Random question.  I am 6'2 and fly a M20J.  Overall, the plane is very comfortable for me.  However, I have to sit with the seat in the rearward most position and my legs are still a bit cramped up with knees fairly close to the yoke.  I have never flown right seat in a Mooney, but had a passenger with me on a flight the other day who is approximately my height/size and noticed that he had to pull the right seat up quite a bit further than mine to reach the pedals.  Upon closer inspection, I noted that the right seat pedals are much further forward than the left seat pedals.  Long story short, are the pedals adjustable?  I would love to move the left seat pedals forward by around 2-3 inches such as on the right seat.
I am 6-2 and I have not experienced this on either my E or F model.  I do fly with the seat in the rear most position and when in cruise I even slide ti back further if no one is behind me.  I guess there could be some adjustment made with all the linkages that exist but I have not seen anything mentioned in the manuals.
Wow!   my uneducated guess is,,,,   your plane has rudder peddle extensions, but you didnt know it.
I suspect that is a distinct possibility.  I have never heard of such.  Is the extension something that is readily identifiable from a layman's perspective and easy to remove?
Any chance of a picture?
Brandon,
I am 6'5" and pull my seat up one notch and find it fits my legs comfortably. Really does sound like there are extensions down there. If so, and you remove them, they are a fairly popular item for resale.
John
Will the extensions fit a k , if so I might be interested
I'm not sure if they'll fit a K. My assumption is that they will, but cannot confirm that. Make me an offer if interested. They have to go.
You will have to drill 2 holes in the top of the pedals to mount them.  It might be best to just swap pedals if they are in similiar condition.  They will also change the geometry of the arc as you depress the pedal.  I'm 5'8" and they made things more comfortable for me and got me a comfortable distance from the yoke.
Mooney also offered an option for an extra set of holes at the rear of the seat rail to allow you to get the seat back further.
When I got my plane, I found that I had to use the front-most hole in the seat to be able to use the pedals. (I'm 5' 8"). Since this puts the yoke very close and  I drive my car with the seat way back, I figured I really wanted pedal extensions. After a while, I got used to the configuration, and now I wouldn't go to any expense to change them. Although I almost never have anyone in the rear seat, I suspect a back seat passenger would really appreciate my seat that far forward.
I will be back to my plane at the last of next week and will see if I really need them . I am 5'5 and I have not spent much time in my plane , but i am doing my check ride next wed and should be starting transition training on Thursday and will let you know if I am interested
The extensions were removed this morning and it makes a vast difference.  I can now move the seat into the second position from the back and it is very comfortable.  I'm excited to take it for a ride to try out the new pedal position.  For anyone interested, I snapped a couple of photos of the 3" extensions after they were removed.
Just got off the phone with don Maxwell and he said they should interchange pretty much to all mooneys , he said the peddles are all the same
