I am needing to replace a missing O2 Nut and flip style cover on a K Model.  Has anyone had any luck locating replacements or any idea where I can find a replacement?  Thanks
It is part of an AVOX (Scott) Zodiac 23599-22 outlet assembly.
I cannot find the cover listed separately anywhere.
You might try a junk yard. That part is specified for both Mooney and AeroCommander 112 and 114
It looks like you could just unscrew the cover.
Taking the cover off is easy. The "nut" is built to take a special two prong tool to install and remove, but an awl or other such tool will work. Or if you have a snap ring tool.
