cferr59 Posted October 19, 2022 Report Posted October 19, 2022 My thoughts are to slow to ~80mph (C model), open the door and let it roll off the back of the wing. Any other ideas? Thanks! 1 Quote
ArtVandelay Posted October 20, 2022 Report Posted October 20, 2022 Just be careful (keep seat belts on), I don’t want to read about you on aviation mishaps forum. Quote
201Steve Posted October 20, 2022 Report Posted October 20, 2022 Affix a wood screw eye hook to pumpkin. Latch to wing tie down eye hook with a straight pin. Run a line from pin to gear door. Keep gear down until ready to drop. Select gear up- bomb deployed. no I wouldn’t actually do that but I also wouldn’t participate in my Mooney. Far fetched as it may be, I’d be thinking about a pumpkin tail strike on my horizontal stab. 1 Quote
Guest Posted October 20, 2022 Report Posted October 20, 2022 On 10/20/2022 at 12:27 AM, 201Steve said: Affix a wood screw eye hook to pumpkin. Latch to wing tie down eye hook with a straight pin. Run a line from pin to gear door. Keep gear down until ready to drop. Select gear up- bomb deployed. no I wouldn’t actually do that but I also wouldn’t participate in my Mooney. Far fetched as it may be, I’d be thinking about a pumpkin tail strike on my horizontal stab. Expand Sounds like the voice of experience! Quote
GeeBee Posted October 20, 2022 Report Posted October 20, 2022 "As God as my witness, I thought turkeys could fly" Or....how air drops can go wrong....quickly 1 9 Quote
Fly Boomer Posted October 20, 2022 Report Posted October 20, 2022 On 10/20/2022 at 12:27 AM, 201Steve said: I wouldn’t actually do that but I also wouldn’t participate in my Mooney Expand Nope. Fly with someone who has a taildragger with the door off. This is like asking if you can land on a glacier or in a stream bed. Quote
carusoam Posted October 20, 2022 Report Posted October 20, 2022 Pick a properly sized pumpkin… 1) It fits through the vent window… 2) It doesn’t dent anything when it hits… 3) Call in a favor with one of your Brand C friends…. With a big window in each door. PP thoughts and other unhelpful ideas only… Best regards, -a- 1 Quote
N201MKTurbo Posted October 20, 2022 Report Posted October 20, 2022 Just remember the pumpkin is going Mooney speed when you release it. Think lobbing it onto the target. You will be amazed how many people think the wind will blow it back and release it after the target. 1 Quote
carusoam Posted October 20, 2022 Report Posted October 20, 2022 Time to bust out the physics book! Height of drop, speed (Vx, Vy, axis not climb rates) of drop, gravity, some fudge factor for the non-ideal pumpkin shape and its wind resistance… WAAS distance measuring…. To identify the target, and release point… Practice the execution… dry runs will be important… Plan A: Fly the plane, no distractions… don’t make it into the daily paper… Best regards, -a- Quote
Rwsavory Posted October 20, 2022 Report Posted October 20, 2022 1. Ascertain that aircraft airspeed and groundspeed is Zero. 2. Stand on wing walk holding pumpkin firmly in hands. 3. Extend arms so that pumpkin is forward of wing’s leading edge. 4. Release pumpkin. 1 2 Quote
DXB Posted October 20, 2022 Report Posted October 20, 2022 Use a syringe to squirt a pumpkin spice latte through the narrow slit created when the door pops open in flight. Where you been @cferr59?? Been a long time since I saw you even tho you’re just a few hangars away… 1 1 Quote
Marc_B Posted October 20, 2022 Report Posted October 20, 2022 @DXB when i read this my first thought was "Jose's pee tube" pumpkin puree...if you have enough puree you could start your run early and streak it right across the target! ha ha. 2 2 Quote
Hank Posted October 20, 2022 Report Posted October 20, 2022 Good luck getting the door open far enough to push out anything larger than your fist . . . . 3 Quote
A64Pilot Posted October 20, 2022 Report Posted October 20, 2022 On 10/20/2022 at 4:59 PM, Hank said: Good luck getting the door open far enough to push out anything larger than your fist . . . . Expand Exactly, I believe it was Cut Bank Montana that had a junk car on the airfield, if you could fly over at some set altitude and hit it with a bowling ball your fuel was free. It’s way harder than you would think. Apparently some time ago they decided the liability of bowling balls falling from aircraft was too high and stopped it. Pumpkin is better than a bowling ball? Find someone with an airplane that it’s legal to remove the door and go with them The weekend is jam-packed with fun events for the entire family. However, this year’s event will not include the bowling ball drop, a favorite event, but a liability nightmare. http://www.cutbankpioneerpress.com/cut_bank_pioneer_press/news/article_ebcbc5a2-1d78-11e4-a1fe-0019bb2963f4.html The weekend is jam-packed with fun events for the entire family. However, this year’s event will not include the bowling ball drop, a favorite event, but a liability nightmare. “The insurance company won’t let us do the bowling ball drop, and because it has been eliminated we have received a lot of comment on it,” said Nollkamper. However, he does not believe that the elimination of the bowling ball drop will have an effect on turnout for the event. Quote
ArtVandelay Posted October 20, 2022 Report Posted October 20, 2022 On 10/20/2022 at 4:59 PM, Hank said: Good luck getting the door open far enough to push out anything larger than your fist . . . .Speaking from personal experience? 1 Quote
Bolter Posted October 20, 2022 Report Posted October 20, 2022 I can neither confirm nor deny having seen flour bombs from a J model. Low speed, but still well above stall speed, and the door is opened pretty easily. I strongly encourage a separate pilot and bombadier for slow and low flight. The mass of a pumpkin concerns me for impact with a poorly done toss, however. Your no wind drop distance is calculated by: 1 Quote
N201MKTurbo Posted October 20, 2022 Report Posted October 20, 2022 I’ve done 3 different flour boomings from a Mooney. Always through the storm window. Quote
WAFI Posted October 20, 2022 Report Posted October 20, 2022 As long as you don't say "Hey watch this!" you'll be fine. Quote
N201MKTurbo Posted October 20, 2022 Report Posted October 20, 2022 The best I ever did was 3’ right and 10’ short. The target was a mannequin in a canoe wearing a red bikini. Two people got in the canoe and the winner got her in the left boob. There was a bit of controversy. Some said if the flour haven’t hit the lady, it would have been about 5 feet long. There were about 30 planes and you got 3 tries. There were 4 airplanes in the air at any time. You did your three runs and on the next circuit you landed and another plane would take off. 1 1 Quote
Hank Posted October 20, 2022 Report Posted October 20, 2022 On 10/20/2022 at 6:23 PM, ArtVandelay said: Speaking from personal experience? Expand I left the door open while taxiing one hot summer day and forgot to close it. Managed to do so at 3000 msl / 100 mph and went on my way. Not sure I could have pushed it open a foot, it was trailing nicely with about a 2" gap. Quote
Pinecone Posted October 20, 2022 Report Posted October 20, 2022 On 10/20/2022 at 6:51 PM, Bolter said: I can neither confirm nor deny having seen flour bombs from a J model. Low speed, but still well above stall speed, and the door is opened pretty easily. I strongly encourage a separate pilot and bombadier for slow and low flight. The mass of a pumpkin concerns me for impact with a poorly done toss, however. Your no wind drop distance is calculated by: Expand You didn’t take into account the drag of the pumpkin. From the time you release it, it is decelerating. Quote
MikeOH Posted October 21, 2022 Report Posted October 21, 2022 On 10/20/2022 at 9:59 PM, Pinecone said: You didn’t take into account the drag of the pumpkin. From the time you release it, it is decelerating. Expand Yeah, and you need to know if it's an African or European pumpkin... 2 3 Quote
aviatoreb Posted October 21, 2022 Report Posted October 21, 2022 On 10/21/2022 at 1:12 AM, MikeOH said: Yeah, and you need to know if it's an African or European pumpkin... Expand That’s not a horse… you are just banging to coconuts together. 3 Quote
Bolter Posted October 21, 2022 Report Posted October 21, 2022 On 10/20/2022 at 9:59 PM, Pinecone said: You didn’t take into account the drag of the pumpkin. From the time you release it, it is decelerating. Expand True. This is an order of magnitude calc. Too many variables you cannot control to make a meaningful precision calculation. Including knowing your precise position and speed relative to target at the moment of the drop. Quote
bradp Posted October 21, 2022 Report Posted October 21, 2022 I threw a gross banana peel my kid handed me out the pilot window over the Atlantic. it just smacked the H stab and caused a gross mess. 1 Quote
