Rmfriday Posted September 27, 2023 Report Posted September 27, 2023 Anyone have a servicable or yellow tagged engine mount part # 590000 or 590000-509 Just found a crack in mine......
PT20J Posted September 27, 2023 Report Posted September 27, 2023 1 hour ago, Rmfriday said: Anyone have a servicable or yellow tagged engine mount part # 590000 or 590000-509 Just found a crack in mine...... Is yours not repairable?
N201MKTurbo Posted September 27, 2023 Report Posted September 27, 2023 I have sent two to LASAR over the years. I’m not sure they are still doing weld repairs. But anybody can fix it per 43.13-1B. It has extensive guidance on how to make weld repairs to steel tube structures. If your A&P isn’t a welder, he can supervise a real welder. Also, depending on where it cracked, there are service bulletins addressing engine mount cracks, with guidance for adding gussets to the mount. 1
Rmfriday Posted September 27, 2023 Author Report Posted September 27, 2023 Thanks for the replies Going to head to the airport later and meet w the A&P to see where it is cracked. Also contacted Alan Fox and he is checking to see if he has one.
Robert Hicks Posted September 27, 2023 Report Posted September 27, 2023 I’ve got one here in Phoenix. Does not have gussets yet.
Pinecone Posted September 28, 2023 Report Posted September 28, 2023 Doesn't Acorn Welding repair them? And reports I have seen is that they are pretty much a new mount.
Rmfriday Posted October 8, 2023 Author Report Posted October 8, 2023 Mount was not cracked but broken….. you can also see what 25 years does to the rubber mounts( new one in the middle)
