tfagin Posted April 20, 2018 Report Posted April 20, 2018 Just had our prop and hub overhauled on our 1979 M20J. Prop is a McCauley B2D34C214-A and had about 1000 hrs and 12 years since last overhaul. Cost - $2900. Verbal estimate (not firm by any means) prior to work was about $2K. They did find some corrosion and had some re-plating done. Fair cost, or were we screwed?
Guest Posted April 20, 2018 Report Posted April 20, 2018 Here it’s around 1500-2000 Canadian per blade, so 3-4000 Canadian for your propeller. The US always seems lower due to greater competition. Clarence
ArtVandelay Posted April 20, 2018 Report Posted April 20, 2018 Just had our prop and hub overhauled on our 1979 M20J. Prop is a McCauley B2D34C214-A and had about 1000 hrs and 12 years since last overhaul. Cost - $2900. Verbal estimate (not firm by any means) prior to work was about $2K. They did find some corrosion and had some re-plating done. Fair cost, or were we screwed? Sounds good to me, I thought a reseal and dress would cost that much. Personally I would not want my blades grounded as they are 40 years old, but in good shape.Dud you overhaul because of time, hours, or condition?
jetdriven Posted April 21, 2018 Report Posted April 21, 2018 Reseal and repaint is around 500-600$. I just had it done for the second time. 2
Oldguy Posted April 21, 2018 Report Posted April 21, 2018 IRAN for the prop on my J ran $1200 last month. Disassembled, cleaned, repaired, painted and reassembled. McCauley 2-blade.
bradp Posted April 21, 2018 Report Posted April 21, 2018 Why grind your blades if you don’t need to unless you live in Canada. IRAN. If there’s a blade issue they’ll point it out.
tfagin Posted April 21, 2018 Author Report Posted April 21, 2018 23 hours ago, teejayevans said: Sounds good to me, I thought a reseal and dress would cost that much. Personally I would not want my blades grounded as they are 40 years old, but in good shape. Dud you overhaul because of time, hours, or condition? We did it because of time - 12 years since last OH.
tfagin Posted April 21, 2018 Author Report Posted April 21, 2018 Thanks to all for your input. Feeling a little better!
carusoam Posted April 22, 2018 Report Posted April 22, 2018 @tfagin, Just Wondering.... Why Wait so long before your first post? Wouldn’t it have been better to ask for the advice before having the work done? Are you in Canada? Because OH on a prop for GA/part 91 ops isn’t required on a timed basis. (In the US) and isn’t very popular when not required... You might want to add some detail to your avatar... PP thoughts only, just wondering... Best regards, -a-
Cody Stallings Posted April 22, 2018 Report Posted April 22, 2018 That’s about right for that Propeller. A C14 McCauley is a very time consuming Propeller, as they are threaded an the Ferules have to be removed, reinstalled, restaked an Drilled. Lots of Work in that one process. Also, keep in mind the Blades in a C14 are like finding hens teeth these day. Try an keep the grinding an fileing to a Minimum. 2
Fookz92 Posted April 23, 2018 Report Posted April 23, 2018 East coast Propeller located in Lititz, PA. Talk to Randy. He's a straight shooter. 77J bought in Dec 2017. Propeller with 960hrs SNEW. Never overhauled. Cost $2500 and that includes shipping back to you.
lifendet Posted April 23, 2018 Report Posted April 23, 2018 29 minutes ago, Fookz92 said: East coast Propeller located in Lititz, PA. Talk to Randy. He's a straight shooter. 77J bought in Dec 2017. Propeller with 960hrs SNEW. Never overhauled. Cost $2500 and that includes shipping back to you. Any specific reason for the overhaul? 960 hrs and good shape since new I wouldnt see the need to overhaul.
rbridges Posted April 23, 2018 Report Posted April 23, 2018 i had some work done on my prop and it came out to $1700. I think it was a little high, but I'm sure you see lots of variability depending on the market area and shop.
Fookz92 Posted April 23, 2018 Report Posted April 23, 2018 3 minutes ago, lifendet said: Any specific reason for the overhaul? 960 hrs and good shape since new I wouldnt see the need to overhaul. My IA was pushing for the overhaul more than me. But it is a peace of mind now that it is done. The plane has been dormant for over a decade in a hangar. Was concerned about possible corrosion or rust. The findings during the overhaul?..... none. Just and AD compiled with is all.
LANCECASPER Posted April 23, 2018 Report Posted April 23, 2018 6 hours ago, Fookz92 said: My IA was pushing for the overhaul more than me. But it is a peace of mind now that it is done. The plane has been dormant for over a decade in a hangar. Was concerned about possible corrosion or rust. The findings during the overhaul?..... none. Just and AD compiled with is all. That's why I like IRAN "Inspect and replace as necessary". On an overhaul they are bound to do an overhaul, meaning you lose some material off of the blades, some parts which are just fine have to be replaced, etc. On an inspect and reseal you still get the peace of mind and on a two blade prop for about $600. It took a couple of overhauls on different planes over the years to help me realize that. 3
ArtVandelay Posted April 23, 2018 Report Posted April 23, 2018 That's why I like IRAN "Inspect and replace as necessary". On an overhaul they are bound to do an overhaul, meaning you lose some material off of the blades, some parts which are just fine have to be replaced, etc. On an inspect and reseal you still get the peace of mind and on a two blade prop for about $600. It took a coupe of overhauls on different planes over the years to help me realize that. Does IRAN imply reseal and repaint, or do they need to be requested as well?
jetdriven Posted April 23, 2018 Report Posted April 23, 2018 Generally included but you can can maybe save 100$ not having it painted. But that’s foolish, they’re painted wirh Polane and it’s a very tough paint and that protects the blades from corrosion. So, short answer, yes but always ask.
Bravoman Posted April 24, 2018 Report Posted April 24, 2018 (edited) On 4/20/2018 at 7:49 PM, M20Doc said: Here it’s around 1500-2000 Canadian per blade, so 3-4000 Canadian for your propeller. The US always seems lower due to greater competition. Clarence That’s what capitalism and a free market does for you! Edited April 24, 2018 by Bravoman
Guest Posted April 24, 2018 Report Posted April 24, 2018 9 hours ago, Bravoman said: That’s what capitalism and a free market does for you! Yes, that or the fact that the market is so small there is only enough work for only a few shops. Clarence
Guest Mike261 Posted April 26, 2018 Report Posted April 26, 2018 i had mine done last year at annual. 2600.00 overhauled painted etc. mike
Cardinal767 Posted April 26, 2018 Report Posted April 26, 2018 Byam Propeller in Fort Worth, TX has always done a good job and a fair price for me for decades. I had my prop OVERHAULED with all SB's complied with about two years ago. The prop hadn't been off since 1981. I think the price was around $2k. The prop governor was to the point the cost of repair exceeded buying a new one and they let me know it.
DonMuncy Posted April 26, 2018 Report Posted April 26, 2018 3 hours ago, Cardinal767 said: Byam Propeller in Fort Worth, TX has always done a good job and a fair price for me for decades. I had my prop OVERHAULED with all SB's complied with about two years ago. The prop hadn't been off since 1981. I think the price was around $2k. The prop governor was to the point the cost of repair exceeded buying a new one and they let me know it. I had a very bad experience with Byam, but I don't want to bad-mouth them on the forum, since my experience may not be typical of them. If you want to PM me, I will give you any details you want.
squeaky.stow Posted May 17, 2019 Report Posted May 17, 2019 On 4/23/2018 at 8:54 PM, Bravoman said: That’s what capitalism and a free market does for you! $3-4K Canadian = $2.2 - 3K US at today’s exchange rate. Just about what the OP paid. Sounds like our little free market is working just fine!
jetdriven Posted May 19, 2019 Report Posted May 19, 2019 On 4/22/2018 at 12:28 AM, Cody Stallings said: That’s about right for that Propeller. A C14 McCauley is a very time consuming Propeller, as they are threaded an the Ferules have to be removed, reinstalled, restaked an Drilled. Lots of Work in that one process. Also, keep in mind the Blades in a C14 are like finding hens teeth these day. Try an keep the grinding an fileing to a Minimum. Are the blades for a C214 not being made anymore? Or are they just that expensive? curious.
