GeeBee Posted August 22, 2022 Report Posted August 22, 2022 Make a mockup where you can insert the RedBird TD-2 glass and I am sure you will have buyers. 1
robert38606 Posted August 23, 2022 Report Posted August 23, 2022 9 hours ago, MooneyP87 said: Currently doing it for fun however I have had a few people ask if I was planning on selling some type of kit or making it certified. I don't have any plans as of right now to get it certified (however this may change once I have it completed). I have read briefly on the certification process and I would need to provide a plug and play system for this to happen. I could do this but the price would knock most sim enthusiast out. I am thinking about making replica interior kits that would have the framing, walls, ceiling, and possibly a custom panel depending on what the user wants. The panel is where the hard part comes in because not everyone wants a G1000 setup. I guess it depends on what price knocks most sim enthusiasts out, but I would be interested 1
LANCECASPER Posted August 23, 2022 Report Posted August 23, 2022 10 hours ago, MooneyP87 said: Were those bottles full when you started this project?
carusoam Posted August 23, 2022 Report Posted August 23, 2022 P87, Can you share a pic or two of your printer? This may spark a few more ideas for people that can see in 3D… It will be interesting to see how well printed parts hold up during sim use…. Best regards, -a-
MooneyP87 Posted August 24, 2022 Author Report Posted August 24, 2022 On 8/22/2022 at 8:50 PM, LANCECASPER said: Were those bottles full when you started this project? I have no idea what you're talking about
MooneyP87 Posted August 24, 2022 Author Report Posted August 24, 2022 On 8/22/2022 at 10:30 PM, carusoam said: P87, Can you share a pic or two of your printer? This may spark a few more ideas for people that can see in 3D… It will be interesting to see how well printed parts hold up during sim use…. Best regards, -a- Sure! The three printers shown are all Prusa MK3S's. I also have an Ender printer but I try to not use it unless I need all the printers running as the quality just isn't the same. The parts are extremely durable. For the heavy use parts like the panel, switches, and dashpad I am printing those using PETG with a larger print nozzle than standard with an additional wall layer (typically 3d parts are printed with 2 solid layers for walls but I am using 3). I've tried to break the dashpad with my hands and was unable. The walls/ceiling are printed at 3mm thick with three layer print seams to make them more durable. I have learned that I need to make connector links for all of the large parts so that they can bolt together with 3mm bolts. This isn't so much of a strength issue, but it will help, but more of an alignment correction. Having 18 printed parts for a wall with no way to connect them except some type of glue makes it a pain for linking them together. So each piece moving forward (upper left wall/ceiling, and right sides) will still be large separate pieces but I will make each large section bolt together. This would also allow someone to not be required to glue them. 1
MooneyP87 Posted September 6, 2022 Author Report Posted September 6, 2022 (edited) Update post: The panel is painted and ready. I am going to give it a few days to fully cure and then I will install the G1000/G5 units along with the switches. I test fit it with the vertical column last night (2nd pic). I still have some work to do on the vertical column but it is close to being ready for paint. I also finished the dashpad this weekend (1st pic) and finished the left (lower) wall but forgot to take a picture of it. Right now I am printing the left upper wall. Should have some major progress pictures coming soon as I am just over half way finished with the printed parts. Edited September 6, 2022 by MooneyP87 1
Fly Boomer Posted September 6, 2022 Report Posted September 6, 2022 13 minutes ago, MooneyP87 said: Update post: The panel is painted and ready. I am going to give it a few days to fully cure and then I will install the G1000/G5 units along with the switches. I test fit it with the vertical column last night (2nd pic). I still have some work to do on the vertical column but it is close to being ready for paint. I also finished the dashpad this weekend (1st pic) and finished the left (lower) wall but forgot to take a picture of it. Right now I am printing the left upper wall. Should have some major progress pictures coming soon as I am just over half way finished with the printed parts. You shared pics of your printing setup and parts you are printing, but it doesn't look like the bed of any of your printers is nearly large enough to print those huge parts. Do you have another monster printer somewhere?
MooneyP87 Posted September 6, 2022 Author Report Posted September 6, 2022 (edited) 30 minutes ago, Fly Boomer said: You shared pics of your printing setup and parts you are printing, but it doesn't look like the bed of any of your printers is nearly large enough to print those huge parts. Do you have another monster printer somewhere? I wish I had a monster printer hiding.. I do have a Prusa XL on pre-order but even once I receive it, it will only print 14" parts; still better than 8-9" though. The answer to the question is the most time consuming part of the project, 3D modeling. I model the main sections and then make cuts every 210-240mm and insert a bracket on the back of the print that will link the parts together with 3mm bolts. See pics for a better explanation. The inside of the cabin looks like one piece, however the rear shows all of the connected brackets that are used when the parts are split so that they can be linked together. The 2nd pic shows the boxes I use to "cut/split" the objects for printing. The large brackets you see on the corners are used to attach the section to the frame of the simulator. Edited September 6, 2022 by MooneyP87
Fly Boomer Posted September 6, 2022 Report Posted September 6, 2022 10 minutes ago, MooneyP87 said: I wish I had a monster printer hiding.. I do have a Prusa XL on pre-order but even once I receive it, it will only print 14" parts; still better than 8-9" though. The answer to the question is the most time consuming part of the project, 3D modeling. I model the main sections and then make cuts every 210-240mm and insert a bracket on the back of the print that will link the parts together with 3mm bolts. See pics for a better explanation. The inside of the cabin looks like one piece, however the rear shows all of the connected brackets that are used when the parts are split so that they can be linked together. The 2nd pic shows the boxes I use to "cut/split" the objects for printing. The large brackets you see on the corners are used to attach the section to the frame of the simulator. Very clever!
201Mooniac Posted September 6, 2022 Report Posted September 6, 2022 That is incredibly impressive work. I cant wait to see what it looks like finished. Please let me know if you decide to sell them
MooneyP87 Posted September 7, 2022 Author Report Posted September 7, 2022 Here's what the pieces actually look like during the process. Picture is the upper left wall I am currently printing. This system seems to be working well for now although I may make a few tweaks to it in the future for additional stability.
carusoam Posted September 8, 2022 Report Posted September 8, 2022 Something must be askew with the scale….. The panel parts make the big dog in the background appear kind of tiny… This project gets better every day! Best regards, -a-
MooneyP87 Posted September 13, 2022 Author Report Posted September 13, 2022 Here's a picture showing the panel with the dash pad attached to it. I've installed and tested the LED lighting strip and I think it will provide adequate lighting, even with the brightness adjusted very low but I won't know for sure until I get everything inside the frame. Now I just need to make the vinyl labels for all buttons and switches and the panel will be ready for wiring. 6
MooneyP87 Posted September 26, 2022 Author Report Posted September 26, 2022 Weekend Update: I have the frame put together and am test fitting the panel and left walls. I still have a lot of work to do but the project is coming along nicely.
TuomoMooneyFlying Posted September 26, 2022 Report Posted September 26, 2022 This is extremely impressive work! There’s so much detail and separate smaller projects embedded to it. Did you build the throttle and yoke from scratch or are you converting an existing project unit? How are all the switches wired and connected, using mobiflight and arduino megas?
MooneyP87 Posted September 26, 2022 Author Report Posted September 26, 2022 28 minutes ago, TuomoMooneyFlying said: This is extremely impressive work! There’s so much detail and separate smaller projects embedded to it. Did you build the throttle and yoke from scratch or are you converting an existing project unit? How are all the switches wired and connected, using mobiflight and arduino megas? Thanks! The throttle quadrant I purchased earlier this year from eBay, there's a guy who 3d prints them and sells them as plug-n-play. Hindsight, I should have built it myself because getting it to mount into the rest of the vertical column was a pain and I feel like I could have made them a little more precise, but it's done now. The yokes are honeycomb yokes that I have cut up to pieces and rewired lol. This is all a big learning curve but at some point I plan on making my own to have them more realistic, but these will work for now. All of the switches will be wired up to Arduino boards. There are a few options for the software/switch integration, and I am not certain which one I am going to use yet but once I get to the wiring stage I will make that determination. The reason I state this is, I want to find one solution that I can use for X-Plane and MSFS so that I can test and use both flight sims but haven't had the time to test out different switches, potentiometers, and LEDs.
