Parts manual indicates 67F MAY use...
Transmitter Assembly, fuel quantity.
610161 LH
610160 RH
These are F only. C,D, and E use a different part number...
I am not a qualified source, so check your numbers carefully.
Hope that helps...,
  • 8 years later...
On 5/9/2022 at 4:55 PM, ukrsindicat@yahoo.com said:
The arm and float are different.  A while back, I bought one just to see.   Their resistance characteristics are very similar.
Some of them (aftermarket senders) have a compression bolt that allows for for removal of the arm and float. But I decided to go with CIES since I'm installing JPI 900. I just wish there was somesort of the discount for CIES. $1700 for four senders is a tough pill.
On 4/4/2014 at 5:46 PM, orionflt said:
I have 4 for a 62' C but I believe they changed styles around 65
Would you be interested in selling two?  I have a ‘62 also and need to get mine rebuilt. I’ve talked to CIES and theirs don’t work with original factory multi gage. If I had two to rebuild I could swap during an annual and shorten the downtime.
I've got two old fuel senders that I bought a while back.  Just in the past month or so the R.H. sender in our C has decided to get jumpy.  I see in the parts manual that the R.H. is P/N 5641991.  These senders don't have part numbers on them that I can discern.  Which one is the R.H. sender?   I'd guess that the bent arm with the float on it points aft?   I could send one of these in to Air Parts of Lockhaven for an o.h.  Thx.
I have four senders that I removed from a M20J. The right two work perfectly. The left two need rebuilding due to intermittent resistance readings verified after removal. I'd sell the right two for $50 each ($100 total + shipping) and throw in the left two for free since they need work.
IMG_0233.JPG.004ce76548725bdd0f5a7081773ecfb9.JPGIMG_4441.JPG.69fd9b5d5c702808dd58ad745e0212e4.JPGIMG_4442.JPG.62029ef93df54086f955195dea7fb7e8.JPGIMG_4443.JPG.345e81a2fd0d98d9817f13202533570b.JPGIMG_4444.JPG.0a8e8884081097458043462444630f5b.JPG
Just order new ones from CIES and be done with it. You’ve got the plane pulled apart, not is the easiest time to upgrade them.
I just did...$1800 for four senders... My sphincter still hurts...
