kerry Posted January 9, 2024 Report Posted January 9, 2024 I was curious if anyone knows why a TFR would be issued in restricted airspace. There's a TFR approximately 35 miles East of the BTY VOR which is in the middle of R-4808 N. Seems strange since no one can fly in this area anyway. Quote
Hank Posted January 9, 2024 Report Posted January 9, 2024 Because the rules say there's supposed to be a TFR, and career bureaucrats are well known to follow rules over common sense and logic. 1 Quote
MB65E Posted January 9, 2024 Report Posted January 9, 2024 It’s a Device Assembly Facility used for assembling atomic weapons. I thought it was strange too. I saw the TFR pop up a 2-3 weeks ago. The building is massive. Google maps has some neat pictures. -Matt Quote
Ragsf15e Posted January 9, 2024 Report Posted January 9, 2024 1 hour ago, kerry said: I was curious if anyone knows why a TFR would be issued in restricted airspace. There's a TFR approximately 35 miles East of the BTY VOR which is in the middle of R-4808 N. Seems strange since no one can fly in this area anyway. Wouldn’t surprise me if that facility (Yucca mtn storage, old nuclear test area, etc) was DOE. They are doing something that needs a tfr and they did it to keep the Air Force out (who usually goes right through there). 3 Quote
EricJ Posted January 9, 2024 Report Posted January 9, 2024 +1 that it keeps the people who normally use that airspace (i.e., the people for whom it is restricted to), from going in the TFR area. Restricted Areas aren't prohibited to everybody, they're restricted to the people who are allowed to use it. A TFR may keep those folks out, too. 2 Quote
Ragsf15e Posted January 9, 2024 Report Posted January 9, 2024 And then there’s our own ability to go right through there… the tfr would likely prevent that as well. Remember that we can get permission to cross R areas, and in some places it’s pretty easy. I’m not saying that GA airplanes are normally cleared through this one, but I have been cleared through some Nellis areas on the weekend when nobody used them. 2 Quote
201er Posted January 9, 2024 Report Posted January 9, 2024 39 minutes ago, Ragsf15e said: And then there’s our own ability to go right through there… the tfr would likely prevent that as well. Remember that we can get permission to cross R areas, and in some places it’s pretty easy. I’m not saying that GA airplanes are normally cleared through this one, but I have been cleared through some Nellis areas on the weekend when nobody used them. You can get cleared through TFRs too. Same deal, just squawking and talking. 3 Quote
flyboy0681 Posted January 9, 2024 Report Posted January 9, 2024 12 hours ago, MB65E said: It’s a Device Assembly Facility used for assembling atomic weapons. I thought it was strange too. I saw the TFR pop up a 2-3 weeks ago. The building is massive. Google maps has some neat pictures. -Matt Hmm, I wonder what this wire does.. Quote
PT20J Posted January 9, 2024 Report Posted January 9, 2024 It's listed on tfr.faa.gov as "Temporary flight restrictions for Special Security Reasons." Quote
Fly Boomer Posted January 9, 2024 Report Posted January 9, 2024 13 hours ago, kerry said: I was curious if anyone knows why a TFR would be issued in restricted airspace. There's a TFR approximately 35 miles East of the BTY VOR which is in the middle of R-4808 N. Seems strange since no one can fly in this area anyway. I thought you could fly in these with permission from using agency or controlling agency. 1 Quote
Ragsf15e Posted January 9, 2024 Report Posted January 9, 2024 1 hour ago, 201er said: You can get cleared through TFRs too. Same deal, just squawking and talking. True, I guess I was just thinking it might change the approval authority atc would need to clear you through. Quote
MattCW Posted January 9, 2024 Report Posted January 9, 2024 2 hours ago, 201er said: You can get cleared through TFRs too. Same deal, just squawking and talking. Yep, the actual instructions for this one are: ALL ACFT ENTERING OR EXITING THE TFR MUST BE ON AN ACT IFR OR VFR FLT PLAN WITH A DISCRETE CODE ASSIGNED BY AN AIR TFC CTL (ATC) FAC. ACFT MUST BE SQUAWKING THE DISCRETE CODE PRIOR TO DEP AND AT ALL TIMES WHILE IN THE TFR. ALL ACFT ENTERING OR EXITING THE TFR MUST REMAIN IN TWO - WAY RADIO COM WITH ATC. It seems pointless. It's the same as the one that pops up around Mayport NAS except this one requires a flight plan. Quote
kerry Posted January 9, 2024 Author Report Posted January 9, 2024 This airspace is continuously hot. Groom Lake area 51. Quote
201er Posted January 9, 2024 Report Posted January 9, 2024 46 minutes ago, kerry said: This airspace is continuously hot. Groom Lake area 51. Then maybe it's to make an airspace violation double jeopardy. Fly over this and then you're busted for violation of both restricted airspace and tfr! Quote
whiskytango Posted January 9, 2024 Report Posted January 9, 2024 2 hours ago, 201er said: Then maybe it's to make an airspace violation double jeopardy. Fly over this and then you're busted for violation of both restricted airspace and tfr! The FAA will put you on Double Secret Probation. 1 Quote
Ragsf15e Posted January 9, 2024 Report Posted January 9, 2024 3 hours ago, MattCW said: Yep, the actual instructions for this one are: ALL ACFT ENTERING OR EXITING THE TFR MUST BE ON AN ACT IFR OR VFR FLT PLAN WITH A DISCRETE CODE ASSIGNED BY AN AIR TFC CTL (ATC) FAC. ACFT MUST BE SQUAWKING THE DISCRETE CODE PRIOR TO DEP AND AT ALL TIMES WHILE IN THE TFR. ALL ACFT ENTERING OR EXITING THE TFR MUST REMAIN IN TWO - WAY RADIO COM WITH ATC. It seems pointless. It's the same as the one that pops up around Mayport NAS except this one requires a flight plan. Yeah it’s just their boilerplate tfr verbiage. They don’t tell you what approval authority atc has to go through to clear you through. Im guessing if you ask to fly through even with a squawk and under atc control, they’ll deny entry. Quote
201er Posted January 9, 2024 Report Posted January 9, 2024 33 minutes ago, Ragsf15e said: Yeah it’s just their boilerplate tfr verbiage. They don’t tell you what approval authority atc has to go through to clear you through. Im guessing if you ask to fly through even with a squawk and under atc control, they’ll deny entry. Well apparently Blade claims to offer charters and helicopter flights to Area 51. Found this via google: https://www.blade.com/airports/homey-area-51 1 Quote
DCarlton Posted January 10, 2024 Report Posted January 10, 2024 10 hours ago, PT20J said: It's listed on tfr.faa.gov as "Temporary flight restrictions for Special Security Reasons." Seems like I remember one of these in Hobbs NM this past year. I’ve wondered if it’s associated with a movement of some sort. Stuff coming and going. Best to stay away. Too many armored vehicles and people with loaded weapons… Quote
