amekler Posted December 7, 2024 Report Posted December 7, 2024 My display is going on my Shadin mini flow-L Does anyone have one they removed? Alan N9127M 2000 Bravo Quote
Pinecone Posted December 7, 2024 Report Posted December 7, 2024 I have whatever was removed from my 252 Quote
anthonydesmet Posted December 7, 2024 Report Posted December 7, 2024 I still have my display but not sure if it’s what you’re looking for. I’ll send a photo. Quote
alextstone Posted December 7, 2024 Report Posted December 7, 2024 1 hour ago, amekler said: My display is going on my Shadin mini flow-L Does anyone have one they removed? Alan N9127M 2000 Bravo I have one our of my 1995 Bravo... Alex Quote
amekler Posted December 7, 2024 Author Report Posted December 7, 2024 I’m interested i can barely read mine you can email me at nhflydoc@gmail.com Alan Quote
Jetpilot86 Posted December 8, 2024 Report Posted December 8, 2024 I’ll have one available by the end of January. 95 Bravo Quote
donkaye Posted December 8, 2024 Report Posted December 8, 2024 As an option, you could send yours back to Shadin to have the display replace, if they are still doing them. I had my display replaced by them a number of years ago. Quote
Pinecone Posted December 9, 2024 Report Posted December 9, 2024 I will post a picture when I get home. On a cruise, so hard to get to my hangar now. Quote
LANCECASPER Posted December 9, 2024 Report Posted December 9, 2024 1 hour ago, Pinecone said: I will post a picture when I get home. On a cruise, so hard to get to my hangar now. I think your 252 had a Hoskins FT-101, not a Shadin. Quote
PT20J Posted December 9, 2024 Report Posted December 9, 2024 On 12/7/2024 at 4:06 AM, amekler said: My display is going on my Shadin mini flow-L Does anyone have one they removed? Alan N9127M 2000 Bravo Skyman Avionics has mine for sale. 541-604-9573. info@skymanavionics.com. https://www.skymanavionics.com/product-page/shadin-fuel-flow-indicator-912041t Previous owner had it repaired by Shadin in 2010 and I have the 8130. It was working fine when removed. Quote
musicman Posted December 10, 2024 Report Posted December 10, 2024 I removed one from my J last week. It was working fine when removed. Quote
donkaye Posted December 10, 2024 Report Posted December 10, 2024 I don't understand why someone would want to remove the Miniflo-L from their panel even when upgrading it. If there is one item where multiplicity of function is useful it is fuel quantity and fuel computations. Even though I installed the MVP-50 in my upgrade, I kept the Miniflo-L due to its usefulness. When my display goes out again, the unit is going in for repair, not removal. 1 1 Quote
alexz Posted December 10, 2024 Report Posted December 10, 2024 4 hours ago, donkaye said: I don't understand why someone would want to remove the Miniflo-L from their panel even when upgrading it. If there is one item where multiplicity of function is useful it is fuel quantity and fuel computations. Even though I installed the MVP-50 in my upgrade, I kept the Miniflo-L due to its usefulness. When my display goes out again, the unit is going in for repair, not removal. Probably because it’s the easiest sensor to live without. One will not loose orientation in space if fuel flow is gone. On top of that shadin fuel flow sensor was always gumming up for me, even replacement become sticky after about a year. Quote
Vance Harral Posted December 11, 2024 Report Posted December 11, 2024 On 12/7/2024 at 7:17 AM, amekler said: i can barely read mine @amekler there may not be anything really wrong with yours. The intensity of the display is controlled by a potentiometer. Over time, with vibration of the panel, dirt, etc., this potentiometer can lose slider contact, resulting in the display intensity going to full bright or full dim. Simply wiggling the potentiometer back and forth a bit can often re-establish contact and restore reasonable intensity. We have had exactly the same problem as you, and I was able to resolve in just a few minutes with a small screwdriver. Instructions from the installation/maintenance manual are shown below. Suggest you slide the box out of the panel, tweak the display potentiometer a little, and re-install. It can't hurt, and might help. Quote
amekler Posted December 11, 2024 Author Report Posted December 11, 2024 6 hours ago, Vance Harral said: @amekler there may not be anything really wrong with yours. The intensity of the display is controlled by a potentiometer. Over time, with vibration of the panel, dirt, etc., this potentiometer can lose slider contact, resulting in the display intensity going to full bright or full dim. Simply wiggling the potentiometer back and forth a bit can often re-establish contact and restore reasonable intensity. We have had exactly the same problem as you, and I was able to resolve in just a few minutes with a small screwdriver. Instructions from the installation/maintenance manual are shown below. Suggest you slide the box out of the panel, tweak the display potentiometer a little, and re-install. It can't hurt, and might help. interesting. if I shine a flashlight on the sensor the display goes full bright. when I turn the flashlight off it goes full dim. I'll try your suggestion. Alan Quote
