Some people think that their individual POH/Owner's Manual is how all airplanes should be flown.
Seeing is believing, right? Even in Missouri? Check this out, ye unbelievers! I prefer "As desired" myself.
My 1969 M20F POH has the same line, in some circumstances I choose "takeoff flaps" but most times I choose "as desired"
Where did you find a 100 pound girlfriend :D
Ha ha I went out specifically searching for the woman of my dreams that could allow for my m20J to be a good 4 person airplane. :). Gosh I hope she doesn't come on here I'll be toast!
Did you also search for an 100 pound mother-in-law to match?
Is it still a 4 person airplane if the gf decides she wants her mother to come along?
Oh gosh if the mother in law thinks she's going to come then I'd have to refer to the FAA oxygen requirements for pass above 14k. It's only necessary to offer o2 to pass, not required so I'd technically be right if I made the offering at the volume of a whisper? And how high do I need to fly to put her in sleepy land?
You do know this is a public forum, right? google aaronk mother in law in a few days after the crawlers have updated...  :wub:
With that bench seat in the back you might seat three. Who has the record for most 100 lb GF's in one Mooney. Extra credit for vintage.
At the same time? That would be dangerous.
My wife would be very upset if I had ANY gf's at all . . .
vintage? Of the girlfriend? You could probably get one or two more 80 year olds in there than 20 year olds, but... um....
  • 2 weeks later...
  • 2 weeks later...
In the past I usually didn't use flaps on takeoff. That is the way I was checked out. But I found that the break from the runway is much cleaner when using flaps and they are 100% necessary when taking off hot and heavy unless you have a lot of runway to burn off. Landing I always use full flaps (not really huge anyways) and trim the nose very carefully. I usually fly alone and find myself quite nose heavy so an approach at 85 mph and full nose up trim results in frequent squeakers :)
I've been away 2 weeks and this thread is still going on? I don't understand what there is to discuss!? You're supposed to and it's better to use flaps on every takeoff.
Welcome back! Things are just like you left them!! Except maybe your parrots. Any new ones, freshly imported from the homeland? If they're in the cockpit and flapping on takeoff, does that help?
Lord! Why am I reading this thread?
Because you don't want to miss the post that would put this tread in the ditch again (assuming it was ever out of it)!
Or maybe it used full flaps and lost control wheelbarrowing down the runway?
(Sorry, I can't help myself!)
You took the bait!
Page 13 anyone??
AUGH!
I was hoping to actually find something worth reading.
BTW: Just to kick things up a bit. No flap takeoffs are my normal configuration. Use 'em if you need 'em for improved takeoff performance, but nominally loaded on typical runways of 4k or longer I leave the flaps up.
