dcjohnst Posted July 18, 2014 Report Posted July 18, 2014 Let's say you're faced with an engine that has had a bad cam shaft and lifter problems (threw a rod once) and now has stainless steel in the oil filter and you're not quite sure what's going on but the engine only has 1400 hours and you're beginning to suspect that it's just a bad engine that chews up cam shafts. It's just one thing after another. Do you rebuild? Swap out? Buy New? Does anyone have any idea about the NET cost of these options for a Lycoming IO-360 on an M20J (i.e. after trading in the existing motor which can probably be rebuilt depending on what's wrong with it, and nobody really knows yet what's wrong?) Quote
Andy95W Posted July 18, 2014 Report Posted July 18, 2014 Get roller tappets and separate magnetos on your reman engine from Lycoming. And a Power Flow exhaust system if you want a bit more power. Quote
Guest Posted July 18, 2014 Report Posted July 18, 2014 I'd look seriously at the AD 2012-19-01 and SB 569 and Lycoming's treatment of the consumer before I'd consider buying a factory engine. Clarence Quote
scottfromiowa Posted July 18, 2014 Report Posted July 18, 2014 Who did the overhaul? Consumer Aviation did a good write-up on some of the top shops. Give it a read. 500+ since overhaul to new limits at Poplar Grove. Doing great so far with oversized cylinders. Knocking on wood as just like watching golf and the announcer says "That is his 15 green in regulation"....the guy pulls it into the lake. My vote is to overhaul at a shop to new limits. A shop that has a good reputation. 1 Quote
ArtVandelay Posted July 18, 2014 Report Posted July 18, 2014 A factory rebuilt is about $30K, and shop overhaul is about $23K. Or go large (if you have a Hartzell prop) and get a rebuilt IO-390 for $32K, and get extra 10HP Quote
Guest Posted July 18, 2014 Report Posted July 18, 2014 Are you sure that it stainless steel in the oil filter? There is really nothing I can think of on the inside made of stainless steel. If its a cam and lifter failure you have to consider repair versus overhaul very carefully, a lot depends on the airframe and its market value. Clarence Quote
ArtVandelay Posted July 18, 2014 Report Posted July 18, 2014 Are you sure that it stainless steel in the oil filter? There is really nothing I can think of on the inside made of stainless steel. If its a cam and lifter failure you have to consider repair versus overhaul very carefully, a lot depends on the airframe and its market value. Clarence That should be easy to check, SS is non-magnetic. Quote
Guest Posted July 18, 2014 Report Posted July 18, 2014 You are correct, but what on the inside of the engine is made of stainless steel? Clarence Quote
John Pleisse Posted July 18, 2014 Report Posted July 18, 2014 Reman or new. Hopefully you could get $4k-$7k for your core. Quote
KSMooniac Posted July 18, 2014 Report Posted July 18, 2014 You are correct, but what on the inside of the engine is made of stainless steel? Clarence Nothing! Â Quote
DaV8or Posted July 18, 2014 Report Posted July 18, 2014 I'd look seriously at the AD 2012-19-01 and SB 569 and Lycoming's treatment of the consumer before I'd consider buying a factory engine. Clarence  Are any of the big, reputable engine shops offering roller lifters yet? That would be a major consideration for me. Quote
Mooneymite Posted July 18, 2014 Report Posted July 18, 2014 A high-time engine? Definitely a factory remain because all the accessories are probably worn out too. However, with a low time engine the question is tougher since there may still be a lot of life in the accessories and it's a shame to dump them. A field overhaul replacing only the out-of-limits parts may make sense. 1400 hours is probably toward the factory remain side, but there may be other factors to consider. Quote
N201MKTurbo Posted July 18, 2014 Report Posted July 18, 2014 Most of the hose fittings and the prop governor line are SS. Nothing else I can think of. If you are getting shiny metal in your oil filter that is non-magnetic it is probably aluminum. Quote
dcjohnst Posted July 18, 2014 Author Report Posted July 18, 2014 Turns out I should have said "alloy steel" in the filter, not "stainless." So it's crankshaft, connecting rod, or counterweight. Â That's a laboratory finding so pretty definitive. The more I learn about replacing an engine the more sickening it gets. Just goes on and on and on... So, maybe gonna spend more time working to get a more specific diagnosis before going to extremes here... Thanks for your help! Quote
jetdriven Posted July 18, 2014 Report Posted July 18, 2014 could that be from cam or lifters? I know the lifters are chilled cast iron but what about the cam? Â Which laboratory did you use? Quote
Guest Posted July 18, 2014 Report Posted July 18, 2014 Pulling two cylinders should allow for complete internal inspection of the engine exposing the camshaft and valve lifters, not a real big job to verify the metal source. Clarence Quote
Alan Fox Posted July 19, 2014 Report Posted July 19, 2014 Poplar Grove , Western Skyways , Signature , I have done business with all three and have had only good experiences....... Quote
cujet Posted July 19, 2014 Report Posted July 19, 2014 Believe it or not, there are capable mechanics that will overhaul your engine, provide a warranty and use the very best parts available.  I've had engines built by BPE (Barret Precision Engines) (Monty and Alan Barret) with fantastic success. These guys really understand the issues with the original designs, know what the best parts are, and provide an incredibly high quality product.  All, for less than a factory engine, assembled with care, quite unlike a factory engine. 1 Quote
dcjohnst Posted July 19, 2014 Author Report Posted July 19, 2014 Clarence, I think you're on the same wavelength as mechanic... Got my fingers crossed hoping for connecting rod. Remote possibilities, but the other possibles are even more remote. Might be something else nobody's thought of. I understand not trusting Lycoming, but Continental's better? We're a captive market and they're murdering us... No wonder nobody wants to fly anymore. Quote
Alan Fox Posted July 19, 2014 Report Posted July 19, 2014 Murdering us ???? look at some of the judgements for failures.....its more like we are murdering them.....the reason they are expensive is because of people suing.......easy math......Someone has to pay..... 3 Quote
rockydoc Posted July 20, 2014 Report Posted July 20, 2014 Make a few bucks and keep life interesting..Buy a different airplane with a decent engine, take everything you want out of your existing airplane and put it in your newly acquired airplane and then part out your existing airplane. Â The sum of the parts is worth a whole lot more than the whole airplane. Â Just saying. Quote
AESpecialists Posted August 14, 2014 Report Posted August 14, 2014  In my (admittedly biased) opinion, I'd send your engine to a reputable overhaul shop (like us) where all of the AD's and SB's will be complied with, and you'll be able to preserve a maintenace history.   A factory reman is just an overhaul with two notable exceptions:  1. You get a brand new $4 blank logbook  2. Your engine is built up out of anonymous servicable parts that could be anywhere from brand new to barely in limits.   We had a fleet customer that went the factory reman route for a few engines. When one of them came to us at TBO,the crank failed the SB 505/530 inspection for corrosion. It was a rude, and rather expensive shock. 1 Quote
