MATTS875 Posted February 4, 2021 Report Posted February 4, 2021 I know this might have been covered before but if one were to get the STC 310 upgrade will a McCauley 3 blade work or does it have to be a hartzell prop?
Parker_Woodruff Posted February 4, 2021 Report Posted February 4, 2021 1 minute ago, MATTS875 said: I know this might have been covered before but if one were to get the STC 310 upgrade will a McCauley 3 blade work or does it have to be a hartzell prop? Needs a new prop
Niko182 Posted February 4, 2021 Report Posted February 4, 2021 You need 1 of the 3 hartzell Shimitar props, or the 4 blade MT prop.
StevenL757 Posted February 4, 2021 Report Posted February 4, 2021 17 minutes ago, Niko182 said: You need 1 of the 3 hartzell Shimitar props, or the 4 blade MT prop. 51 minutes ago, Parker_Woodruff said: Needs a new prop Ditto. The Harzell F7498 (Acclaim Type-S prop) is the best bang for your buck today. Depending on whether you have TKS installed or not, this prop will gain you between 4 and 7 knots over the "standard" F7693/DF-2 scimitar. The 7498 also weighs 7.5 pounds less. Stay away from the composite flavor unless you enjoy spending $27k+ on a prop that will perform the same as the standard 7693/DF-2. https://hartzellprop.com/products/top-prop/mooney/mooney-m20r-m20s-and-m20tn/ Let me know if you need a hand procuring when/if the time comes. Steve
MIm20c Posted February 4, 2021 Report Posted February 4, 2021 From what I’ve seen the type S needs to babied a little more than the standard top prop. Seems to be picking up nicks a little faster. Too soon to tell but I’m curious how it will look with 2k+ hrs. However, it’s absolutely worth it for the speed and weight advantages. 1
StevenL757 Posted February 5, 2021 Report Posted February 5, 2021 1 hour ago, MIm20c said: From what I’ve seen the type S needs to babied a little more than the standard top prop. Seems to be picking up nicks a little faster. Too soon to tell but I’m curious how it will look with 2k+ hrs. However, it’s absolutely worth it for the speed and weight advantages. Completely agree. Given it's thinner, it does wear a bit more than the standard. I'm finishing in the avionics shop on Saturday, so I'll grab some pics tomorrow if it helps anyone. I have just over 700 hours on mine, and it certainly does show wear. 1
Cody Stallings Posted February 6, 2021 Report Posted February 6, 2021 Not to be “That Guy” but the F7693DF prop will make it in an out of a propshop more times that the F7698 due to the fact it’s a thicker beefer blade. Lots of width an Thickness on those blades.
carusoam Posted February 6, 2021 Report Posted February 6, 2021 You nailed it Cody! The cost of greatness... for the thin blades... Best regards, -a-
Tim Jodice Posted February 6, 2021 Report Posted February 6, 2021 On 2/4/2021 at 6:11 PM, StevenL757 said: Stay away from the composite flavor unless you enjoy spending $27k+ on a prop that will perform the same as the standard 7693/DF-2. I am sure that they have gone up in 3 years but @FoxMike paid about $15K for a 4 blade in 2018. I paid about 13K last year for a 3 blade.
Niko182 Posted February 6, 2021 Report Posted February 6, 2021 Last year i got a quote i believe for 12.8k in socal for the 7498 and the 7693.
StevenL757 Posted February 6, 2021 Report Posted February 6, 2021 37 minutes ago, Niko182 said: Last year i got a quote i believe for 12.8k in socal for the 7498 and the 7693. Yeah, that sounds right. My 7498 was just over 15k, as I had to add TKS slinger ring, nozzles, and overshoes. 44 minutes ago, Tim Jodice said: I am sure that they have gone up in 3 years but @FoxMike paid about $15K for a 4 blade in 2018. I paid about 13K last year for a 3 blade. The 4-blade MTV-14 for the Ovation platform is easily in the low 20’s today, unfortunately. If I remember correctly, it was only a slight bit less back in 2014 when I was shopping for new props when the engine was being changed out.
Tim Jodice Posted February 6, 2021 Report Posted February 6, 2021 28 minutes ago, StevenL757 said: The 4-blade MTV-14 for the Ovation platform is easily in the low 20’s today, unfortunately. If I remember correctly, it was only a slight bit less back in 2014 when I was shopping for new props when the engine was being changed out. I will call MT Monday. I hope it has not gone up $6K+ in 3 years. I am unfamiliar with hartzell's composite pricing other than a friend I made at the airport and he owns a piper matrix. he said it was $12-13K just to overhaul it. I could see Hartzells being in the $20-30Ks Hartzells are true structural composite propellers where as a MT is basically a wooden propeller with a composite cover simply to protect the wood and is not structural. 1 service benefit I know of is how easy it is to repair a wooden propeller. When I was in Deland having my propeller installed I was able to check out MT facility and I saw this. This blade was a typical prop strike. You can see where the wood grain is no longer straight and it has curves in it. that is where it snapped. it is repaired to new spec. It costs about $1600 a blade.
MATTS875 Posted February 7, 2021 Author Report Posted February 7, 2021 Ok. Thanks for all the input. Seems that the 310 makes a big difference in take off and climb. Best to find one that’s already had the STC done 1
Niko182 Posted February 7, 2021 Report Posted February 7, 2021 Just now, MATTS875 said: Ok. Thanks for all the input. Seems that the 310 makes a big difference in take off and climb. Best to find one that’s already had the STC done It makes a pretty big difference. I made the jump from 244hp to 310 and was blown away to say the least
MATTS875 Posted February 7, 2021 Author Report Posted February 7, 2021 1 minute ago, Niko182 said: It makes a pretty big difference. I made the jump from 244hp to 310 and was blown away to say the least I’m looking forward to it. Will be a big jump from the 201
carusoam Posted February 7, 2021 Report Posted February 7, 2021 280 to 310... is a holy cow... seat of the pants... no instruments required... You know you have full power with all of the acceleration going on... Starting with 244hp...has got to make this upgrade super worthwhile... If unsure... go for a ride... I flew with @Cris in his Screamin’ Eagle... Best regards, -a-
