cowboy85 Posted December 13, 2012 Report Posted December 13, 2012 Curiosity is getting the best of me and I cant find much with google to answer this question. Is it possible to convert an early model push-pull control system to a mid 70's style quadrant/lever style? Thanks, Matt
N201MKTurbo Posted December 13, 2012 Report Posted December 13, 2012 I have had both. I currently have the levers and wish I had the push pull controls. The levers eat up a lot of leg room. I think they make the cabin seem more cramped. I think I can adjust the push pull controls more accurately. You can install vernier push pull controls, which makes mixture setting much more accurate. besides, changing them out will be a giant PITA! Just my 2 cents... 1
duke Posted December 14, 2012 Report Posted December 14, 2012 push pull controls are easier for fine adjustments, My 1st plane had levers (warrior) My next (m20f) and current one (m20s) has push pull. Mooney went from push pull to lever and then back to push pull. A wise decision in my opinion.
Hank Posted December 14, 2012 Report Posted December 14, 2012 I like my throttle quadrant . . . Besides, how accurately do I really need to lean my O-360 anyway? You injected guys flying LOP mostly just use the FF number anyway, right? How accurate does that need to be? 2
scottfromiowa Posted December 14, 2012 Report Posted December 14, 2012 Flown both. Push-Pull Vernier preferred by me.
N33GG Posted December 14, 2012 Report Posted December 14, 2012 The best is whatever aircraft I am flying at the time. Get me in the air, and I appreciate push pull or throttle quadrant, high or low wing, fast or slow, single or multi engine, etc. etc. etc. However, I will admit that I have flown some aircraft with push pull controls that were better than others, eg sticky or rough, and I have flown some that were like fine precision controls should be. Same with throttle quadrants. If the controls are good and smooth to allow precision control without a lot of fuss (and distraction from your flying), that is what is most important to me. 1
KSMooniac Posted December 14, 2012 Report Posted December 14, 2012 It is possible with the correct parts and a lot of effort. I'm going to make the opposite conversion sometime in the first half of 2013, and will happily sell you a full throttle quadrant, console, and engine controls if you'd like to convert yours! You'll need a 337 field approval, but if you're using all Mooney parts it should be easy to get.
Piloto Posted December 14, 2012 Report Posted December 14, 2012 The quadrant makes it more difficult for the heavy pilot to move in and out of the seat. Levers are more practical on twins due to the longer cable distance because of more force required to actuate the cable. The bigger the plane the bigger the lever José 1
aerobat95 Posted December 15, 2012 Report Posted December 15, 2012 I like the levers......then and again everything I fly now has levers.....feels more like the big planes :-) 1
carusoam Posted December 15, 2012 Report Posted December 15, 2012 Ray, Are there any more "accurate" version of levers like a vernier adds to the accuracy of a simple push pull knob? Sliding a lever five clicks would be nice... Best regards, -a-
aerobat95 Posted December 15, 2012 Report Posted December 15, 2012 Yea that would be awesome.....the best of both worlds
Hank Posted December 15, 2012 Report Posted December 15, 2012 Ain't no need to go and mess up a perfectly good throttle quadrant! 'Clicks'! 1
chrixxer Posted November 17, 2018 Report Posted November 17, 2018 On 12/14/2012 at 10:17 AM, KSMooniac said: It is possible with the correct parts and a lot of effort. I'm going to make the opposite conversion sometime in the first half of 2013, and will happily sell you a full throttle quadrant, console, and engine controls if you'd like to convert yours! You'll need a 337 field approval, but if you're using all Mooney parts it should be easy to get. Did you end up doing this? Interested...
KSMooniac Posted November 17, 2018 Report Posted November 17, 2018 Did you end up doing this? Interested... I did make the conversion. I'm glad I did it, but it was a metric crapton of effort. I had my salvage plane to scavenge for parts and patterns, which made it possible. It would have been even more difficult if I just had a pile of parts and the parts manual. I didn't log my hours, but I estimate it was in the neighborhood of 150 hours of labor. Much of that in difficult contortions to replace the nose wheel well pieces up by the firewall... Everything between the instrument panel and the floor was swapped. To make it more difficult, the 77 nose wheel opening is larger than the 78+ openings, so I had to make a doubler to shrink the opening slightly to fit the newer nose wheel well parts. Did I mention this was a ton of work? Sent from my LG-US996 using Tapatalk 1
RobertGary1 Posted November 20, 2018 Report Posted November 20, 2018 I love the quadrant. I love being able to adjust throttle, mix, prop without moving my hand from one to the other. Just like you move 2 throttles at the same time in a twin you can move prop and throttle together. I don't go rich on landing because for go around its so trivial to move them all forward at the same time. -Robert
