jaylw314 Posted March 4, 2018 Report Posted March 4, 2018 This might be on the level of a "duh" suggestion, but when I taxi on the ramp, I have to go slow, sometimes VERY slow, otherwise the nose starts bouncing. Today I tried taxiing across the ramp back to my hangar, but instead of going straight through, I zig-zagged so I was goin about 30 deg across the orientation of the concrete slabs. Sure enough, it significantly reduced the nose bouncing and I could taxi faster. Turned the bouncing into something more like a dutch roll since the mains were hitting the slab edges at different times. Obviously, that's not a great idea on taxiways and such, and at a towered airport, ground might look at you funny, but just thought I'd share that... 2 Quote
EricJ Posted March 5, 2018 Report Posted March 5, 2018 23 minutes ago, jaylw314 said: This might be on the level of a "duh" suggestion, but when I taxi on the ramp, I have to go slow, sometimes VERY slow, otherwise the nose starts bouncing. Today I tried taxiing across the ramp back to my hangar, but instead of going straight through, I zig-zagged so I was goin about 30 deg across the orientation of the concrete slabs. Sure enough, it significantly reduced the nose bouncing and I could taxi faster. Turned the bouncing into something more like a dutch roll since the mains were hitting the slab edges at different times. Obviously, that's not a great idea on taxiways and such, and at a towered airport, ground might look at you funny, but just thought I'd share that... Just tell people you learned in taildraggers. 4 1 Quote
Yooper Rocketman Posted March 5, 2018 Report Posted March 5, 2018 Pull your yoke to full aft (up elevator). With the Rocket’s nose heavy tendency, I never taxi without full aft elevator. It will help with the bouncing too. Tom 3 Quote
jaylw314 Posted March 5, 2018 Author Report Posted March 5, 2018 6 hours ago, Yooper Rocketman said: Pull your yoke to full aft (up elevator). With the Rocket’s nose heavy tendency, I never taxi without full aft elevator. It will help with the bouncing too. Tom I do--after every flight, my hands and biceps are sore from holding the yoke all the way back while taxiing. Quote
RobertGary1 Posted March 5, 2018 Report Posted March 5, 2018 7 hours ago, jaylw314 said: I do--after every flight, my hands and biceps are sore from holding the yoke all the way back while taxiing. I did my private in a taildragger so habits die hard. My instructor would smack you if you didn't have the yoke in your gut during taxi. So I still do it today. -Robert 1 Quote
jaylw314 Posted March 5, 2018 Author Report Posted March 5, 2018 57 minutes ago, RobertGary1 said: I did my private in a taildragger so habits die hard. My instructor would smack you if you didn't have the yoke in your gut during taxi. So I still do it today. -Robert My primary instructor taught me the same way. He'd chant "protect the nosewheel, protect the nosewheel" while we were taxiing all the time Quote
StevenL757 Posted March 5, 2018 Report Posted March 5, 2018 11 hours ago, jaylw314 said: I do--after every flight, my hands and biceps are sore from holding the yoke all the way back while taxiing. But your nose wheel will smile and thank you. Quote
bradp Posted March 5, 2018 Report Posted March 5, 2018 Trim up and then... Grab the yoke with your forearm instead of hand (kind of hug it in the angle of your elbow) - then you can use your weight to hold the yoke back without using the smaller muscles in your hand / wrist. 1 Quote
jaylw314 Posted March 5, 2018 Author Report Posted March 5, 2018 14 minutes ago, bradp said: Trim up and then... Grab the yoke with your forearm instead of hand (kind of hug it in the angle of your elbow) - then you can use your weight to hold the yoke back without using the smaller muscles in your hand / wrist. Does trimming actually help during taxiing? I imagine the horizontal stabilizer travel is much less significant than the elevator travel... I've got a RAM mount on the yoke, so kind of hard to do the forearm thing... Quote
jlunseth Posted March 5, 2018 Report Posted March 5, 2018 I ride horses, so I just go with the flow. Quote
Yooper Rocketman Posted March 6, 2018 Report Posted March 6, 2018 5 hours ago, bradp said: Trim up and then... Grab the yoke with your forearm instead of hand (kind of hug it in the angle of your elbow) - then you can use your weight to hold the yoke back without using the smaller muscles in your hand / wrist. That’s exactly what I do. With the Rocket (maybe a 231 thing) I have a huge weight on the yoke linkage so to pull it full aft it’s some work. Great Point ! I have to wonder what the tire pressure and condition of the donuts are? With an extra 100+ pounds on the nose of my Rocket, I get no bounce unless not pulling the yoke back. Maybe try 49 lbs. on the nose tire? Tom Quote
RobertGary1 Posted March 6, 2018 Report Posted March 6, 2018 20 hours ago, jaylw314 said: Does trimming actually help during taxiing? I imagine the horizontal stabilizer travel is much less significant than the elevator travel... I've got a RAM mount on the yoke, so kind of hard to do the forearm thing... It should. I trim up in Mexico on dirt strips because the increased elevator authority lets you get the nose off much, much faster. Only works on Mooney's, not Cessna's with just a trim tab. -Robert Quote
Hank Posted March 6, 2018 Report Posted March 6, 2018 3 minutes ago, RobertGary1 said: It should. I trim up in Mexico on dirt strips because the increased elevator authority lets you get the nose off much, much faster. Only works on Mooney's, not Cessna's with just a trim tab. -Robert I can see that helping on your takeoff run, but taxiing? Quote
jaylw314 Posted March 6, 2018 Author Report Posted March 6, 2018 31 minutes ago, Hyett6420 said: Ok so if pulling the yoke back does not help, then when were your pucks last changed? Makes a HUGE difference. They are VERY old (more than 15 years?), but still visibly in good shape and in spec (no gap between the collar and plate). Yes, I still plan to get them changed out at some point 1 Quote
RobertGary1 Posted March 6, 2018 Report Posted March 6, 2018 1 hour ago, jaylw314 said: They are VERY old (more than 15 years?), but still visibly in good shape and in spec (no gap between the collar and plate). Yes, I still plan to get them changed out at some point If they measure good and things are tight I wouldn’t replace them just because of age. There are enough legitimate things to spend money on. - Robert Quote
RobertGary1 Posted March 6, 2018 Report Posted March 6, 2018 2 hours ago, Hank said: I can see that helping on your takeoff run, but taxiing? I don’t actually know. -Robert Quote
Yooper Rocketman Posted March 6, 2018 Report Posted March 6, 2018 My main picks had not been changed in 15 years yet always passed inspection. I decided to change them a couple years ago and setting the old stack next to the new stack I was amazed at the height difference! Very noticeable difference in taxi too. My nose pucks get changed every 5-7 years, based on the recommendation of Darwin Conrad, the owner of the Rocket STC. Tom Quote
Hank Posted March 6, 2018 Report Posted March 6, 2018 3 hours ago, Hyett6420 said: I would change them, after all they are what protects your tanks, wings and fueslage on landing (heavy or otherwise) and a little spent here, will save you a lot spent there. you WILL notice the difference. Mine passed the test, too, but I replaced them at the end of 2013. The manufacture date molded into them (installed upside down) I had read as 06/96, but after removal was actually 09/69!! Talk about a world of difference, both taxiing and landing. I swear my landings improved at least 3 points on a 1-to-10 scale. 1 Quote
jaylw314 Posted March 7, 2018 Author Report Posted March 7, 2018 7 hours ago, Hyett6420 said: I would change them, after all they are what protects your tanks, wings and fueslage on landing (heavy or otherwise) and a little spent here, will save you a lot spent there. The main gear pucks are only about 6 years old and in good shape. It's just the nose gear discs that are old. Quote
Hank Posted March 7, 2018 Report Posted March 7, 2018 3 minutes ago, jaylw314 said: The main gear pucks are only about 6 years old and in good shape. It's just the nose gear discs that are old. Old nose gear pucks . . . Extra nose bouncing during taxi . . . Going extra slow on the ramp for steering control. I think I'm seeing a connection. 1 Quote
jaylw314 Posted March 7, 2018 Author Report Posted March 7, 2018 1 minute ago, Hank said: Old nose gear pucks . . . Extra nose bouncing during taxi . . . Going extra slow on the ramp for steering control. I think I'm seeing a connection. Yup Of course, being in the habit of holding the nose wheel off on landings and easing it down is probably not a bad habit to have! 1 Quote
