PharmDpilot Posted April 8, 2024 Report Posted April 8, 2024 Does anyone know of a direct plug-in LED replacement for position lights / strobes / beacon for a 1965 M20C with 201 wingtip mods? Quote
Yetti Posted April 8, 2024 Report Posted April 8, 2024 The AeroLEDs were quick to install and replaced the strobe/position on my 75 F. Direct screw match. 2 Quote
LANCECASPER Posted April 8, 2024 Report Posted April 8, 2024 59 minutes ago, PharmDpilot said: Does anyone know of a direct plug-in LED replacement for position lights / strobes / beacon for a 1965 M20C with 201 wingtip mods? Attach a picture and it'll be easier to tell you which ones to buy. Quote
PharmDpilot Posted April 24, 2024 Author Report Posted April 24, 2024 On 4/7/2024 at 9:00 PM, LANCECASPER said: Attach a picture and it'll be easier to tell you which ones to buy. Here are my wingtips. I appreciate your help. Quote
LANCECASPER Posted April 24, 2024 Report Posted April 24, 2024 1 hour ago, PharmDpilot said: Here are my wingtips. I appreciate your help. It looks like the Orion 650E is what you need, a 12v red and a 12v green. https://www.aircraftspruce.com/catalog/elpages/orion650eseries.php?clickkey=22748 A Mooneyspacer @OSUAV8TER is a Whelen dealer - he should be able to help. 1 Quote
OSUAV8TER Posted April 24, 2024 Report Posted April 24, 2024 @PharmDpilot I am a Whelen Aerospace Technologies authorized reseller and I carry the wingtip nav/strobe LED lights in my inventory. I can prepare a custom quote for you based on your needs and advise on installation. www.gallagheraviationllc.com <- website gallagheraviationllc@gmail.com <- email me 513-401-6495<- call/text/mms Quote
PeteMc Posted April 24, 2024 Report Posted April 24, 2024 55 minutes ago, OSUAV8TER said: I carry the wingtip nav/strobe LED lights in my inventory. FINALLY got my LED Recognition lights in!! I just had the (new to me) shop do it when I went in for Annual. Haven't seen them yet, plane's done except for a couple of things they're waiting on to come back like the O2 tank. Is your plane done yet? Quote
OSUAV8TER Posted April 24, 2024 Report Posted April 24, 2024 @PeteMc We are close. Maybe another week until it is done? Then it goes to paint so I may get to fly it for a week or two! How do you like your interior? Quote
McMooney Posted April 24, 2024 Report Posted April 24, 2024 I'm eventually going to get the 650/660's for my birdy but in the interim, i just replaced the bulbs with leds from spruce as for the beacon, can't speak highly enough about these Quote
PeteMc Posted April 25, 2024 Report Posted April 25, 2024 2 hours ago, OSUAV8TER said: How do you like your interior? Loving it, or at least for the flights, then home and one other short flight before my time expired for the Annual. It is a bit thicker on the sides, so a little more snug. But I think that's more "different" than it really is that we lost much space. Quote
Immelman Posted April 25, 2024 Report Posted April 25, 2024 (edited) OP please ignore this if it is obvious to you but I feel it should be mentioned: The traditional style strobe lights like in your photos typically have a power supply that takes aircraft DC voltage, charges some sort of capacitor, and then creates the flash with a rapid discharge. So any strobe replacement with LEDs is not merely a remove and replace, you'll need to remove that power supply unit as well (mine were mounted to wing inspection panels) and run DC power straight to the new lighting. A weight savings! Edited April 25, 2024 by Immelman 1 Quote
Ragsf15e Posted April 25, 2024 Report Posted April 25, 2024 14 hours ago, PeteMc said: Loving it, or at least for the flights, then home and one other short flight before my time expired for the Annual. It is a bit thicker on the sides, so a little more snug. But I think that's more "different" than it really is that we lost much space. (Sorry to thread divert) - Did you end up with a new trim switch or repair? Quote
PeteMc Posted April 25, 2024 Report Posted April 25, 2024 2 hours ago, Ragsf15e said: Did you end up with a new trim switch or repair? New. From my tech life I know that some used stuff works forever, others fail in a short period and you'll never really know. Talked it over with my old mechanic and he concurred that he's changed some and never had a problem, others the same micro switch or one of the others would fail on the used switch and the owner is then spending the same amount that the switch would have cost AND double the installation time. I'm keeping the other one and since there's no rush, I'll see if it is fixable and then I'll sell it. (Have to see what the process is, if any, for a repair certification.) 1 Quote
