Sabremech Posted December 7, 2018 Report Posted December 7, 2018 I’m finally able to put a few pictures of the SabreCowl Gen2 project out there. This is a complete cowling unlike the previous version that I modified the original cowling. The intent is for this cowling to be an FAA/PMA replacement for the J models and an STC for the C, E, F, and G models. David 18 2 Quote
orionflt Posted December 7, 2018 Report Posted December 7, 2018 looking nice..... when will you be ready for a trial fit on the early mooneys? Brian Quote
steingar Posted December 7, 2018 Report Posted December 7, 2018 Looks spanky. I hope you sell lots. Quote
wcb Posted December 7, 2018 Report Posted December 7, 2018 WOW. That looks GREAT! Just what I was thinking and can't wait to get'R done! Quote
rbridges Posted December 7, 2018 Report Posted December 7, 2018 That looks cool. Got any pics of it on the plane? Quote
Sabremech Posted December 7, 2018 Author Report Posted December 7, 2018 40 minutes ago, rbridges said: That looks cool. Got any pics of it on the plane? My mission today was to test fit the cowling on my C model to see if I had any interference issues that might require a change in the cowling. The cowling is not finished to the point that molds could be made. I do have an issue with my carb air box that I thought might not clear and I was right. I’ll need to come up with another new design carb air box for the C & G models. So, unfortunately no pictures of both halves on my airplane yet. Thanks, David Quote
orionflt Posted December 7, 2018 Report Posted December 7, 2018 1 minute ago, Sabremech said: My mission today was to test fit the cowling on my C model to see if I had any interference issues that might require a change in the cowling. The cowling is not finished to the point that molds could be made. I do have an issue with my carb air box that I thought might not clear and I was right. I’ll need to come up with another new design carb air box for the C & G models. So, unfortunately no pictures of both halves on my airplane yet. Thanks, David was wondering if you were going to have to find/make a new carb heat box for the new cowl design. Brian Quote
rbridges Posted December 7, 2018 Report Posted December 7, 2018 26 minutes ago, Sabremech said: My mission today was to test fit the cowling on my C model to see if I had any interference issues that might require a change in the cowling. The cowling is not finished to the point that molds could be made. I do have an issue with my carb air box that I thought might not clear and I was right. I’ll need to come up with another new design carb air box for the C & G models. So, unfortunately no pictures of both halves on my airplane yet. Thanks, David They had to make a new carb heat box for mine when the 201 cowl was added. 1 Quote
Shadrach Posted December 7, 2018 Report Posted December 7, 2018 Looks really great David. As with your last version, I’d really like to see a profile shot. Your Gen II appears even more streamlined than a stock J cowl but it’s hard to tell ut a profile shot. Quote
INA201 Posted December 7, 2018 Report Posted December 7, 2018 Will the gen2 fit all models J and below or are modifications in order? My thinking is if it is somewhat economical to produce it could revolutionize and modernize a lot of the fleet. That Lopresti cowl is very cost prohibitive. Quote
ArtVandelay Posted December 7, 2018 Report Posted December 7, 2018 Will the gen2 fit all models J and below or are modifications in order? My thinking is if it is somewhat economical to produce it could revolutionize and modernize a lot of the fleet. That Lopresti cowl is very cost prohibitive. Good ?, because some Js don’t have ram air.Js cooling ports are more rectangular, which makes sense since the air intake/filter is rectangular, given the round peg, square hole problem, either you’re going to be blocking the intake or the round holes will be oversized. Quote
INA201 Posted December 7, 2018 Report Posted December 7, 2018 2 minutes ago, teejayevans said: Good ?, because some Js don’t have ram air. Js cooling ports are more rectangular, which makes sense since the air intake/filter is rectangular, given the round peg, square hole problem, either you’re going to be blocking the intake or the round holes will be oversized. Would it make a difference round or square? Ultimately it would be the design that is the most streamlined and produces the highest pressure in the top of the cowl. Just my two cents but I’m not an aeronautical engineeer. Quote
Shadrach Posted December 7, 2018 Report Posted December 7, 2018 8 minutes ago, teejayevans said: Good ?, because some Js don’t have ram air. Js cooling ports are more rectangular, which makes sense since the air intake/filter is rectangular, given the round peg, square hole problem, either you’re going to be blocking the intake or the round holes will be oversized. If you buy Lopresti, don’t you get ram air whether you had it or not? Quote
INA201 Posted December 7, 2018 Report Posted December 7, 2018 9 minutes ago, Shadrach said: If you buy Lopresti, don’t you get ram air whether you had it or not? You do. I recall them saying that they really improved the ram air over the original design. 1 Quote
Sabremech Posted December 7, 2018 Author Report Posted December 7, 2018 22 minutes ago, teejayevans said: Good ?, because some Js don’t have ram air. Js cooling ports are more rectangular, which makes sense since the air intake/filter is rectangular, given the round peg, square hole problem, either you’re going to be blocking the intake or the round holes will be oversized. The shape of the air filter versus the shape of the cylinder cooling inlet really doesn’t matter. My previous version of cowling mod has a square filter with the round inlets and being located inside the pressurized cowling loses very little MP. My cowling will not have provisions for ram air. Cost benefit led me to not install it as part of the new cowling. 51 minutes ago, INA201 said: Will the gen2 fit all models J and below or are modifications in order? My thinking is if it is somewhat economical to produce it could revolutionize and modernize a lot of the fleet. That Lopresti cowl is very cost prohibitive. I do believe the cowling will fit the C through J models with no modifications to the cowling itself, but some modifications to components under the cowling, mostly on the C and G models. Thanks, David Quote
DXB Posted December 7, 2018 Report Posted December 7, 2018 @Sabremech Looks amazing but does this mean you are abandoning pursuit of STC for the gen 1 cowl for the C? Quote
takair Posted December 7, 2018 Report Posted December 7, 2018 9 minutes ago, Sabremech said: The shape of the air filter versus the shape of the cylinder cooling inlet really doesn’t matter. My previous version of cowling mod has a square filter with the round inlets and being located inside the pressurized cowling loses very little MP. My cowling will not have provisions for ram air. Cost benefit led me to not install it as part of the new cowling. I do believe the cowling will fit the C through J models with no modifications to the cowling itself, but some modifications to components under the cowling, mostly on the C and G models. Thanks, David David That is impressive. Would love to update my old E. Are you still doing the basic cowl mod or is this a new direction for the product line? Also, I’m curious....why the STC for the older models, while the J can be purely PMA? It is actually a positive direction for the FAA...I have experienced this on some of my stuff too...but it would be really cool if they would go PMA on the older models too. Quote
Sabremech Posted December 8, 2018 Author Report Posted December 8, 2018 (edited) 1 hour ago, DXB said: @Sabremech Looks amazing but does this mean you are abandoning pursuit of STC for the gen 1 cowl for the C? The Gen 1 cowl would only fit 66 and up C, E, F & G models and left me struggling with a solution for the pre 66 models. I had also been approached to come up with a replacement for the old fiberglass cowlings on the J’s. The issue with the older models and the J cowling request plus the fact that the original cowling mod was very labor intensive lead me to move on to the new Gen 2 complete cowling. The labor hours are reduced quite a bit over the old mod plus I can sculpt the new cowling versus just compromising. So, yes, I won’t be doing any more of the gen 1 modifications. I did gather some very invaluable data such as the size of the cooling air inlets. They need to be 5.75 inch diameter ( which is almost the identical area of the J air inlets) for the 4 cylinder Lycoming engines to get consistent cooling temps across the models and the unique performance each individual engine has. This new cowling is planned to fit all year models of the C through J’s. It should also fit B models but I don’t anticipate there being a real demand from B owners, but I could be surprised. This will replace the Gen 1 modification. 1 hour ago, takair said: David That is impressive. Would love to update my old E. Are you still doing the basic cowl mod or is this a new direction for the product line? Also, I’m curious....why the STC for the older models, while the J can be purely PMA? It is actually a positive direction for the FAA...I have experienced this on some of my stuff too...but it would be really cool if they would go PMA on the older models too. The new cowling should be pretty straight forward as a PMA with the cowling being the only parts changed. The older models will require an STC because I’m modifying the induction system and the cooling system with the baffling. I’d like it to be easier too, but I know that won’t happen. Thanks David Edited December 8, 2018 by Sabremech 1 Quote
M20F-1968 Posted December 8, 2018 Report Posted December 8, 2018 Dave, I might make a suggestion: You might make the air inlets larger which would accommodate at turbonormalizer. The inlet could be then decreased with a fiberglass insert wet mounted so it is properly bonded when customer is not interested in a turbo. With RayJay back in business, there may be turbonormalized options on the horizon. The air intakes on the Lopresti cowling are too small to accommodate a turbo (think Acclaim v. Ovation inlets). Just a thought which might leave options open to give some unexpected utility to the fleet. I like the shape of the cowling. Hope the silhouette is as streamlined. John Breda 4 Quote
Brandontwalker Posted December 8, 2018 Report Posted December 8, 2018 It is difficult to tell from the photos. Is there a provision for cowl flaps? If so, will they connect to the existing linkages on the J?Sent from my iPhone using Tapatalk Quote
