47U Posted December 1 Report Posted December 1 1 hour ago, 201Steve said: @47U all that work carrying blocks… I could not help but notice the tail tie down not but mere inches away from your stack of weight…. I didn’t run a flightline safety analysis on this project, all I did was rotate pictures and repost them. It does look a bit sketchy though, doesn’t it.
201Steve Posted December 1 Report Posted December 1 @47U ah. Not your bird. Well, either way I just meant to say- why not just use the perfect ground anchor already there! lol
Captnmack Posted Friday at 03:49 PM Report Posted Friday at 03:49 PM A local A&P built these and adjustable for different aircraft.
PT20J Posted Friday at 05:10 PM Report Posted Friday at 05:10 PM I got one of these. Used 2 layers of blocks. 1
Skates97 Posted Friday at 05:56 PM Report Posted Friday at 05:56 PM I bought a furniture dolly, four 90lb bags of quick crete on it, and a heavy duty tie down strap with I think a 1,000lb working load limit. 1
0TreeLemur Posted Friday at 09:28 PM Report Posted Friday at 09:28 PM 3 hours ago, Skates97 said: I bought a furniture dolly, four 90lb bags of quick crete on it, and a heavy duty tie down strap with I think a 1,000lb working load limit. ^^^ this. In testing it, I put 50 lb sacks of gravel on the tail. At about 2-1/2 the tail connector went from tension to compression, leading me to believe that the tension is less than 150 lbs on my J model. It ain't a hug load.
Hank Posted Friday at 10:42 PM Report Posted Friday at 10:42 PM 1 hour ago, 0TreeLemur said: ^^^ this. In testing it, I put 50 lb sacks of gravel on the tail. At about 2-1/2 the tail connector went from tension to compression, leading me to believe that the tension is less than 150 lbs on my J model. It ain't a hug load. I've used a case and a half of oil, my roll of wrenches and about 5-6 printed approach plates books, then had to push down with one arm. My old IA had a galvanized wash tub on wheels, filled with cement with a eyelet poking up out of it; he used it for many things, including holding the nose down when removing the engine from a plane (not mine). This does require planning and preparation, installing wheels and wiring up the eyelet before mixing the cement.
