Heybluez Posted December 31, 2016 Report Share Posted December 31, 2016 On 12/21/2016 at 5:08 PM, Ratherbflying said: Has anyone been able to replace the internal fuse on ones of these things yet? On my unit the fuse is soldered in, and after pushing my luck by using a second outlet to configure a heater in the cabin, it is now quite blown. Guess I should have redone the math. I've replaced the internal fuse but mine was not soldered in. It has a clip. Can you send me a pic of the internal of your switch? yes... don't put too much on that switch.. says 10A but seems to be very sensitive on the load it gets. Quote Link to comment Share on other sites More sharing options...
Ratherbflying Posted January 1, 2017 Report Share Posted January 1, 2017 Here is the pic. I circled where the fuse goes (it's already been removed.) I figured out which fuse to put in, but didn't get over to pick it up before the holiday. I also need some desoldering braid to clean up the holes before I solder the new one in. Thanks for the help. 1 Quote Link to comment Share on other sites More sharing options...
Heybluez Posted January 1, 2017 Report Share Posted January 1, 2017 6 hours ago, Ratherbflying said: Here is the pic. I circled where the fuse goes (it's already been removed.) I figured out which fuse to put in, but didn't get over to pick it up before the holiday. I also need some desoldering braid to clean up the holes before I solder the new one in. Thanks for the help. Interesting. Mine has a clip. See pics. The fuse is a 20mm 10A fuse. You can get them on Amazon Prime pretty cheap. 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 1, 2017 Report Share Posted January 1, 2017 Nice photos gents! Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
Marauder Posted January 1, 2017 Report Share Posted January 1, 2017 Thanks for posting the internals. The document that came with it showed a 2200W capacity. I'm running my Reiff rated at 600W and a small ceramic heater putting out 800W at the same time. No issues thus far. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Marauder Posted January 1, 2017 Report Share Posted January 1, 2017 And BTW, apparently the Chinese Call Center Lady has retired. Calling in now has this booming woman voice.Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ratherbflying Posted January 2, 2017 Report Share Posted January 2, 2017 16 hours ago, Heybluez said: Interesting. Mine has a clip. See pics. The fuse is a 20mm 10A fuse. You can get them on Amazon Prime pretty cheap. Wow, I am jealous. Mine has a wimpy 10mm fuse, and it's soldered on to the board, not clipped. 12 hours ago, Marauder said: Thanks for posting the internals. The document that came with it showed a 2200W capacity. I'm running my Reiff rated at 600W and a small ceramic heater putting out 800W at the same time. No issues thus far. Sent from my iPad using Tapatalk That is pretty much the exact load I had on it when the fuse blew. I had just added the ceramic block heater this year. It worked for the duration of my test when I set things up, but the first time I used it for real (turning the ceramic heater on 30 minutes before I got to the airport) I arrived to find the fuse blown. I considered trying to modify the fuse to make it a bit more robust, but I'm going to add one of these to the setup instead: https://www.amazon.com/gp/product/B00WV7GMA2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 Quote Link to comment Share on other sites More sharing options...
Marauder Posted January 2, 2017 Report Share Posted January 2, 2017 That is pretty much the exact load I had on it when the fuse blew. I had just added the ceramic block heater this year. It worked for the duration of my test when I set things up, but the first time I used it for real (turning the ceramic heater on 30 minutes before I got to the airport) I arrived to find the fuse blown. I considered trying to modify the fuse to make it a bit more robust, but I'm going to add one of these to the setup instead:https://www.amazon.com/gp/product/B00WV7GMA2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 I can't tell from the pictures or the Amazon site how it will connect to the Andoer. Will you run a power cord to the relay to switch it on? Be interested in a PIREP once you have it installed.Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ratherbflying Posted January 3, 2017 Report Share Posted January 3, 2017 In the picture, on the right hand side, there is a green-ish 2 wire connector. This is the signal voltage and it can accept either AC or DC. So my plan is to take an old cell phone charger, cut the connector off, strip the wires, and input to the relay. Then I can plug the block into the Andoer. Sorry for being so slow to get this done, but I still have guests coming and going for the holidays. Here is how I plan to wire it: 1. Wall outlet to the Andoer. 2. Andoer Socket 1 - to the engine heater. 3. Andoer Socket 2 - modified cell phone charger to the relay. 4. Wall outlet to the Relay. 5. Ceramic block heater plugged in to the relay. 1 Quote Link to comment Share on other sites More sharing options...
peevee Posted January 3, 2017 Report Share Posted January 3, 2017 I didn't care to run that much current through mine and also use an external relay, it works well. I have the Chinese made one similar to the switch box (by similar I mean exactly the same) Quote Link to comment Share on other sites More sharing options...
Ratherbflying Posted January 3, 2017 Report Share Posted January 3, 2017 I have been looking and looking to find somewhere to buy the optional temperature sensor probe and finally found it this afternoon: http://www.ebay.com/itm/Free-shipping-Accessories-temperature-sensor-for-Smart-Socket-Switch-SC3-GSMT/272468695702?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D888007%26algo%3DDISC.MBE%26ao%3D1%26asc%3D38530%26meid%3Da679215657b845f6a624a795f7de32dc%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D222047670491 Quote Link to comment Share on other sites More sharing options...
Marauder Posted January 3, 2017 Report Share Posted January 3, 2017 1 hour ago, Ratherbflying said: I have been looking and looking to find somewhere to buy the optional temperature sensor probe and finally found it this afternoon: http://www.ebay.com/itm/Free-shipping-Accessories-temperature-sensor-for-Smart-Socket-Switch-SC3-GSMT/272468695702?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D888007%26algo%3DDISC.MBE%26ao%3D1%26asc%3D38530%26meid%3Da679215657b845f6a624a795f7de32dc%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D222047670491 I read the description of the usage in the documentation with the switch. Looks like you can command it to turn on if the temp is below or above a certain temp. Once you play around with this, let me know if it can be used in conjunction with the timing feature. I would love to be able to tell it to turn on every Saturday and Sunday if the temp is below 40 degrees. Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 4, 2017 Report Share Posted January 4, 2017 One of the photos above looks like it has a standard plug for a TC probe. For two blades, one is wider than the other... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
PaulM Posted January 4, 2017 Report Share Posted January 4, 2017 That does look like the correct temperature probe for that unit, but it isn't a thermocouple.. It will be a RTD and I see 3 wires in the pictures. My AT&T sim went offline at 12/31/2016..(and reception had been really spotty the last 6 months as they took towers off line) So I have a t-mobile sim on order. 1 Quote Link to comment Share on other sites More sharing options...
Marauder Posted January 4, 2017 Report Share Posted January 4, 2017 I ordered one of these temp sensors. Got a reply that it was shipped directly from mainland China. Will be here at some point.Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ratherbflying Posted January 4, 2017 Report Share Posted January 4, 2017 OK, fuse is fixed. Relay is installed. Works like a champ. Using an old cell phone charger to supply the control signal. Whacked the old connector off, stripped the wires, and attached the relay connector. This relay box is a very elegant design. It is rated for 1440 watts, which is just a titch less than the 1500 watt ceramic heater on high heat, but the relay includes an On/Off breaker switch. If you do inadvertently pull too much, should be able to just manually reset the circuit. And here it is deployed in the hangar. It will be nice to hop in to a warm cabin and not have the gyros screech from the cold when I flip the master on. 1 Quote Link to comment Share on other sites More sharing options...
Marauder Posted January 4, 2017 Report Share Posted January 4, 2017 OK, fuse is fixed. Relay is installed. Works like a champ. Using an old cell phone charger to supply the control signal. Whacked the old connector off, stripped the wires, and attached the relay connector. This relay box is a very elegant design. It is rated for 1440 watts, which is just a titch less than the 1500 watt ceramic heater on high heat, but the relay includes an On/Off breaker switch. If you do inadvertently pull too much, should be able to just manually reset the circuit. And here it is deployed in the hangar. It will be nice to hop in to a warm cabin and not have the gyros screech from the cold when I flip the master on. Thanks for posting this write-up. My ceramic heater can pull 1500 W, so I will need to check it on with my watt gizmo to see if the 1440 W isn't an issue.When I get that temp probe, I will provide an update on the functionality.Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ratherbflying Posted January 4, 2017 Report Share Posted January 4, 2017 33 minutes ago, Marauder said: Thanks for posting this write-up. My ceramic heater can pull 1500 W, so I will need to check it on with my watt gizmo to see if the 1440 W isn't an issue. Does your heater have a Low or Medium setting? I ran mine on Low for a good twenty minutes and the relay handled it well. Quote Link to comment Share on other sites More sharing options...
Marauder Posted January 4, 2017 Report Share Posted January 4, 2017 Does your heater have a Low or Medium setting? I ran mine on Low for a good twenty minutes and the relay handled it well. Yeah, I have an 800 and 1500 watt setting. Been running it on the 800 W setting but if I can squeeze out 1500 W, it would warm things up a bit quicker. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
PaulM Posted January 6, 2017 Report Share Posted January 6, 2017 The t-mobile sim arrived, and worked without a problem (well, I had to call them manually to get the new phone# since they assumed you would be putting it in a phone and could just dial #NUM#. ) So, we are back online until 2020. Quote Link to comment Share on other sites More sharing options...
Marauder Posted January 6, 2017 Report Share Posted January 6, 2017 The t-mobile sim arrived, and worked without a problem (well, I had to call them manually to get the new phone# since they assumed you would be putting it in a phone and could just dial #NUM#. ) So, we are back online until 2020. That is my pet peeve with t-mobile as well. In addition, you can't set up an account in their website to put funds in" it requires you to text yourself an access code to set up the account. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
PaulM Posted January 6, 2017 Report Share Posted January 6, 2017 16 minutes ago, Marauder said: That is my pet peeve with t-mobile as well. In addition, you can't set up an account in their website to put funds in" it requires you to text yourself an access code to set up the account. Yes, I just ran into that... I think I'll have to find an old 2G full size sim phone... (or go to the store) my only one on hand is a original iphone locked to AT&T. I passed on my original omnipoint-->Tmobile GSM phones in 2001. Tmobile said they were specifically targeting Iot services since AT&T started the shutdown.. but obviously aren't really there for support. Quote Link to comment Share on other sites More sharing options...
Marauder Posted January 7, 2017 Report Share Posted January 7, 2017 Does your heater have a Low or Medium setting? I ran mine on Low for a good twenty minutes and the relay handled it well. Well guess who just blew that stupid soldered in fuse? Quote Link to comment Share on other sites More sharing options...
Marauder Posted January 7, 2017 Report Share Posted January 7, 2017 Here is the pic. I circled where the fuse goes (it's already been removed.) I figured out which fuse to put in, but didn't get over to pick it up before the holiday. I also need some desoldering braid to clean up the holes before I solder the new one in. Thanks for the help. Which fuse holder did you buy? I am going to see if any of the local hardware stores have fuse holders. I'm not sure Radio Shack is in business any longer. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
larryb Posted January 7, 2017 Report Share Posted January 7, 2017 Fuses aside, none of that hardware looks capable of 15 amps. Wires are too small, circuit board traces too small, etc. that fuse holder failed because a small resistance plus high current made it get too hot. Quote Link to comment Share on other sites More sharing options...
