1964-M20E Posted May 6, 2015 Report Posted May 6, 2015 For those who are looking for the gascolator gaskets for the older models 2"O.D, x 1/16" thick. You can special order them from Brown Aircraft Supply call them on the phone and tell them you want he GL-30-HD and specify the gasket be made 1/16" thick it is a perfect match for around $8. http://www.brownaircraft.com/product_p/gl-30-hd.htm 1 Quote
MB65E Posted May 6, 2015 Report Posted May 6, 2015 Thanks! This is helpful. It's one of the scariest things I've seen completely botched on at least 3 diffrent aircraft. I've had issues ordering the gaskets in the past. One calls the OEM with the correct p/n of the gasket or Oring, OEM says "they no longer support, that style has been superseded by $$$$$ unit... You might try aircraft spruce"... more than 1 OEM has said this too. So you try Aircraft spruce and get lucky or not. Then you find out the part you were trying to replace was incorrectly installed in the first place. Pretty silly stuff considering fuel is the single most important thing with regards to staying aloft... Cheers, -Matt Quote
1964-M20E Posted May 7, 2015 Author Report Posted May 7, 2015 Last time I ordered from an MSC it was outrageous something like $30 or $50 for the gasket. I felt I should have gotten a pat on the leg and I hope you enjoyed it. Quote
Andy95W Posted May 7, 2015 Report Posted May 7, 2015 In 14 years of Mooney ownership, I've replaced it once. The only fluid pressure on the gascolator is from gravity, and the gasket is made from good material. If it doesn't leak with the proper torque on the bolt, it's okay. 1 Quote
Andy95W Posted May 7, 2015 Report Posted May 7, 2015 Luckily for all of us they are not flimsy cork gaskets like some airplanes use. I guess since I am my own A&P/IA, I'll keep myself safe, and I replace every gasket, o-ring, and filter required on schedule. You found a mechanic you like and trust, and I won't fault that. 1 Quote
1964-M20E Posted May 7, 2015 Author Report Posted May 7, 2015 Luckily for all of us they are not flimsy cork gaskets like some airplanes use. I guess since I am my own A&P/IA, I'll keep myself safe, and I replace every gasket, o-ring, and filter required on schedule. You found a mechanic you like and trust, and I won't fault that. Somewhat where I'm at. My IA says replace it we replace it. I will challenge the decision at times and ask for an explanation as to why and usually give in. Quote
mike_elliott Posted May 7, 2015 Report Posted May 7, 2015 I have never seen the need to replace the garter filter on the vacuum system and about a dozen other miscellaneous gaskets, filters, and o-rings every year either, but they are cheap in the greater scheme of things and my A&P/IA keeps me safe, so so be it. you don't want that garter filter to disintegrate and bust that expensive King HSI for sure Quote
Guest Posted May 7, 2015 Report Posted May 7, 2015 A maintainers lot in life, "Damned if you do, damned if you don't" Clarence Quote
Z00mie Posted December 28, 2016 Report Posted December 28, 2016 (edited) I'm curious 1964 M20E (having never disassembled the strainer), why 1/16" gasket thickness as opposed to the 1/8 as offered by Brown? Edited December 28, 2016 by Z00mie Quote
Mooneymite Posted December 28, 2016 Report Posted December 28, 2016 On 5/7/2015 at 0:24 PM, Andy95W said: I guess since I am my own A&P/IA, I'll keep myself safe, and I replace every gasket, o-ring, and filter required on schedule. Ouch! I just ordered a couple of vacuum filters. These have always been pricey (in my opinion), but they've gone up another 5 bucks! What in the world could be inside these to cost so much? https://www.aircraftspruce.com/catalog/inpages/rapcofilter.php?clickkey=3946 Quote
Yetti Posted December 28, 2016 Report Posted December 28, 2016 https://www.walmart.com/ip/Fram-Fuel-Filter/16817247 Then get some avery labels and print out some Brittian type labels. Quote
1964-M20E Posted December 28, 2016 Author Report Posted December 28, 2016 3 hours ago, Z00mie said: I'm curious 1964 M20E (having never disassembled the strainer), why 1/16" gasket thickness as opposed to the 1/8 as offered by Brown? 1/16" is what is in there I have tried the 1/8" and it does not work. One would think it would but it does not. Quote
testwest Posted July 6, 2020 Report Posted July 6, 2020 I called Lynne today at Brown Aircraft and they still can make this gasket for your Dukes gascolators! The price is still $8.01. Great deal!! 1 Quote
carusoam Posted July 10, 2020 Report Posted July 10, 2020 There may be a message here for Norman @testwest ^^^^ The rest of this thread is a bit aged... Best regards, -a- Quote
testwest Posted July 10, 2020 Report Posted July 10, 2020 Excellent, thanks! I got my gasket from Brown Aircraft already, they responded very quickly. 1 Quote
65C_flier Posted October 7, 2021 Report Posted October 7, 2021 Does anyone know if the Brown Aircraft gasket fits the top (big) o-ring on this gascolator (78J)? I think it is the Shaw-Aero Gerdes circled below. The o-ring appears to be 1/16" with OD 1-15/16" which looks different to the Lasar 940057-001. Quote
65C_flier Posted October 7, 2021 Report Posted October 7, 2021 Ah, nevermind I found the kit https://lasar.com/seal-kits/complete-seal-kit-drawing-for-gerdes-silver-a-1540-gascolator-gerdes-gascolator-seal-kit-complete Quote
carusoam Posted October 7, 2021 Report Posted October 7, 2021 Looks like 65C_flier has become a 78J_flier…. Had me confused for a second… Best regards, -a- Quote
65C_flier Posted October 15, 2021 Report Posted October 15, 2021 I sure have, but I cant figure out how to change my name Still on the topic of the A-1540. Can anyone tell me where the second MS29513-031 (the big o-ring) goes? According to the parts catalogue it is "between gascolator end plug (btm) and gascsolator housing". Mine only has the lock-o-seal washer on the end cap and there doesn't appear to be anywhere for the -031 to go. I'm wondering if I am missing something off of the gascolator housing? My A&P doesn't think so and the gascolator doesn't have any leaks, but it seems pretty strange. Quote
Guest Posted October 16, 2021 Report Posted October 16, 2021 On 10/15/2021 at 5:45 PM, 65C_flier said: I sure have, but I cant figure out how to change my name Still on the topic of the A-1540. Can anyone tell me where the second MS29513-031 (the big o-ring) goes? According to the parts catalogue it is "between gascolator end plug (btm) and gascsolator housing". Mine only has the lock-o-seal washer on the end cap and there doesn't appear to be anywhere for the -031 to go. I'm wondering if I am missing something off of the gascolator housing? My A&P doesn't think so and the gascolator doesn't have any leaks, but it seems pretty strange. One O ring goes at the top, the second goes on the bottom aluminum plate and the stat o seal goes under the large nut. You may have to tap the bottom plate out of the cylindrical aluminum tube. Once disassembled it will make sense. Lubricate the O rings with some engine oil to aid in re-assembly. Don’t over torque the large nut. Clarence Quote
mike20papa Posted October 16, 2021 Report Posted October 16, 2021 Looking at that photo ..I would be asking myself what the heck is going on to cause that dimensioning of tubing wall on the fuel line. Quote
carusoam Posted October 16, 2021 Report Posted October 16, 2021 On 10/15/2021 at 5:45 PM, 65C_flier said: I sure have, but I cant figure out how to change my name Your screen name can be edited… I don’t recommend changing it…. Over time people may actually remember who you are…. Example: DanM20C now flys a super nice M20K…. If he changes his handle, I won’t be able to find him…. If you want to change something important… add a pic to your avatar…. people will recognize your pic pretty easy… Or you could just use your actual name…. This is all kind of difficult to manage using a small screen… Using an iPad for setting updates makes it a breeze! Best regards, -a- Quote
65C_flier Posted October 26, 2021 Report Posted October 26, 2021 On 10/17/2021 at 8:39 AM, M20Doc said: One O ring goes at the top, the second goes on the bottom aluminum plate and the stat o seal goes under the large nut. You may have to tap the bottom plate out of the cylindrical aluminum tube. Once disassembled it will make sense. Lubricate the O rings with some engine oil to aid in re-assembly. Don’t over torque the large nut. Clarence Thanks Clarence. Super helpful as always. We didn't tap it out this time, but we will next time it is inspected. On 10/17/2021 at 9:34 AM, mike20papa said: Looking at that photo ..I would be asking myself what the heck is going on to cause that dimensioning of tubing wall on the fuel line. @mike20papa not sure what you are seeing here? The fuel lines going into gascolator looked OK to us. Quote
