13 minutes ago, Jeff_S said:
Huh?  Que es esso?
Existe esta cosa llamada 'Google'. Intentalo.
Just now, tigers2007 said:
Amelia Earhart found?
Best data on the issue I have seen yet...and Ballard has gotten involved.
That area has been searched quite good and nothing has been found yet. However it is a shallow lagoon That drops off into the abyss so it may be there but it may be very deep. Keep in mind this is 80 years ago
Titanic is over 2 miles deep...of course, it's huge.
I did Google it, right after I replied to the post. So I got the information. It just seems to me that a bit more context might have helped everyone understand who isn't following TIGHAR religiously.  But titillation and obscure information are part of the process, I understand...
Personally, having examined all the photographic evidence that is now on display everywhere, I think people are stretching with this one, but you never know. I do think that Nikumaroro is the likeliest spot for them to have ended up based on other evidence. Perhaps Ballard can help validate. Only problem is, what happens to the intrigue-industry if this is ever proved? What is the next mystery to be solved.
I know...Ancient Aliens!
I am a big fan of cockpit humor. Jeez, the innuendos surrounding the Johnson Bar alone, and we all know how superior manual gear is to electric, is enough to titillate any pilot.
I'm still intrigued by the "inappropriate touching" of two Mooneys on the caravan this year.   The fact that there's pressure to not talk about it makes it even better.
You're omitting the scatalogical origins of "cockpit" itself!
You might want to check this group out, Project Blue Angel as they have found an aircraft that fits Amelia and Fred’s where others have found nothing.
2 hours ago, Sabremech said:
You might want to...
Add to their GoFundMe. OMG, they have raised $4,015 of their $55,000 goal. To think that Bob Ballard has somehow missed this incredible discovery is just mind boggling. That he has already started spending millions on his wild goose chase to Nikumaroro Island is hard to fathom. He needs to be told about this!
  • 2 months later...
From https://www.nytimes.com/2019/10/14/science/amelia-earhart-robert-ballard.html?smid=nytcore:
For two weeks in August, a multimillion-dollar search from air, land and sea sought to solve the 80-year mystery of Amelia Earhart’s disappearance.
Robert Ballard, the ocean explorer famous for locating the wreck of the Titanic, led a team aboard the resesearch vessel Nautilus that discovered two hats in the depths. It found debris from an old shipwreck. It even spotted a soda can. What it did not find was a single piece of the Lockheed Electra airplane flown in 1937 by Amelia Earhart and Fred Noonan, which vanished during their doomed voyage around the world.
Dr. Ballard and his crew don’t consider it a failure. For one thing, he says, they know where the plane isn’t. And in the process, they may have dispensed with one clue that has driven years of speculation, while a team of collaborating archaeologists potentially turned up more hints at the aviator’s fate.
“This plane exists,” Dr. Ballard said. “It’s not the Loch Ness monster, and it’s going to be found.”
2 hours ago, steingar said:
All this excitement over Amelia Earhart and nobody even knows who Jerrie Mock was.
...and don't forget Beryl Markham!
However, Jerrie made it around the world (setting a slew of records while she was at it), somewhat more germane to the topic at hand.  And Jerrie had one less engine and one less navigator than Earhart.
No dissing of that. Frankly, Amelia was waaay overrated as an aviatrix (versus the others) and much of her 'fame' was generated by her marketing husband.
Jerrie, however, flew a modern airplane in 1964 (my E is a '66) . Still a tremendous feat. Beryl, however, did her (East-West) cross Atlantic in 1936. If you read her biographies, you'll also know that with her in the cockpit you would not need cabin heat.
I'll also point out that both ladies died of natural causes in their 80's.
And she accomplished her flight in a Cessna, no less.
