Ooops. This isn't Kansas, Toto!
From AIN:
Wrong-surface Events Remain Nagging Genav Issue
Calling wrong-surface events one of the top five hazards of the National Airspace System, acting FAA administrator Dan Elwell urged government and industry leaders to make the issue a top priority. In remarks at a recent FAA Safety Summit on the issue, Elwell noted that 1,100 such events have occurred nationwide in the last three years alone. Recently, the number of reported wrong-surface events has increased on arrivals, up 47 percent since early 2016, Elwell said. “The risk is particularly great for general aviation, where we’re seeing a much higher rate of incidents,” he said.
Highlighting the summit, NBAA pointed out that general aviation aircraft were involved in 86 percent of the 596 landing/approach wrong-surface events from Fiscal Years 2016 to 2018. Mark Baker, a keynote speaker at the safety summit, cited loss of situation awareness as a root cause of many events and stressed technology can make a significant difference. He backed the promotion of existing and emerging technologies from iPads to head-up displays in combatting wrong-surface events.
“In most of the cases we’re discussing, there weren’t any injuries or damage. That’s good news. But it still tells us that something in the system needs our collective attention,” Elwell said, stressing the need for collaboration.
Read Expanded Version
Link to comment
Share on other sites
I remember coming into Wichita from St. Louis (travelling west) in 2015 at 8000' and when I looked out the pilot side window, I saw four (if not five) airfields with N/S runways facing me.  Fortunately I was IFR and the instruments were pointing to the correct set of runways.  Ok - no real problem, but I could imaging where it might actually happen.
Then, last year, on my way to Oshkosh, Detroit Approach had me come around from the east to line up on 03R following a 737, which I had in sight.  The controller had me confirm (twice) that I was looking at 03R.  Remember that I was on a "visual approach" so they may not have expected me to confirm direction using cockpit needles.  I am not certain if he knew I had the ILS for 03R dialled in on NAV1 and DXO (for the missed approach) on NAV2.  They were worried about both my seeing which of these four runways was mine and when they could see me on the ground and out of their hair.  I landed waaaay long to stay out of the "flare turbulence" of the 737.
Link to comment
You wouldn't be the first, nor would you have been the last.  There are airports all over in Wichita, the air capital of the world.  I can think of 6 without looking at the map, but I know there are a few more.
Link to comment
Very interesting to read the details of airliners landing at the wrong airports.  Sometimes it was a clear case of "heads up and locked", but more often, when all the details come out, I think, "Gee!  That could have been me".
Link to comment
I tried this going into Key West my first time there.  I was focused on the big airport in front of me and tried to set up for NAS Key West.  Tower got me straightened out with no harm or foul called.  Long before GPS but I did have a kickin Loran on board.
Link to comment
If Harrison Ford, Delta, Air Canada and Coninental can be confused enough to land (or line up with) on a taxiway, so can I.
Those runways and taxiways all look similar... :huh:
That may be good company, but I'd prefer not to join the club.
Link to comment
  • 2 weeks later...
I dropped my airplane off at Phoenix Sky Harbor on Sunday for some warranty work on the avionics.   I was very careful to line up where I was supposed to, not wanting to land on one of the many other options.   On final for 7R below.
Edited by EricJ
Link to comment
ohhhhhh multiple choice.  I always go with C.  :D
Using the ILS for the runway you are assigned helps too once the needle is centered.
I've been flying along to one airport on my left and about to pass the center line because I see another airport straight ahead in the distance that I think that is the one I am flying to.  ATC calls out Mooney ..3Q the airport is 9 o'clock 5 miles turn anytime you feel like it.  Oh yeah I was just lining up with the a a center line Mooney ..3Q thanks:huh:
That wasn't the first time and probably will not be the last at least it was corrected before landing.  We like to think we are out there and it's all us but many times it is a team effort.
Link to comment
Taxiway Hotel is about the size of my home strip... Bravo and Fox look like they are both about the same width, and twice the length...
By my count, you could safely have.... 16-24 Mooneys depart simultaneously... one pair for every 3000' of runway and taxiway not adjacent to a building or ramp....
Link to comment
