Good condition cable for the "Power Boost" (from the power boost nose door to sliding lever on console) for my 73E. My cable is fraying and needs replaced.
I have a 1963 M20C and i am looking for the engine baffles, a good carburetor air intake duct, a nose gear truss, a nose gear tire (500x5 6 Ply). I hope you can help. Thanks
FrancisG
Francis.
I have the intake boot in excellent condition, the truss, and a set of baffling. Does your oils cooler lines route up over the engine and down to the oil cooler or behind the engine and down? Brent
Brent
I will have to check on the oil cooler routing, but i would like to take what you have, do you have fresh nose gear rubber pucks, i am also looking for front tire. Please PM or call / text at 415-279-0609 Thanks
Francis
I'm looking for an exhaust pipe that's in primo condition.  I have a 1967 F.
I have an extra exhaust pipe from my 67 F.  I will get it out and post a picture next time I'm at the hanger.
  • 2 weeks later...
  • 2 weeks later...
  • 4 weeks later...
I need a steel prop oil line for Lycoming A1A Mooney M20A.  I have a friend with a M20B and it uses the same line.  Straight fitting out of governor than 90 deg forward to run along top edge of right side oil sump.
JR
jrflyboyVP2@yahoo.com
512-940-8038
