I know there were other threads on wheel chocks but I am just about ready to buy these and wanted to see if anyone has experience with them. http://www.skygeek.com/degroff-5904-yellow-wheel-chocks.html
They are lightweight and I like the cord. It looks like it will snug around the wheels and won't go anywhere. I want to know if they will work on all types of surfaces including smooth hangar concrete.
I have them and use them whenever we land at a different airport and they work well. I keep them in the baggage compartment. I use wood chocks in the hangar.
+1
I went to my nearest glass & aluminum outlet, that manufacture windows and shower doors, and asked them to cut me two 6" lengths of 2" aluminum angle. They used off cuts and gave it to me for free!
I have a set of aluminum chocks and they work fine.  Since the hangar is fairly flat, it shouldn't be an issue on the smooth concrete.
I have the same ones and they work great.  Stay away from Skygeek for your own sanity!!
I once had a pair of these and I put them in the garage to prevent my wife from pulling her car too far forward. She drove right over them and flattened them out. Wrong tool for the job. Doh!
I know there were other threads on wheel chocks but......
Won't work on ice, but hanger floor is OK depending on how powerful your tug is. As others have advised, even CB's avoid the supplier you're shopping at.
Last time (several months ago) I tied to order something they took forever and I canceled the order.
Have used very similar ones that I got from Aircraft Spruce 10 years ago.  Keep them stored behind the rear seat with one side down so is flat on the baggage floor.  Would not use any other  kind.
Got some nice molded plastic ones from Spruce that are light and strong, in the hangar i just split the hand tow bar in half put the 2 pieces down front and back of the nose wheel its right there when I am ready to pull out.
I participated in the Kachina Doll Air Rally in 1993. The organizers made custom chocks for all the entrants. Two pieces of angle aluminum held together with a section of aircraft cable that was very professionally swagged. They were painted blue with my tail number stenciled on them. They are still in the hat rack of the plane and are in great shape, although they now have the wrong tail number on them.
Much better then a T-Shirt!
