zehutiman Posted October 16, 2023 Report Posted October 16, 2023 I’ve been flying my airplane (Missile) with a new GI275 for about 1 1/2 months and during the last couple flights, the #4 cylinder EGT has been running about 130 deg hotter than the rest. The CHT is a bit higher, too. I can’t find an actual EGT limitation listed for my IO550A, but obviously the 130 deg difference shows something isn’t right. My research shows that if it was a valve problem, the CHT would probably be lower? Any thoughts? PS: during descent, the EGT increased quite a bit — high 1500’s — so I increased the mixture to keep the temps down. I’ve never paid a lot of attention to the EGT’s and CHT’s during descent, but I’m reminded of Mike Bush’s comments that he leaves the mixture alone after he’s finished leaning at cruise, so it stays the same all the way to landing. Quote
N201MKTurbo Posted October 16, 2023 Report Posted October 16, 2023 Three things that can cause that (that I know of). 1. That cylinder is running leaner than the others. Do a lean test and see if that cylinder peaks at the same FF as the rest. 2. One plug isn't firing in that cylinder. Do an in flight mag check and see what the EGTs are on the individual mags. 3. The sensor is bad. Swap the sensors between cylinders. or at least remove and inspect the sensors. 3 2 Quote
EricJ Posted October 16, 2023 Report Posted October 16, 2023 On 10/16/2023 at 12:01 PM, zehutiman said: I’ve never paid a lot of attention to the EGT’s and CHT’s during descent, but I’m reminded of Mike Bush’s comments that he leaves the mixture alone after he’s finished leaning at cruise, so it stays the same all the way to landing. Expand Remember that Mike Busch flies a turbocharged airplane, and for a normally aspirated airplane you should be adjusting the mixture as you descend or it'll be going lean, especially if you maintain power during the descent. Just keeping an eye on the EGTs during descent will let you know what's going on. 1 1 Quote
zehutiman Posted October 16, 2023 Author Report Posted October 16, 2023 On 10/16/2023 at 1:05 PM, N201MKTurbo said: Three things that can cause that (that I know of). 1. That cylinder is running leaner than the others. Do a lean test and see if that cylinder peaks at the same FF as the rest. 2. One plug isn't firing in that cylinder. Do an in flight mag check and see what the EGTs are on the individual mags. 3. The sensor is bad. Swap the sensors between cylinders. or at least remove and inspect the sensors. Expand I tried number 2. yesterday, but didn’t notice a change. However, I wasn’t sure how long to let the engine run on each mag, so i only ran it that way for about 10 seconds — not much time for the temp to change. How long should I run the engine on each mag? Quote
Marc_B Posted October 16, 2023 Report Posted October 16, 2023 @zehutiman Savvy has several flight profiles they recommend. Every time I do this they always want even more time to see trends. Short answer, at least 10 engine monitor cycles (I run mine for at least 30 seconds). https://resources.savvyaviation.com/wp-content/uploads/savvy_pdf/SavvyAnalysisFlightTestProfiles.pdf 2 Quote
Ragsf15e Posted October 16, 2023 Report Posted October 16, 2023 On 10/16/2023 at 3:45 PM, zehutiman said: I tried number 2. yesterday, but didn’t notice a change. However, I wasn’t sure how long to let the engine run on each mag, so i only ran it that way for about 10 seconds — not much time for the temp to change. How long should I run the engine on each mag? Expand It will change quickly. If a plug wasn’t firing you’d also feel roughness. It would likely be pretty obvious. Try #1, maybe you have a partially clogged injector. 1 1 Quote
N201MKTurbo Posted October 16, 2023 Report Posted October 16, 2023 On 10/16/2023 at 3:45 PM, zehutiman said: I tried number 2. yesterday, but didn’t notice a change. However, I wasn’t sure how long to let the engine run on each mag, so i only ran it that way for about 10 seconds — not much time for the temp to change. How long should I run the engine on each mag? Expand In the event of a mag failure the engine is expected to run on one mag till the tanks are dry. But if a plug wasn't firing, you would have felt it. 1 Quote
zehutiman Posted October 17, 2023 Author Report Posted October 17, 2023 On 10/16/2023 at 4:26 PM, Marc_B said: @zehutiman Savvy has several flight profiles they recommend. Every time I do this they always want even more time to see trends. Short answer, at least 10 engine monitor cycles (I run mine for at least 30 seconds). https://resources.savvyaviation.com/wp-content/uploads/savvy_pdf/SavvyAnalysisFlightTestProfiles.pdf Expand I’ll try that tomorrow. Quote
jlunseth Posted October 21, 2023 Report Posted October 21, 2023 Just asking to verify. Is this behavior a change from past observed temps, or is it possible it has always been going on and you just noticed it? 3 Quote
zehutiman Posted October 31, 2023 Author Report Posted October 31, 2023 On 10/21/2023 at 1:18 PM, jlunseth said: Just asking to verify. Is this behavior a change from past observed temps, or is it possible it has always been going on and you just noticed it? Expand No, it’s definitely new behavior. Quote
Shadrach Posted November 1, 2023 Report Posted November 1, 2023 I’m thinking it’s a sensor issue given the mags checked out in flight mag. Your engine has a CR of 8.5:1. 1573° is outside of the norm for which an engine unless there is an ignition problem. Would have been interesting to know the single mag EGT on the cylinder. I expect the reading was in excess of 1700° Would be highly suspect. You could try swapping probes, but removing exhaust probes can sometimes damage them. . I would replace the probe. It’s a low risk investment, and the most likely cause of the issue. 1 Quote
Ragsf15e Posted November 1, 2023 Report Posted November 1, 2023 On 11/1/2023 at 2:02 AM, Shadrach said: I’m thinking it’s a sensor issue given the mags checked out in flight mag. Your engine has a CR of 8.5:1. 1573° is outside of the norm for which an engine unless there is an ignition problem. Would have been interesting to know the single mag EGT on the cylinder. I expect the reading was in excess of 1700° Would be highly suspect. You could try swapping probes, but removing exhaust probes can sometimes damage them. . I would replace the probe. It’s a low risk investment, and the most likely cause of the issue. Expand I sometimes see egts that high after descending from lop cruise. Say cruising at 10,000’, nose down, don’t touch anything else. Egts start to climb slowly during decent. Maybe around 4 or 5,000’ they set off the yellow “caution” on my jpi930 as they pass 1500. I guess I’m saying maybe those egts could be possible at lower altitude near peak? I don’t think egt probes usually fail this way, but I agree it’s worth checking? Quote
Shadrach Posted November 1, 2023 Report Posted November 1, 2023 On 11/1/2023 at 2:49 AM, Ragsf15e said: I sometimes see egts that high after descending from lop cruise. Say cruising at 10,000’, nose down, don’t touch anything else. Egts start to climb slowly during decent. Maybe around 4 or 5,000’ they set off the yellow “caution” on my jpi930 as they pass 1500. I guess I’m saying maybe those egts could be possible at lower altitude near peak? I don’t think egt probes usually fail this way, but I agree it’s worth checking? Expand He’s at 1573 in cruise. I do have one cylinder that will just break 1500° at low altitude at WOTRAO. 1573° at 21.5”x2520 seems unlikely. 1 Quote
PT20J Posted November 2, 2023 Report Posted November 2, 2023 Easy to swap probes and see if the problem stays with the cylinder or follows the probe. Quote
EarthboundMisfit Posted November 2, 2023 Report Posted November 2, 2023 Are you running ROP or LOP in those photos? For comparison our IO-550G in cruise (9000ft, approx 20 deg LOP) last week: Quote
Shadrach Posted November 2, 2023 Report Posted November 2, 2023 On 11/2/2023 at 4:08 AM, PT20J said: Easy to swap probes and see if the problem stays with the cylinder or follows the probe. Expand On more than one occasion, I’ve had exhaust probes get flakey after being disturbed. I don’t know why exactly. I’d guess that they were marginal before removal and the process finished them off. It’s good idea to have a spare or two on hand just in case. 1 Quote
