Just finished leaning to peak at 7000 ft, and the engine started running rough. Similar to 3 of 4 cylinders firing. I reverted to full rich. Turned on the boost pump. Cycled left, right and back to both magnetos. No change. Just started to look for a place to make a precautionary landing, and the roughness cleared. I switched fuel tanks, and continued my flight without a recurrence. Any ideas?  I was thinking maybe a bit of water in the fuel. I drained both sumps. The right had a few drops of water, and the left was clear. I was flying on the left when the engine was rough. I also drained the sump in the cockpit during preflight using 5 seconds on both sides. Scratching my head.
Edited by Derrickearly
Grammar
I had a similar occurance KOSH bound over the summer about an hour into flight. only lasted a few seconds. The roughness went away quicker than my elevated pulse. I decided it was a small amount of water, despite the usual sumping.
Here’s another illustration of dead cylinder, clogged injector.
It does get your attention especially at 500 ft.
That’s exactly what happened to me on a trip. Happened again a few hours later on the same trip. Pulled the injectors when I got home and found one partially clogged. All good after cleaning them.
2 hours ago, ArtVandelay said:
Engine monitor data?
This is an example of what losing a cylinder for a few moments looks like:
Thank you!  I didn’t think to look at the egt and cht readings. Now I know what to look for.
I think you need to replace fuel cap O-rings, any amount of water is not a normal condition, you should never find water.
I’ve never seen water come from anywhere except a leaking fuel cap myself
Be sure to disassemble the cap and change the little o-ring around the center pin. You'll need a new, small cotter pin to put it back together.
The fuel lines do not feed from the bottom of the tanks. That’s why there is so much unusable fuel. It takes a lot of water in the tank to get to the engine and then it will likely just quit.
Shouldn’t be any water if you’ve sampled your tanks during preflight.
