Solution is popularly referred to as "the dog house" or "aplenum".   Easy to maintain and functions with CHT's never above 350 WOT in climb, and that's in Texas.  Nothing chaffing the upper cowling, either.
Not so great for routine maintenance, getting to plugs, etc,
51 minutes ago, Bob_Belville said:
Bring it to AGL! :rolleyes: Maybe you and Marauder can work out your schedules and I'll take you home. We'll put Chris in the back of my E.
Sounds like a plan, your going to S-F_N.?, I'm trying to get off
My expectations of my local accountant just went up! :)
Dan, I didn't know you had that skill!  Nicely done.
Edited by carusoam
as a temporary fix I have been told that cutting the head off a large cable tie and slipping the nylon tie strip between the metal and baffle material will definitely keep the baffle seal from folding back. :)
Edited by Cruiser
fixed terminology
49 minutes ago, Cruiser said:
as a temporary fix I have been told that cutting the head off a large cable tie and slipping the nylon tie strip between the metal and baffle material will definitely keep the baffle from folding back. :)
Non-ambiguous Terminology: the metal is the "baffle", the "rubber" is the "baffle seal". AFAIK.
