Chrigi Posted June 8, 2020 Report Posted June 8, 2020 parting out Mooney M20R Ovation with IO-550-G, prop strike. Let me know what you need! Ailerons 400 USD each Wingtips with lights 500 USD each and much more Quote
charlesual Posted June 8, 2020 Report Posted June 8, 2020 Do you happen to know if the wingtips fit an F model? If so, I’d like to buy. Sent from my iPhone using Tapatalk Quote
MarkD34M Posted June 8, 2020 Report Posted June 8, 2020 I'd like to purchase the oil temp prop that sits under the oil cooler if available. Quote
Alan Fox Posted June 8, 2020 Report Posted June 8, 2020 44 minutes ago, charlesual said: Do you happen to know if the wingtips fit an F model? If so, I’d like to buy. Sent from my iPhone using Tapatalk Wingtips will not fit an F , the ailerons are different Quote
charlesual Posted June 8, 2020 Report Posted June 8, 2020 Aw, bummer. Do you happen to know if the landing gear motor would fit an F?Thanks AlanSent from my iPhone using Tapatalk Quote
Alan Fox Posted June 8, 2020 Report Posted June 8, 2020 10 minutes ago, charlesual said: Aw, bummer. Do you happen to know if the landing gear motor would fit an F? Thanks Alan Sent from my iPhone using Tapatalk It will not , as your F is a 14 volt system , and all R models are 28 Volt , What year is your F ?? Quote
charlesual Posted June 8, 2020 Report Posted June 8, 2020 1967Sent from my iPhone using Tapatalk Quote
charlesual Posted June 8, 2020 Report Posted June 8, 2020 I want to swap out the 20:1 ratio for 40:1. Sent from my iPhone using Tapatalk Quote
Nick Pilotte Posted June 9, 2020 Report Posted June 9, 2020 Where are you at for shipping considerations? Some of these parts are big enough for local pickup or will require crating. What year or serial number is it so we can check fitment of parts? 1 Quote
testwest Posted June 9, 2020 Report Posted June 9, 2020 Any of the rocker switches available? I am looking for a Radio Master switch (E-T-A type) in black with white letters. Quote
carusoam Posted June 9, 2020 Report Posted June 9, 2020 Welcome aboard, Chrigi. Appears as though something is a bit amiss.... There is a first for everything... Post a bunch of pics when able... Is there a pic of the panel? Is this an O1, O2, O3.... G1000, waas capable... How is the electric fuel pump controller...LO/HI... the LO wears out first... How are the flap control relay electronics... they have a tendency to wear... Got the Porsche 944 clock in there? PP questions only... not necessarily in need of anything yet... Best regards, -a- 1 Quote
Chrigi Posted June 10, 2020 Author Report Posted June 10, 2020 Hi It's a 96' model. Attached some panel pictures. Location is Switzerland. For most parts shipping should be not a big problem, except for the large items. Yes I have still all rocker Switches. And 28V Aircraft. About 1500h TT so maybe the switches are still ok:) Best Regards 1 Quote
Niko182 Posted June 10, 2020 Report Posted June 10, 2020 If someones looking for yokes to upgrade, its probably the time to shine. Quote
MIm20c Posted June 10, 2020 Report Posted June 10, 2020 Hard to see a ‘96 being put down. Hopefully there was a lot more damage than just a prop strike, otherwise it’d be nice to see it in the air again. Your prices look really good. 2 Quote
Ross Taylor Posted June 10, 2020 Report Posted June 10, 2020 Those are nice yokes, @Niko182 - PM sent @Chrigi Quote
Cruiser Posted June 10, 2020 Report Posted June 10, 2020 I would be interested in the rudder trim complete with all hardware. Quote
carusoam Posted June 11, 2020 Report Posted June 11, 2020 Probably some SIC brakes to go with that too... Some really nice chairs, front and back... The air handling system is really nice... Doc John put an O interior in his M20F... Just sharing some ideas of things that have been done around here... Best regards, -a- Quote
Niko182 Posted June 11, 2020 Report Posted June 11, 2020 The seats is a really big one too. On the O's they're fully adjustable. Quote
Skates97 Posted June 11, 2020 Report Posted June 11, 2020 2 hours ago, Niko182 said: The seats is a really big one too. On the O's they're fully adjustable. Will the seats fit a vintage plane? Quote
Niko182 Posted June 11, 2020 Report Posted June 11, 2020 4 minutes ago, Skates97 said: Will the seats fit a vintage plane? Yes Quote
Tahir K Posted June 11, 2020 Report Posted June 11, 2020 Rookie here:if I were to buy and install the VSI and/or the Altimeter and/or the HSI...Would I need some other paperwork or something for any of them? Are they certified to put in my 66' E? Would I need anything else to go with either of those instruments? Quote
jetdriven Posted June 11, 2020 Report Posted June 11, 2020 Anytime you open the static system, you need to do a pressure test. And A&P can do this. 1 Quote
gsxrpilot Posted June 11, 2020 Report Posted June 11, 2020 I'm tempted by the glare shield with integrated compass. 1 Quote
Ross Taylor Posted June 11, 2020 Report Posted June 11, 2020 @Tahir K - keep in mind that any of these electrical instruments, like the HSI, are 28V. They won't work in either your E or ours...at least not without a lot of extra gymnastics. But of course that's not an issue for the vacuum instruments, except for lighting. 1 Quote
