Zippy_Bird Posted April 19, 2024 Report Posted April 19, 2024 Hi All, Hope everyone is enjoying some good Spring flying! Seeking opinions today from folks that fly the Brittain AccuTrak and AccuFlight systems in their Mooneys. Specifically I am trying to understand if folks have one or both installed, and in the case of both, is one more useful than the other? My bird came with a basic Brittain wing leveler which I love and over this past year I have been wanting to enhance my basic system with more advanced features. I don't have piles of cash right now to buy a fancy new autopilot, so instead I have been collecting components piece-by-piece to install the Brittain Accutrak (B-11) & AccuFlight (B-12). The MS forums and resident expert K.W. have proven priceless in understanding these systems, and I am grateful to all who have shared knowledge. Currently I am at the point where I need to make my final install decisions and send components off to Porter-Straight for rebuild and yellow tag. My question to the forum is this... Should I install both systems (the AccuTrak AND the AccuFlight) or just one system (the AccuTrak OR the AccuFlight)? If just one, why? Always appreciate the diversity of thought and opinion on the forums, and often discover things I never considered. Thanks in advance to anyone who throws in a word! Sincerely, Zippy_Bird Quote
takair Posted April 19, 2024 Report Posted April 19, 2024 I have both and love it. The two together offer better performance than one alone, but any version is better than none. If you look at some of my flight tracks, you can see how well it can perform. It takes some initial patience, tweaking it, and it takes a little learning ton how to use it all together, but once you do, performance is on par with some of the more expensive systems. There are a few threads about this…or happy to discuss on via phone…. Quote
Hank Posted April 19, 2024 Report Posted April 19, 2024 I have both, too. AccuFlight follows the heading bug, great for straight-line flight. AccuTrak follows whatever I program into my WAAS GPS--straight lines, turns, instrument approaches, etc. But neither one does anything with the elevator, you still have to watch and manage your altitude. Quote
cliffy Posted April 20, 2024 Report Posted April 20, 2024 I had only the Accu-trak in my Mooney and didn't need anything else. It followed my course from the old GPS 155 TSO that I had. Didn't care about flying a heading as all I did was cross country point to pint straight line. I think 2 wires were pulled from the 155 TSO for left -right steering and all was good. Easy Peasy If I needed a heading for ATC or something just the wing leveler and turn knob sufficed My airplane flies straight. Lots less install if you just go Accu-trak I think I have 2 systems in boxes on the shelf -1 Accu-trak /Accuflight combo and one Accutrack only that I'm going to put up for sale here on MS soon. Both were working when removed. Quote
Echo Posted April 20, 2024 Report Posted April 20, 2024 i had both and only used Accu-Flite heading bug. Worked fantastic. You could compensate for wind drift with it. Being able to quickly dial in a heading from ATC, or to program a heading that kept you out of weather was a common requirement that the Accu-Flite performed well. Of course you could see the "magenta line" and set the bug to follow it. I fly out/into Class C airspace and being given headings is common for me so I prefer to the AccuTrak. Quote
0TreeLemur Posted April 20, 2024 Report Posted April 20, 2024 I fly 1000 mile cross-countries several times a year. At first did it all in my C by hand. Arrived at my destination too tired. Then like you I gathered the parts and installed an Accutrak II first in our C. It was a fantastic magenta line follower. But, after I finished my IR and started asking for diversions around buildups I started to covet the Accuflite. Installed that my nav problems were all solved. Life was so good, except for altitude hold. Next I pieced together the parts for the Brittain AH system, and with the help of some resident knowledge here, got it working. Ended up with a full two-axis autopilot, all done by tubing and rubber bands! Now I fly a J with a "modern" autopilot- the 1980's vintage Bendix-King KFC-150. Honestly, the Brittain wing leveler does a better job than the BK at keeping the wings level in turbulence because it is more responsive and smoother. The dynamics of the Brittain wing leveler are just unbeatable it seems. The altitude hold on the BK system is very aggressive at maintaining altitude within 20 ft. The Brittain altitude hold had more like a +/- 60 ft variance, and provided a much smoother ride. In mountain wave turbulence I just have to turn the BK altitude hold off or it will make my passengers (or me) puke. The Brittain altitude hold, while responsive, seems a better match for the flight dynamics of a small airplane. The Accutrak II would sometimes wander a bit. Seemed random, but more likely to happen after several hours of a long trip. The Accuflite of course depends on the rate of gyro precession on your DG- that would make long distance flights without the Accutrak a little zig-zaggy. If you can find all the parts, I'd recommend putting in both. You can use the Accuflite to help in maneuvering (e.g. holds) too if you need to look at an approach plate or weather data on your iPad while shooting an approach. It's all great for workload reduction. 1 Quote
Zippy_Bird Posted April 21, 2024 Author Report Posted April 21, 2024 Thank you all for the valuable insights. Installing both is the way to go. Decision made! Question for the AccuTrak (B-11) folks... What methods are you guys using to drive the AccuTrack NAV1 and NAV2 inputs and with what hardware? I currently have two old-school Bendix-King VOR/ILS/GS heads driven by KX-155s that should play nice with the AccuTrak NAV1 and NAV2 inputs. I am however looking to add IFR GPS navigation as soon as possible given budget constraints. May do it at the same time as this install if I can swing it. Based on comments above it sounds like most have GPS navigation paired with the AccuTrak, but how and with what? My understanding of the documentation suggests an analog output capable navigation/CDI head MUST BE INSTALLED to serve as an intermediary between a given navigation source and the AccuTrak controller for the purpose of generating the required volts/amps input signals for the AccuTrak. Upstream from the NAV/CDI head, one can have their avionics of choice, but the signal MUST pass through an analog output capable CDI... or so that is my understanding. In other terms, if one is rocking a modern WAAS GPS they also have a modern GPS/VOR/ILS/GS CDI (like a Midcontinent GI-106A) routing signal to the AccuTrak? Is this understanding of a modern GPS setup correct, or are there other methods? As always thanks so much for the comments. Getting excited for the install! Sincerely, Zippy_Bird Quote
takair Posted April 21, 2024 Report Posted April 21, 2024 I have my GNs-430 coupled to mine. Just uses the analogue left-right outputs which are switched by the GNS. I never bothered hooking up my number 2 nav and have never missed it. It might be of value when flying pure VORs or under failure of number 1….although then you still have heading… Quote
0TreeLemur Posted April 22, 2024 Report Posted April 22, 2024 The setup in my C involved a Mid-continent GI-106A connected to the GNS430W, and a BK KI-209 connected to the KX-155 nav/com. The analog outputs from those two indicators were connected to the Accutrak II as NAV1 and NAV2. I almost never used the VOR nav functions. I'd say you can get by with just the GI-106A connected to the Accutrak. Quote
Zippy_Bird Posted April 28, 2024 Author Report Posted April 28, 2024 Hi All, One last question before this thread slides into history... has anyone used a Garmin GI-275 to drive a Brittain AccuTrak? It seems to me that if this were possible, it could help bridge a gap when upgrading avionics, particularly if one plans to get a GFC500 eventually, but can't muster the funds to do it all in a single install. Thanks to everyone who added to the discussion! Z Quote
LANCECASPER Posted April 29, 2024 Report Posted April 29, 2024 15 hours ago, Zippy_Bird said: Hi All, One last question before this thread slides into history... has anyone used a Garmin GI-275 to drive a Brittain AccuTrak? It seems to me that if this were possible, it could help bridge a gap when upgrading avionics, particularly if one plans to get a GFC500 eventually, but can't muster the funds to do it all in a single install. Thanks to everyone who added to the discussion! Z It might drive it but it's not on the compatibility list: https://static.garmin.com/pumac/gi275_autopilot_compatibility_c.pdf Quote
Zippy_Bird Posted March 21 Author Report Posted March 21 (edited) Hi All, I received a PM with a follow-on question about using a GI-275 with the Brittain AccuTrack. Thought I'd update this old thread with my findings. I've learned a lot. Originally my thinking was a GI 275 could work like a “consolidated Instrument” that would output course deviation information for multiple navigation inputs like GPS, VOR, and Heading, and I could send that to an AccuTrack on one channel (e.g. Heading 1). I was chasing this because I wanted “Heading Mode” for ATC vectoring. In my mind I was thinking the GI-275 had two output pins like a KI-209 VOR head (one for positive voltage deviation Left, one positive voltage deviation Right) AND that the GI-275 internal software smarts would send all course deviation voltages out the same two pins for ALL MODES of operation, including Heading Mode. I thought I could run two wires (L+ R+) from two GI-275 pins into a single channel on my Accutrak and have it all. It sounded like a good theory anyway... When I talked about this with my local Avionics shop I was told the Heading Mode output from the GI-275 is a completely different animal in how it connects and sends data, than how GPS and VOR connect and send data. Apparently it was designed to be backward compatible with the raft of legacy autopilots. That information burst my bubble. Given this and other significant STC compliance questions, I did not pursue connecting a GI-275 to the AccuTrack. Which lead me back to the AccuTrack base camp... I have confirmed two AccuTrack conneciton methods are in use by members of MooneySpace: 1) Direct wire a GPS Head Unit (Garmin 300XL, 430W, 530W, etc) to a channel on the AccuTrack (e.g. Heading 1) 2) Direct wire a legacy VOR head (KI-209, GI-206, etc) to a channel on the AccuTrack (e.g. Heading 2) Each Channel having two wires (+Left, +Right) and each transmitting the correct current and voltage to the AccuTrack. If you obtain an install guide for your equipment, it is usually a quick search to find which output pins correspond to the (+Left +Right) for your output lines. I hope this saves someone from wasting time chasing a ghost! Thanks, Z Edited March 21 by Zippy_Bird Quote
DCarlton Posted March 21 Report Posted March 21 I have the system that follows the DG heading bug. Just had the Turn Coordinator repaired; getting ready to reinstall. I haven't done the homework at all but I've wondered if the following could be used to create an AV30 analog interface with the Brittain system if the AV30 is configured in the DG mode. https://uavionix.com/product/av-apa-pma/ Quote
takair Posted Saturday at 11:51 AM Report Posted Saturday at 11:51 AM 12 hours ago, DCarlton said: I have the system that follows the DG heading bug. Just had the Turn Coordinator repaired; getting ready to reinstall. I haven't done the homework at all but I've wondered if the following could be used to create an AV30 analog interface with the Brittain system if the AV30 is configured in the DG mode. https://uavionix.com/product/av-apa-pma/ That’s very interesting. That my just work. Would need to see the install manual or pin out to be sure. 1 Quote
Rmfriday Posted Saturday at 02:07 PM Report Posted Saturday at 02:07 PM I also was wondering if this would work? I can’t seam to find what the output from the Uavionics adapter is? would be a cool setup if it worked and also replaced the need for a 106.. Quote
DCarlton Posted Saturday at 07:01 PM Report Posted Saturday at 07:01 PM 4 hours ago, Rmfriday said: I also was wondering if this would work? I can’t seam to find what the output from the Uavionics adapter is? would be a cool setup if it worked and also replaced the need for a 106.. Yep. It may be in the AV-30-E installation manual but I haven't looked yet. I've got a strong hunch it would work. It would make for an interesting test. Quote
