rbmaze Posted March 30 Report Posted March 30 I have a '69 M20E and it currently lacks a panel-mounted clock. An IR checkride is my near future, so I want to get this properly sorted out. I've thought about some options and I'm not sure what to go with. Planning to install this during my annual early this summer. My current panel has dual G5s and I have a GSB 15 for USB power. I am lacking a voltmeter so the AV-20 or other clocks with such a feature are a plus. Also I am very interested in installing an EDM900, so this will negate the voltmeter need, but I am going to hold off until after the annual since it will be my first. Or maybe I should skip the clock for now and just install the engine monitor right away. What I am considering: SC-5 Superclock I like the look and functions, such as indicators for expired timers. Seems to have an intuitive interface. Lower cost. Dislike that the battery only lasts 10 years and is not field serviceable. Dated design. AV-20-S Looks like a great setup, but there are redundant features. I am planning to install an OAT probe on my G5. Is there any sense installing an AV-20 with another probe? I don't really need a backup AI with dual G5s as far as I know. The AoA indicator seems hit or miss in usefulness. Most expensive option, but nice display and interface. CH93 series w/ USB More modern than SC-5, but interface looks bare bones. I already have dual USB ports, but a backup would not be horrible to have. The clock will go under the vacuum gauge on the left. EDM 900 will eventually mount vertically where the white card is to the left of the 530W. At that time I will remove the FS-450 and move the CDI to its position. What would you install here? Quote
PeteMc Posted March 30 Report Posted March 30 My preference is a sweep second hand. Not sure if I have a Mitchell aircraft clock or not, but it sure looks like one of their very basic analog clocks. Problem with the digital is that there are more "digits" to remember. With the sweep hand you just mentally picture the clock and you know where 1 minute is for your Holds, etc. For an actual approach, I used a kitchen timer clipped to my Lapboard during training. Now days I have a timer in ForeFlight. Another advantage of a clock with hands is for fuel balance. I look at the minute hand and if it pointing to the right side of the clock, I should be on the right tank, left should be left tank. So if I was talking to ATC or just contemplating my navel, if I'm unsure if I switched tanks, I just look at the clock. And then there's your Engine Monitor... the cheaper the clock the less reason not to add the EDM900. Talk to the mechanic and let them know you want to add an EDM and as they are looking at the plane, keep that in mind for work that can be deferred. There may be some things that can wait a year that will let you get the EDM. There also may not be and may be some other big ticket items, but if the shop knows the big picture going into the Annual it can only help. 1 Quote
DCarlton Posted March 30 Report Posted March 30 I installed an SC-5 years ago. It's OK. It's a clock. The uptimer starts when I turn on my Alternator. It's a good reminder. Quote
N201MKTurbo Posted March 30 Report Posted March 30 I have a Waltham A-13A-1. I think it is the finest aviation clock ever made. http://walthamclocks.com/a-13a-1.html 1 Quote
DCarlton Posted March 30 Report Posted March 30 On 3/30/2025 at 10:51 PM, N201MKTurbo said: I have a Waltham A13A. I think it is the finest aviation clock ever made. Expand Was that the OEM clock? Fits in your yoke? Their web site is not responding; very slow. Quote
N201MKTurbo Posted March 30 Report Posted March 30 No it is in the panel. When I had my M20F I had an LC2 in the yoke. I had to modify it to fit. Quote
EricJ Posted March 30 Report Posted March 30 Another alternative, although maybe not practical before you need your check ride, is to slide-in upgrade your 530 to an Avidyne 540. This allows a digital time display on the top (mine is configured that way) with seconds that qualifies as the clock. I also have an LC-2 that has proven to be a maintenance hog, enough so that I'm no longer interested in trying to figure out what it's problem du jour might happen to be. The UI is not great on those, anyway. There's a comparatively inexpensive FDS GT50 that might work, https://www.aircraftspruce.com/catalog/inpages/flightdatafc50.php Quote
Ragsf15e Posted March 31 Report Posted March 31 On 3/30/2025 at 10:56 PM, DCarlton said: Was that the OEM clock? Fits in your yoke? Their web site is not responding; very slow. Expand My ‘68F had a Waltham in the yoke. They were great! They even overhauled it for me a couple years ago when it finally quit after 50 years. Quote
Glenn Posted March 31 Report Posted March 31 (edited) On 3/30/2025 at 10:51 PM, N201MKTurbo said: I have a Waltham A-13A-1. I think it is the finest aviation clock ever made. http://walthamclocks.com/a-13a-1.html Expand I agree. If my navigation ever depends on just clock and compass, I would rather have a clock that was not dependent on electricity. Edited March 31 by Glenn left out a word Quote
N201MKTurbo Posted March 31 Report Posted March 31 I bought mine on EBay about 25 years ago. I got a service manual for it and completely disassembled it, cleaned it and put it back together. It was the most complicated mechanical assembly I have ever done. The barrel grease was some strange mil spec that ended up crossing to Aeroshell #6. I needed a tiny dab of it. I used Möbius watch oil for everything else. The specified oil is nowhere to be found. I made a barrel winder out of a tap handle and a piece of copper pipe with a slot in it. It worked great. I got real good at sharpening tiny screwdrivers. Quote
N201MKTurbo Posted Monday at 03:46 AM Report Posted Monday at 03:46 AM On 3/31/2025 at 3:02 AM, bluehighwayflyer said: I have a Waltham on my yoke and it is thing of mechanical beauty that just works. I doubt I would install one ab initio today, however. I had a LC-2 in my previous M20J and what a cheap piece of junk that thing was Pretty much the antithesis of the Waltham. I have an AV-30-C installed and am very fond of it. So much so that just purchased an AV-20-S that I’ll be installing soon. On the panel. Not on the yoke to replace the Waltham. It might cost the most but it does so much more that I think it represents the greatest value I’m going to go ahead and install another OAT probe for it. If I ever install a tailBeaconX in the future I will repurpose the AV-20-S to control it, assuming that will eventually be approved like it currently is for the AV-20-E. Expand You probably had an A-11. It will fit on the yoke. I have enough parts to build one. I’ll have to put it together one of these days. Quote
hais Posted Monday at 07:49 AM Report Posted Monday at 07:49 AM A feature I wanted are two separate buttons. The stopping one just stops it. The reset one starts a new count. Some work in sequence like start-stop-reset-run. Too many clicks while in the hold. One press too many and now you have to click like 7 times to get in the correct mode... 1 Quote
rbmaze Posted Monday at 04:03 PM Author Report Posted Monday at 04:03 PM On 3/30/2025 at 10:08 PM, PeteMc said: My preference is a sweep second hand. Not sure if I have a Mitchell aircraft clock or not, but it sure looks like one of their very basic analog clocks. Expand Interesting info. I can see the benefits of that. I like to run an hour before switching tanks, but your strategy seems useful. On 3/30/2025 at 10:08 PM, PeteMc said: And then there's your Engine Monitor... the cheaper the clock the less reason not to add the EDM900. Talk to the mechanic and let them know you want to add an EDM and as they are looking at the plane, keep that in mind for work that can be deferred. Expand Thanks for this advice. That makes a lot of sense. I already let a potential mechanic know I want to install an EDM900 and was quoted 50 hours. Didn't think of being able to defer work to combine with the install. I'm thinking I'll avoid doing it with the annual since I really have no idea what to expect as far as unknown issues that will pop up when I'm in the shop. Quote
rbmaze Posted Monday at 04:07 PM Author Report Posted Monday at 04:07 PM On 3/30/2025 at 10:48 PM, DCarlton said: I installed an SC-5 years ago. It's OK. It's a clock. The uptimer starts when I turn on my Alternator. It's a good reminder. Expand Do you remember how long the install took? A shop asked me what options I want setup before providing a quote. I'm guessing things like LED dimmer and Engine Time (hobbs meter) are optional wires to connect. Uptimer is a good reminder of your flight time? Quote
DCarlton Posted Monday at 04:10 PM Report Posted Monday at 04:10 PM On 3/31/2025 at 2:38 AM, Ragsf15e said: My ‘68F had a Waltham in the yoke. They were great! They even overhauled it for me a couple years ago when it finally quit after 50 years. Expand I have my original mechanical yoke clock in a box in the garage. I've gotta go find it now and check it out. Quote
Utah20Gflyer Posted Monday at 04:19 PM Report Posted Monday at 04:19 PM I get my time from the clock in the gps (Garmin 355) which has hours and minutes and then use the timer on my Garmin 327 transponder for seconds - timing holds, etc. I used to have a LC2 but found it to be very user unfriendly and got rid of it. So essentially I’m splitting the requirement over two devices. I feel like this works because the GPS is what you use for release times and ATC reporting and they don’t want to hear about seconds. The timer on the transponder is really simple and user friendly. Until someone convinces me otherwise I think this fulfills the legal requirement. 2 Quote
DCarlton Posted Monday at 04:24 PM Report Posted Monday at 04:24 PM On 3/31/2025 at 4:07 PM, rbmaze said: Do you remember how long the install took? A shop asked me what options I want setup before providing a quote. I'm guessing things like LED dimmer and Engine Time (hobbs meter) are optional wires to connect. Uptimer is a good reminder of your flight time? Expand It's been a long time; don't remember how long it took but I could look it up. It's a relatively easy install. Probably best to download the install manual and read it to make sure you're getting what you want. Seems like I remember wiring the backlighting had options (dimmed or not dimmed, etc). I use the timer on the clock for flight times. You can download the install manual on the EI web site. 1 Quote
rbmaze Posted Monday at 04:40 PM Author Report Posted Monday at 04:40 PM On 3/30/2025 at 11:22 PM, EricJ said: Another alternative, although maybe not practical before you need your check ride, is to slide-in upgrade your 530 to an Avidyne 540. Expand Unfortunately this is out of budget for me, but a great option to have a drop-in replacement. My 530W is mostly solid (I do receive some interference sometimes on the comm so I use it as my secondary). I'll probably run it until it dies and see if I can save the funds for a GFC500 one day. On 3/30/2025 at 11:22 PM, EricJ said: There's a comparatively inexpensive FDS GT50 that might work Expand Thanks for the recommendation. I haven't seen this one and it's a lower price point than others. Quote
rbmaze Posted Monday at 04:42 PM Author Report Posted Monday at 04:42 PM On 3/31/2025 at 4:19 PM, Utah20Gflyer said: I get my time from the clock in the gps (Garmin 355) which has hours and minutes and then use the timer on my Garmin 327 transponder for seconds - timing holds, etc. I used to have a LC2 but found it to be very user unfriendly and got rid of it. Expand I have definitely heard of others doing this and perhaps I should get on board and just save the money for my engine monitor. I have a 330 ES so I believe it has a timer. Just not sure how to "vet" a DPE to be sure they will accept this as legal which is one of the hurdles in my head. Quote
rbmaze Posted Monday at 04:55 PM Author Report Posted Monday at 04:55 PM On 3/30/2025 at 10:51 PM, N201MKTurbo said: I have a Waltham A-13A-1. I think it is the finest aviation clock ever made. http://walthamclocks.com/a-13a-1.html Expand Is this the 8-Day Clock? Are these still made? The description is written in the present tense as if it's for sale, but I'm guessing only parts are available. I see one available on ebay. Quote
N201MKTurbo Posted Monday at 04:58 PM Report Posted Monday at 04:58 PM On 3/31/2025 at 4:55 PM, rbmaze said: Is this the 8-Day Clock? Are these still made? The description is written in the present tense as if it's for sale, but I'm guessing only parts are available. I see one available on ebay. Expand Waltham has been out of business since the 70s. A company bought their name and services the A13A and may produce new ones. if you want one of their old clocks you have to buy a used one. Quote
rbmaze Posted Monday at 05:00 PM Author Report Posted Monday at 05:00 PM Wow. Gone since the 70s. Thanks for the info. Quote
Utah20Gflyer Posted Monday at 05:52 PM Report Posted Monday at 05:52 PM On 3/31/2025 at 4:42 PM, rbmaze said: I have definitely heard of others doing this and perhaps I should get on board and just save the money for my engine monitor. I have a 330 ES so I believe it has a timer. Just not sure how to "vet" a DPE to be sure they will accept this as legal which is one of the hurdles in my head. Expand I’m sure the 330 has the same timer as the 327. It really is the best aviation timer I’ve ever used. Try it out next time you get up in the air and see what you think. I’ve tried using the timer on the GPS and my I pad but it just takes too long to get to it and set it up. Also it takes those two devices away from how I want to be using them. The timer on the Transponder is basically stand alone and takes maybe two button touches to get it ready. Starts with one touch, stops with one touch, resets with one touch. It’s perfect! 1 Quote
EricJ Posted Monday at 06:18 PM Report Posted Monday at 06:18 PM On 3/31/2025 at 4:42 PM, rbmaze said: Just not sure how to "vet" a DPE to be sure they will accept this as legal which is one of the hurdles in my head. Expand If the DPE has been identified just ask them. It's not an unusual issue so they may have dealt with it before, or they may just quote the reg. 1 Quote
Pinecone Posted Monday at 08:33 PM Report Posted Monday at 08:33 PM If anyone needs a clock, I have the MidContinent digital with dual USB ports (you have never have too many) that came out of my panel. Quote
