Meshach Posted December 30, 2024 Report Posted December 30, 2024 After a few years of hand flying, I’d like to see if I can get the PC to work. But I’m missing the piece that goes in the yoke. The rest of the system seems intact. IIUC, without the valve, the system cannot work. Does anyone know where I could get that little piece/button that goes in the yoke. 1970 F.
takair Posted December 30, 2024 Report Posted December 30, 2024 Check eBay, perhaps for an entire yoke. Perhaps @Alan Fox has one. Alternately, you can retrofit with electric solenoid, but that is obviously more work.
JoeM Posted December 31, 2024 Report Posted December 31, 2024 I prefer an on/off toggle switch so I used this one https://www.aircraftspruce.com/catalog/elpages/togglevalve11-12168.php 2
AJ88V Posted December 31, 2024 Report Posted December 31, 2024 I like the button on the yoke. Becomes very automatic to press it while turning the plane and then releasing it to let the wing leveler reengage. Recommend looking for a Mooney yoke on eBay.
Andy95W Posted December 31, 2024 Report Posted December 31, 2024 5 hours ago, JoeM said: I prefer an on/off toggle switch so I used this one https://www.aircraftspruce.com/catalog/elpages/togglevalve11-12168.php This is the switch I installed in series with the yoke pushbutton in my last Mooney, a 1967 M20C. Having the on/off toggle and a functioning yoke switch is really the best of both worlds. Turn the toggle on and the PC works normally. Turn it off and the airplane flies normally.
M20E for me Posted January 2 Report Posted January 2 On 12/31/2024 at 8:33 AM, JoeM said: I prefer an on/off toggle switch so I used this one https://www.aircraftspruce.com/catalog/elpages/togglevalve11-12168.php I used this toggle switch as well. I like it better than the old knob. It’s a switch on the dash and now I have a ppt on the yoke. 2
DCarlton Posted January 2 Report Posted January 2 https://www.mcmaster.com/62475K14/ Another possibility. Not an aircraft part. 1
Echo Posted January 3 Report Posted January 3 (edited) I have an actual Brittain PC disconnect valve I will sell. PM if interested and I can share photos. Ths is for panel NOT yoke button. It is a push pull. Edited January 3 by Echo
Meshach Posted January 3 Author Report Posted January 3 I like the idea of a switch on the panel. I assume that’s a minor alteration that my A/P should have no problem doing?
Igor_U Posted January 3 Report Posted January 3 7 hours ago, Echo said: I have an actual Brittain PC disconnect valve I will sell. PM if interested and I can share photos. Ths is for panel NOT yoke button. It is a push pull. I am not looking to buy but would be interesting to see the photo. What year of Mooney would have this on the panel?
Echo Posted January 4 Report Posted January 4 Brittain made and sold them as well as an electric solenoid to cancel p.c. An vintage Mooney with a Brittain system could have them. Most came OEM with yoke push button disconnect. I prefer to NOT hold the button while disengaging p.c. and wanted a push to talk button integrated in yoke so push pull was installed. The line for disconnect was pulled back through yoke and shaft. Drill a hole in panel. (I already had a hole where ram air cable was) I removed cable as I have a J cowl with no ram air on plane. Screw in push pull manual dump and attach line.
Hank Posted January 4 Report Posted January 4 Or keep the yoke button, and mount a Push-to-Talk like this . . . .
hammdo Posted January 4 Report Posted January 4 My old B had the push/pull switch vs yoke button… I changed yokes out on my C and may still have the button. Let me know and I’ll look for it… is for older style yokes. -Don
