Guest Posted August 24, 2020 Report Posted August 24, 2020 For comparison, here’s the equivalent for our Prime Minister’s home. Less than 1 mile in diameter. Quote
Seymour Posted August 24, 2020 Report Posted August 24, 2020 On 8/22/2020 at 5:25 PM, flyboy0681 said: VFR flight plans work just fine, but just don't arrive at the outer ring unannounced when coming in, give ATC ample time to identify you and get things squared away if you aren't being handed off to them. Expand A question to clarify, since my home drome is just inside the outer 30nm ring and I'll be returning during a VIP TFR this Friday: If I'm under VFR flight following ( "traffic advisories" ) with a discrete transponder code flying direct to my uncontrolled field, do I also need to have filed a VFR flight plan? ....and does it need to be activated? (I'd like my first formation flying experience to be a positive one.) Quote
mike_elliott Posted August 24, 2020 Report Posted August 24, 2020 On 8/23/2020 at 1:47 PM, flyboy0681 said: I was in Manhattan two years ago when Trump was in town. Words could not possibly describe traffic conditions in midtown as Fifth Avenue was shut down around Trump Tower. Expand looking at the traffic in mid town lately on the business channel beauty shots, that might not be an issue any longer. Seems all the cars left Manhattan for some reason Quote
mike_elliott Posted August 24, 2020 Report Posted August 24, 2020 On 8/24/2020 at 10:33 AM, M20Doc said: For comparison, here’s the equivalent for our Prime Minister’s home. Less than 1 mile in diameter. b Expand We have the biggest TFRs..Our TFRs are the best, they are the biggest in the world. 1 3 Quote
flyboy0681 Posted August 24, 2020 Report Posted August 24, 2020 On 8/24/2020 at 2:03 PM, mike_elliott said: We have the biggest TFRs..Our TFRs are the best, they are the biggest in the world. Expand They are the most beautiful TFR's you've ever seen. 1 1 Quote
Andy95W Posted August 24, 2020 Report Posted August 24, 2020 On 8/24/2020 at 2:00 PM, Seymour said: A question to clarify, since my home drome is just inside the outer 30nm ring and I'll be returning during a VIP TFR this Friday: If I'm under VFR flight following ( "traffic advisories" ) with a discrete transponder code flying direct to my uncontrolled field, do I also need to have filed a VFR flight plan? ....and does it need to be activated? (I'd like my first formation flying experience to be a positive one.) Expand Yes, you must be on a VFR flight plan, but that's a good question about "activated": --------------- All aircraft must be on an active IFR or filed VFR flight plan with a discrete code assigned by an Air Traffic Control (ATC) facility. Aircraft must be squawking the discrete code prior to departure and at all times while in the TFR and must remain in two-way radio communications with ATC. ------------------- Best suggestion, of course, is to activate it to remove any doubt or question from the Feds. It's easy enough to do using the Lockheed Martin website, you won't have to talk to anyone on the radio. https://www.1800wxbrief.com/Website/mobileweb/#/ 1 Quote
Marauder Posted August 24, 2020 Author Report Posted August 24, 2020 (edited) On 8/24/2020 at 3:47 PM, Andy95W said: Yes, you must be on a VFR flight plan, but that's a good question about "activated": --------------- All aircraft must be on an active IFR or filed VFR flight plan with a discrete code assigned by an Air Traffic Control (ATC) facility. Aircraft must be squawking the discrete code prior to departure and at all times while in the TFR and must remain in two-way radio communications with ATC. ------------------- Best suggestion, of course, is to activate it to remove any doubt or question from the Feds. It's easy enough to do using the Lockheed Martin website, you won't have to talk to anyone on the radio. https://www.1800wxbrief.com/Website/mobileweb/#/ Expand You need to have an active VFR flight plan prior to entering the 30 nm ring of the TFR. Found a NORAD guide: https://www.norad.mil/Portals/29/Documents/NORAD civil aviation kneeboard - US Airspace (Aug 17).pdf Edited August 24, 2020 by Marauder 2 Quote
flyboy0681 Posted August 24, 2020 Report Posted August 24, 2020 On 8/24/2020 at 4:07 PM, Marauder said: You need to have an active VFR flight plan prior to entering the 30 nm ring of the TFR. Found a NORAD guide: https://www.norad.mil/Portals/29/Documents/NORAD%20civil%20aviation%20kneeboard%20-%20US%20Airspace%20(Aug%2017).pdf Sent from my iPad using Tapatalk Pro Expand Need an active VFR Flight Plan but it doesn't have to be actually activated. All they want is a record of who is flying in case they need to refer to it. Quote
Marauder Posted August 24, 2020 Author Report Posted August 24, 2020 On 8/24/2020 at 4:11 PM, flyboy0681 said: Need an active VFR Flight Plan but it doesn't have to be actually activated. All they want is a record of who is flying in case they need to refer to it. Check the “During Flight” section. It says “activate”. I’m pretty sure means you need to activate it, not just have one on file.Sent from my iPad using Tapatalk Pro Quote
flyboy0681 Posted August 24, 2020 Report Posted August 24, 2020 On 8/24/2020 at 4:13 PM, Marauder said: Check the “During Flight” section. It says “activate”. I’m pretty sure means you need to activate it, not just have one on file. Sent from my iPad using Tapatalk Pro Expand When the Mar-a-Lago TFR was started, Palm Beach ATC held a town hall meeting and went through all of the steps and procedures for local pilots and that's what they told the group. Since that time I have flown VFR dozens of times during the TFR and have never been questioned whether I had opened the flight plan, even when returning home. Also keep in mind that during the TFR, Secret Service ATC Controllers (yes there's a such thing) are sitting beside the Palm Beach controllers watching over the scopes and have a controller up in the tower. Quote
Marauder Posted August 24, 2020 Author Report Posted August 24, 2020 (edited) On 8/24/2020 at 4:23 PM, flyboy0681 said: When the Mar-a-Lago TFR was started, Palm Beach ATC held a town hall meeting and went through all of the steps and procedures for local pilots and that's what they told the group. Since that time I have flown VFR dozens of times during the TFR and have never been questioned whether I had opened the flight plan, even when returning home. Also keep in mind that during the TFR, Secret Service ATC Controllers (yes there's a such thing) are sitting beside the Palm Beach controllers watching over the scopes and have a controller up in the tower. Expand There was an AOPA article that was published a while back that mentioned that TFR procedures may be modified from the original intent of 91.141. Maybe this is what they meant. When I pull up an active Trump TFR, it clearly shows it requires an active IFR or filed VFR flight plan. This leads to more confusion as to whether it needs to be activated. Sent from my iPhone using Tapatalk Pro Edited August 24, 2020 by Marauder Quote
Hank Posted August 24, 2020 Report Posted August 24, 2020 (edited) On 8/24/2020 at 2:03 PM, mike_elliott said: We have the biggest TFRs..Our TFRs are the best, they are the biggest in the world. Expand And the longest-lasting! See Washington, DC and Disneyworld . . . . That's why I posted my 13th-floor-view of the DCA VOR, because that's about as high as I'll ever see it. In the airliner, the view from the back is rather restricted! Edited August 24, 2020 by Hank 1 Quote
EricJ Posted August 24, 2020 Report Posted August 24, 2020 (edited) On 8/24/2020 at 5:34 PM, Hank said: And the longest-lasting! See Washington, DC and Disneyworld . . . . That's why I posted my 13th-floor-view of the DCA VOR, because that's about as high as I'll ever see it. In the airliner, the view from the back is rather restricted! Expand Disneyland, too. I think it's marketing rather than practicality. Remember Disney also single-handedly got the copyright laws changed so that the Mickey Mouse copyrights wouldn't expire and become public domain. They seem to know how to get what they want from the government. Edited August 24, 2020 by EricJ Quote
aviatoreb Posted August 24, 2020 Report Posted August 24, 2020 On 8/24/2020 at 5:54 PM, EricJ said: Disneyland, too. I think it's marketing rather than practicality. Remember Disney also single-handedly got the copyright laws changed so that the Mickey Mouse copyrights wouldn't expire and become public domain. They seem to know how to get what they want from the government. Expand Donald Duck's uncle, Scrooge McDuck runs a very successful Lobbyist outfit. 1 Quote
carusoam Posted August 24, 2020 Report Posted August 24, 2020 I think the purpose of the TFR has changed.... Since the military can create confetti out of any plane flying by.... It seems to be an anti-sleep deprivation tactic... If a pilot wanted to interfere with the performance of the opposing team... slowly flying over the house with a heavy helicopter will make an excellent early wake up call... I bet the neighbors really appreciate it as well... Always be friendly to the ATC union... they could put a string of low flying heavy planes over your house for a month... PP Thoughts only, not a sleep expert... Best regards, -a- Quote
Rmag Posted February 4, 2021 Report Posted February 4, 2021 @Marauder first one hits tomorrow at 5:30 PM to Monday 4:00 PM Quote
Hank Posted February 5, 2021 Report Posted February 5, 2021 On 2/4/2021 at 7:46 PM, Rmag said: @Marauder first one hits tomorrow at 5:30 PM to Monday 4:00 PM Expand So will that keep everyone from being sent to the Modena penalty box? Quote
carusoam Posted February 5, 2021 Report Posted February 5, 2021 Modena, Moderna, Madonna... Where do the Biden’s prefer to vacation, Martha’s Vineyard? Best regards, -A- Quote
flyboy0681 Posted February 5, 2021 Report Posted February 5, 2021 On 2/5/2021 at 2:10 AM, carusoam said: Modena, Moderna, Madonna... Where do the Biden’s prefer to vacation, Martha’s Vineyard? Best regards, -A- Expand ... sis boom bah 1 Quote
Marauder Posted February 5, 2021 Author Report Posted February 5, 2021 On 2/5/2021 at 1:49 AM, Hank said: So will that keep everyone from being sent to the Modena penalty box? Expand Thank goodness!!!! Quote
Marauder Posted February 5, 2021 Author Report Posted February 5, 2021 On 2/5/2021 at 2:10 AM, carusoam said: Modena, Moderna, Madonna... Where do the Biden’s prefer to vacation, Martha’s Vineyard? Best regards, -A- Expand He owns a large beach house in Rehoboth Beach. Rumor has it that they built a helipad either on or near the property. 1 Quote
Marauder Posted February 5, 2021 Author Report Posted February 5, 2021 On 2/4/2021 at 7:46 PM, Rmag said: @Marauder first one hits tomorrow at 5:30 PM to Monday 4:00 PM Expand This may finally fill up your hangars! I did find his first one was unusual. The inner circle is 12 nm wide. Historically they are 10 nm. Heard that it was widened to allow him to visit family in the area. I suspect, when summer rolls around, we can expect to see more of them at his Rehoboth beach home. Quote
flyboy0681 Posted February 5, 2021 Report Posted February 5, 2021 On 2/5/2021 at 4:33 PM, Marauder said: He owns a large beach house in Rehoboth Beach. Rumor has it that they built a helipad either on or near the property. Expand Out with the old, in with the new.. 1 Quote
Rmag Posted February 6, 2021 Report Posted February 6, 2021 On 2/5/2021 at 4:35 PM, Marauder said: I suspect, when summer rolls around, we can expect to see more of them at his Rehoboth beach home. Expand Yeah I get to file flight plans at both ends. His Rehoboth beach outer ring covers KWWD were I land in the summer. 1 Quote
Mark605 Posted February 6, 2021 Report Posted February 6, 2021 There was a guy on Jax center last night in a TBM bellyaching because ATC told him he can't land at ILG because of the TFR. Guess we know who doesn't check NOTAM's.... He ended up going to EVY. 1 Quote
