I saw this on the Mooneyflyer and though pt it was pretty interesting.
Not an unfair price for what you get.
if my plane sat for weeks, I would absolutely consider this.
Saw these on display at MooneyMax a few weeks ago. I think they are a great idea to save your biscuits.
For $700 just buy actual jacks that can be used for more reasons than this isolated case. They last plenty long to fool with all of this
Wonder how long this would delay replacement of pucks?
assuming $2k for new pucks installed, will it be worth $800 (normal price) plus tax/shipment? How often does one replace pucks?
Just a question…
-Don
Just a question…
-Don
I had them replaced during my last annual. According to the logbook they were in service for 12 years. Don Maxwell told me he had seen some 40 years old.
You can get away with using them 40 years.
it’s probably just a little rougher on everything in the suspension chain.
our little planes are very robust.
I replaced mine at about that age. They were minimally compressed. They were also still quite flexible. Where they showed their age was in cold temperatures. I jacked the plane up in February and they took nearly a half hour to fully expand.
I haven’t jacked up the plane in cold temperatures with the new ones for fear of being disappointed that the difference in performance is minimal.
The reason mine were not replaced earlier is because they continued to pass inspection per the maintenance manual. I finally replaced them on general principal because it was embarrassing to have shock discs in service that dated to the Johnson administration. If I’m honest, there’s zero difference in feel from the cockpit.
45yrs old vs never installed/new:
  • Haha 2
I suppose they are “more” prone to cracking at a certain point, but apparently that happens a lot less than they even predicted. I agree, just changed mine and they were 20 years old. About the same compression as yours actually.
if I wasn’t about to paint, I doubt I would have changed them.
FYI, the price of the PucSavers does NOT include the 3 bottle jacks.  They do not include them as they said (at MooneyMAX) that it would cost more to ship than to run to the nearest Harbor Freight and just buy them
I was told by a VERY reputable MSC that old, compressed discs are more likely to contribute to fuel tank leaks due to landing loads not being absorbed as well as new discs.  So considering the cost of a tank reseal, these jacks seem like a good idea.
Or replace the shock discs more often (like every 20 years, not every 45 years).
I've always thought pilot technique might have more to do with tank leaks than gear disks.
I'll have to check the criteria in the manual now.  I haven't looked in years.  I've never seen a reason to replace mine nor have the three mechanics that have worked on my plane the last 20 years.  It doesn't seem stiff when I taxi or land.  I might do it if we were painting the landing gear or had to disassemble it for some reason.
So for $700 you get 3 jack frames but not the bottle jacks.  I see some benefit in these, but I would spend my money on a good set of aircraft jacks first.
How did you determine it was 3 for $700?
Just land softly and you won't have a problem ;)    The pucks are there for those few times one doesn't get it quite right.
