dkkim73 Posted January 2 Report Posted January 2 Hi All, Since my plane has LEMO plugs, and I need to call for clearance at an airport I frequent, I bought a David Clark One-XP headset. Great unit. Only problem is that the control box is constantly in the way. The LEMO plug is on the left, front of the left side arm rest. So the cable and box keep snagging on me, the seat, the yoke, etc. It comes with a little clip holder, but there are no features over there to attach. I am thinking of mounting a little loop (or a full DC-specific box clip) to the side panel just under the storm window. And then, since the cable snags the yoke at times, I was going to put some 3M sticky-backed clips nearby to secure the cable run to the LEMO socket. Any: existing experiences in solving this? (clever ideas) tips/tricks on mounting something to the side panel? The finish is some odd pseudo-pleather (2009 Acclaim)... Very functional but things don't stick easily to it. So I am thinking to sink a tiny wide-pitch screw. But firing screws in blindly is asking to be, well, screwed. Maybe I can fish a thin flat hook adjacent to the window to hold the box. Thoughts appreciated! Brought to you today from The Department of First World Problems. David Quote
N201MKTurbo Posted January 2 Report Posted January 2 You could remove the window trim then attach a strap to the airframe or the top of the sidewall so the attachment is hidden under the window trim. Instead of a strap, you could make a sheet metal clip that clips to the top of the sidewall material and hangs down with whatever clip you need. Quote
Pinecone Posted January 2 Report Posted January 2 I bought a stick on clip from Amazon. I stuck it to the side panel above my knee. https://www.amazon.com/gp/product/B081PKGJS5/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 1 Quote
CCAS Posted January 9 Report Posted January 9 On 1/2/2025 at 3:13 PM, dkkim73 said: Thoughts appreciated! I route my headset cord/power box (Bose) over my handset mic and mic bracket on the pillar; stays very much out of the way. But not sure you have that option without seeing your layout. P.S. I also have a DC One headset and find the cords/power box to be a tangled mess so I use that set as my backup. Quote
GeeBee Posted January 9 Report Posted January 9 I use this: https://www.sportys.com/anr-control-holder.html Sporty's does not seem to have the model for Bose, but I see them on other sites including Etsy. You can attach it with velcro and that works but when my airplane interior was re-worked at AeroComfort, Hector drilled the holders then made a backing plate and attached them to the sidewall with machine screws. and riv-nuts just below the limitation placard. It is the bomb. Quote
LANCECASPER Posted January 9 Report Posted January 9 Sellers on Ebay has them for Bose and a few others: https://www.ebay.com/sch/i.html?item=294247818235&rt=nc&_trksid=p4429486.m3561.l170197&_ssn=shachar2208197171 https://www.ebay.com/sch/i.html?_ssn=bioluminous&store_name=bioluminous&_oac=1&_trksid=p4429486.m3561.l170197 Quote
dkkim73 Posted January 11 Author Report Posted January 11 Here's some photos from my temporary solution. I like the idea of a dedicated holder mounted more securely (as above, appreciate the responses!): 1 Quote
PT20J Posted January 11 Report Posted January 11 I just stuff mine in the side pocket beneath the wemac on the pilot's side. 1 Quote
Lax291 Posted January 11 Report Posted January 11 The 3M dual lock was a great solution for me. It took a small piece on the top and bottom of my ANR controller to secure it to the side panel. Have had 0 issues with it falling off and when I need to change batteries it pulls off easily without damaging the plastic panel. 2 Quote
Pinecone Posted January 11 Report Posted January 11 18 hours ago, PT20J said: I just stuff mine in the side pocket beneath the wemac on the pilot's side. What side pocket?? Quote
Nukemzzz Posted January 12 Report Posted January 12 (edited) If I had the dimensions I could 3D print a custom holder for it. Edited January 12 by Nukemzzz Quote
dkkim73 Posted January 12 Author Report Posted January 12 20 hours ago, Lax291 said: The 3M dual lock was a great solution for me. It took a small piece on the top and bottom of my ANR controller to secure it to the side panel. Have had 0 issues with it falling off and when I need to change batteries it pulls off easily without damaging the plastic panel. Maybe I should give it a go. I've sometimes felt that that weird surface material doesn't bond well... OTOH 3M has a wicked assortment of glue types. 2 Quote
Pinecone Posted January 14 Report Posted January 14 On 1/11/2025 at 7:33 PM, Nukemzzz said: If I had the dimensions I could 3D print a custom holder for it. I think someone has posted a print file. But the one I got from Sporty's was 3D printed. Quote
Jetpilot86 Posted February 23 Report Posted February 23 I took a small Velcro loop and mounted it to a trim screw on the sidewall then clip the box to the loop. .001 AMU’s. Pics if I ever get my M back from her spa quarter. Quote
dkkim73 Posted March 20 Author Report Posted March 20 On 2/23/2025 at 4:11 PM, Jetpilot86 said: ... Pics if I ever get my M back from her spa quarter. Spa quarter. Tell me about it! Just got my plane back out of annual Quote
midlifeflyer Posted March 21 Report Posted March 21 My needs are portable so I bought a pack of a half dozen suction hooks at Dollar Tree. I attach them in the side window and hang the control box there. Quote
Jetpilot86 Posted March 21 Report Posted March 21 19 hours ago, dkkim73 said: Spa quarter. Tell me about it! Just got my plane back out of annual I lied. Spa 3rd. 4 months today. Next week (fingers crossed) Quote
Matthew P Posted April 7 Report Posted April 7 I have the same issue, what I am currently doing is using 5' cable extension that runs down along the floor behind the seat. When the aircraft comes out of Annual, I'm going to solder into the panel jacks and run the wiring behind the panels and put an additional passenger headset jack just behind the seat marked for pilot of course, that way I can use either position..atleast that's the plan for now. Quote
dkkim73 Posted April 7 Author Report Posted April 7 23 minutes ago, Matthew P said: I have the same issue, what I am currently doing is using 5' cable extension that runs down along the floor behind the seat. When the aircraft comes out of Annual, I'm going to solder into the panel jacks and run the wiring behind the panels and put an additional passenger headset jack just behind the seat marked for pilot of course, that way I can use either position..atleast that's the plan for now. Clever! Closer to the head. May I ask where you're mounting them? Side, center, floor etc. Quote
Matthew P Posted April 7 Report Posted April 7 (edited) 6 minutes ago, dkkim73 said: Clever! Closer to the head. May I ask where you're mounting them? Side, center, floor etc. Haven't decided yet, won't be on the floor, the plane is in Annual so when it comes out this will be one of my first projects while I am putting in the shoulder harnesses...will send pic when done.. may use a different mount as well.. Edited April 7 by Matthew P Quote
