I will sending a PM to the few guys who I know have an 1975 F model who may have their POH handy. My plane is in the avionics shop and I am having the shop set the V speeds on my Aspen PFD (they were never added when the Aspen was installed). My POH is with the shop and I need to provide them a signed request.
I know what the V speeds are for Vne, Vfe, Vfo, Va, Vx, Vy, Vlo and Vle.
If you know the V speeds for Vno, Vs, Vso could you post them here?
Also, I don't ever think I saw a Vbg (best glide speed) but if there is one in the POH, could you post it as well? I am pretty sure Vref (Vso X 1.3 + half gust) is not provided.
22-1188 knots
vne 174
max maneuvering 117
max struct cruising 152
max gear op 104
max gear extended 104
max flap op 109
red line 174
yellow arc 152-174
green arc 60-152
white arc 56-109
37 minutes ago, Cyril Gibb said:
22-1188 knots
vne 174
max maneuvering 117
max gear op 104
max flap op 109
red line 174
yellow arc 152-174
green arc 60-152
white arc 56-109
Thanks Cyril. Your speeds match the ones I know for mine. I think then Vso = 56, Vs = 60 and Vno = 152. I get that right? Do you see anything for Vbg or Vref (I don't recall them being in the POH).
15 minutes ago, Hank said:
Vref will vary from  flight to flight--it's 1.3 x Vs for your current the weight and configuration, isn't it?
Yes, plus half the gust factor. I don't think it is published for our planes.
Best glide is also weight dependent. Probably in the range of 80-90 kias with the faster end for max gross.  With everything stowed...
Don't trust my aged memory, you would want to look it up...
Edited by carusoam
I have Vso 54kts, Vs 59kts, Vno (top of the green) 152
Stall speeds are at gross
