Danb Posted May 22 Report Posted May 22 Recently got a leak which seemed huge, after washing down engine it apparently was a valve cover gasket which I tightened but it didn’t help. Any pointers on replacing the gaskets engine TSIO 550 G Thanks Dan Quote
Fly Boomer Posted May 22 Report Posted May 22 43 minutes ago, Danb said: valve cover gasket which I tightened but it didn’t help http://www.tcmlink.com/pdf2/SIL21-04B.pdf Quote
LANCECASPER Posted May 23 Report Posted May 23 1 hour ago, Danb said: Recently got a leak which seemed huge, after washing down engine it apparently was a valve cover gasket which I tightened but it didn’t help. Any pointers on replacing the gaskets engine TSIO 550 G Thanks Dan Buy the Real Gasket brand - they are better and a lot less expensive. https://realgaskets.com/product-category/aviation/aviation-opposed/continental/page/2/ https://www.aircraftspruce.com/catalog/eppages/siliconecalvecover_08-01319.php Quote
mike_elliott Posted May 23 Report Posted May 23 Don't over tighten the rocker cover screws, and make sure you use new star lock washers to keep them doing their job. I wouldn't suggest going against The guidance of not using loctite. Did I mention I never had a screw come loose that had loctite on it? 1 Quote
PT20J Posted May 23 Report Posted May 23 @Gee Bee Aeroproducts Guy makes silicone gaskets with a reinforcing layer sandwiched in between that stabilizes the silicone so that it doesn’t squish around so much when tightened. They have worked great on my IO-360. 3 Quote
M20F Posted May 25 Report Posted May 25 On 5/22/2024 at 8:23 PM, mike_elliott said: Don't over tighten the rocker cover screws What setting on the air hammer do you recommend? 3 Quote
MB65E Posted May 25 Report Posted May 25 4 hours ago, M20F said: What setting on the air hammer do you recommend? Sure seems that way. Many are over torqued. 26in lbs on silicone. 50in lbs on cork. -Matt 1 Quote
Gee Bee Aeroproducts Posted May 28 Report Posted May 28 Install dry silicone with fiberglass 25/27 Inch pounds the reinforced material cost five times more than non . ams3320.093 2 Quote
Ali Posted May 30 Report Posted May 30 On 5/23/2024 at 4:20 AM, Danb said: Recently got a leak which seemed huge, after washing down engine it apparently was a valve cover gasket which I tightened but it didn’t help. Any pointers on replacing the gaskets engine TSIO 550 G Thanks Dan Hello, Here's a brief guide to replacing the valve cover gasket on a TSIO-550-G engine: Safety First: Disconnect the battery. Ensure the engine is cool before starting. Remove Components: Remove any components obstructing access to the valve cover (air filter, hoses, etc.). Remove Valve Cover: Unscrew the bolts holding the valve cover in place. Carefully remove the valve cover to avoid damaging the gasket surface. Clean Surfaces: Clean the valve cover and the engine surface where the gasket sits, removing old gasket material and oil residue. Install New Gasket: Place the new gasket onto the valve cover or the engine, ensuring it is properly aligned. Reinstall Valve Cover: Position the valve cover back onto the engine. Tighten the bolts in a crisscross pattern to the manufacturer’s torque specifications I hope this will help you, Thank you Quote
Pinecone Posted May 30 Report Posted May 30 Any ideas of why it would still leak? Tried 5 gaskets, both standard and silicone. Sanded the rocker cover to make sure the mating surface is flat. Swapped covers. Chased threads to make sure the bolt was going in fully. Still leaks. Quote
Danb Posted May 30 Author Report Posted May 30 2 hours ago, Ali said: Hello, Here's a brief guide to replacing the valve cover gasket on a TSIO-550-G engine: Safety First: Disconnect the battery. Ensure the engine is cool before starting. Remove Components: Remove any components obstructing access to the valve cover (air filter, hoses, etc.). Remove Valve Cover: Unscrew the bolts holding the valve cover in place. Carefully remove the valve cover to avoid damaging the gasket surface. Clean Surfaces: Clean the valve cover and the engine surface where the gasket sits, removing old gasket material and oil residue. Install New Gasket: Place the new gasket onto the valve cover or the engine, ensuring it is properly aligned. Reinstall Valve Cover: Position the valve cover back onto the engine. Tighten the bolts in a crisscross pattern to the manufacturer’s torque specifications I hope this will help you, Thank you Thanks Ali I basically did as you suggested, after installing I ran it up retorqued per instructions ran it up no leak, let it cool overnight checked torque ran it etc. No leak yet, waiting for Biden to leave then fly and recheck. D Quote
Danb Posted May 30 Author Report Posted May 30 1 hour ago, Pinecone said: Any ideas of why it would still leak? Tried 5 gaskets, both standard and silicone. Sanded the rocker cover to make sure the mating surface is flat. Swapped covers. Chased threads to make sure the bolt was going in fully. Still leaks. T, I’m sure you did but make sure covers are flat and not bent even a tiny bit, now my leak covered an immense amount of area. I used realgasket if it didn’t work Id try Guys or cork, good luck, I guess your ready to play with the new rocking panel D Quote
Pinecone Posted May 30 Report Posted May 30 A&P sanded the cover flat. Then swapped the cover with another one on the engine and the leak stayed on the same cylinder. Current gasket is a Guy's Quote
MikeOH Posted May 31 Report Posted May 31 Long shot, but any chance there's a hairline crack on the mating surface of the casting? Clean and examine with an eye lupe? Quote
Pinecone Posted May 31 Report Posted May 31 6 hours ago, MikeOH said: Long shot, but any chance there's a hairline crack on the mating surface of the casting? Clean and examine with an eye lupe? That is what I am afraid of. Quote
Mark89114 Posted June 7 Report Posted June 7 I think they are just super duper fussy for some reason....hardly a real answer. Mine leak sometimes, using the real gasket brand, following the instructions, etc. Sometimes they leak and sometimes they don't. The ones that leak, I just tighten up the screws a bit and revisit, if that doesn't work, remove and clean them. Sometimes it works, sometimes it doesn't. I haven't found any rhyme or reason. Mine have been trouble free the last year or so but this posting will probably cause them to start leaking again. 1 Quote
Gee Bee Aeroproducts Posted July 18 Report Posted July 18 On 6/7/2024 at 9:09 AM, Mark89114 said: I think they are just super duper fussy for some reason....hardly a real answer. Mine leak sometimes, using the real gasket brand, following the instructions, etc. Sometimes they leak and sometimes they don't. The ones that leak, I just tighten up the screws a bit and revisit, if that doesn't work, remove and clean them. Sometimes it works, sometimes it doesn't. I haven't found any rhyme or reason. Mine have been trouble free the last year or so but this posting will probably cause them to start leaking again. No fiberglass, prone to sponge faa/ pma allows leaks Quote
PT20J Posted July 18 Report Posted July 18 1 hour ago, Gee Bee Aeroproducts said: No fiberglass, prone to sponge faa/ pma allows leaks I had to replace a Lycoming valve cover that had a pinhole leak so I went ahead and replaced all the gaskets with yours and they work great. 1 Quote
Gee Bee Aeroproducts Posted July 18 Report Posted July 18 (edited) AMS3320 we stock several colors and three different thickness For fuel / oil AMS3325 Flurosilicone We base our products on quality, not cost Edited July 18 by Gee Bee Aeroproducts 1 Quote
