidifier. Quote
jclemens Posted May 19, 2016 Report Posted May 19, 2016 14 weeks in a hangar is not a long time. I would just park it. Unhooking the battery wouldn't hurt, in case there is something on the hot buss. 6 Quote
Mooneymite Posted May 19, 2016 Report Posted May 19, 2016 10 hours ago, jclemens said: 14 weeks in a hangar is not a long time. I would just park it. Unhooking the battery wouldn't hurt, in case there is something on the hot buss. Yes....! 3.5 months isn't that big a deal for a heathy battery. Might put an overnight trickle charge on it before you fly when you get back. 1 Quote
Godfather Posted May 19, 2016 Report Posted May 19, 2016 I would spend the money for a good charger and not worry about a few months. The only time I take the batteries out is at annual...no reason imo to waste time doing it any other time. However, I'm slow and it takes me 20 mins to get them out. Quote
larryb Posted May 19, 2016 Report Posted May 19, 2016 Batteries and chargers are cheap. The real risk to your wallet is engine corrosion. I've been measuring humidity inside my engine, and it is certainly present. I would change the oil and fly it one time to get that fresh oil well distributed. And I would have a method to actively keep the humidity down. Larry Quote
Raptor05121 Posted May 19, 2016 Report Posted May 19, 2016 3 months isnt a long time. Mine has been sitting for 6 months just waiting on an annual. Camguard and fresh oil wouldn't hurt, and just wait for the Gill to die and get a Concorde. 1 Quote
