moon_dog Posted April 11, 2023 Report Posted April 11, 2023 (edited) Hi all, apparently I have a bad down-limit switch in my M20F. The symptom is that the gear down light is intermittent and doesn’t come on right away when the gear goes down. Sometimes takes way too long to come on and is quite disconcerting in the pattern. Anyway, I need a replacement. The Lasar part is the Otto P6-24014. It’s almost a grand and is a special order item. Does anyone know of an alternative to this part? Or where I might be able to find a good used one? Thanks in advance! Edited April 11, 2023 by moon_dog Quote
carusoam Posted April 11, 2023 Report Posted April 11, 2023 wait… You have electric gear…. contact @Alan Fox Or clean the switch… Best regards, -a- Quote
PT20J Posted April 11, 2023 Report Posted April 11, 2023 41 minutes ago, carusoam said: wait… You have electric gear…. contact @Alan Fox Or clean the switch… Best regards, -a- According to the specs, it’s sealed. Quote
PT20J Posted April 11, 2023 Report Posted April 11, 2023 +1 for @Alan Fox Search the part number online. Call an Otto distributer. Call other Mooney Service Centers Quote
LANCECASPER Posted April 11, 2023 Report Posted April 11, 2023 6 hours ago, moon_dog said: Hi all, apparently I have a bad down-limit switch in my M20F. The symptom is that the gear down light is intermittent and doesn’t come on right away when the gear goes down. Sometimes takes way too long to come on and is quite disconcerting in the pattern. Anyway, I need a replacement. The Lasar part is the Otto P6-24014. It’s almost a grand and is a special order item. Does anyone know of an alternative to this part? Or where I might be able to find a good used one? Thanks in advance! https://peerlesselectronics.com/p6-14000-switch They have 146 in stock. 2 1 Quote
PT20J Posted April 11, 2023 Report Posted April 11, 2023 3 hours ago, LANCECASPER said: https://peerlesselectronics.com/p6-14000-switch They have 146 in stock. That's not the same part number, though. Mooney used a P6-24014. Otto doesn't list the Mooney part in their current catalog. I would call them and see if there is a cross reference. https://www.otto-controls.com/-/media/products/electromechanical-switches/limitswitches/p6sealedlimitswitchesmilprf8805/p6-sealed-limit-switches-catalog-page.ashx Quote
moon_dog Posted April 11, 2023 Author Report Posted April 11, 2023 20 minutes ago, PT20J said: That's not the same part number, though. Mooney used a P6-24014. Otto doesn't list the Mooney part in their current catalog. I would call them and see if there is a cross reference. https://www.otto-controls.com/-/media/products/electromechanical-switches/limitswitches/p6sealedlimitswitchesmilprf8805/p6-sealed-limit-switches-catalog-page.ashx Correct. I called Otto this morning and the lead time for this item is 8-10 weeks... Curious if a similar product is approved for use. Definitely ramping up the search for a used one. 1 Quote
LANCECASPER Posted April 11, 2023 Report Posted April 11, 2023 1 hour ago, PT20J said: That's not the same part number, though. Mooney used a P6-24014. Oops! Quote
Ragsf15e Posted April 11, 2023 Report Posted April 11, 2023 You should call DMax and talk to him (Don Maxwell Mooney, Longview TX). I called and talked to him a few years ago and he gave me some specific part numbers. I ended up lubing mine and (fingers crossed), it's been ok since. However, I looked up the part numbers and they appear to be two components that actually make up the switch. I'm not saying these are right - in fact they look different than yours, I'm saying you should call him, but I'm going to attach below so you can see... I'm now curious because your limit switch looks much different than mine (1968 F). What year is your F? Mine look more like the ones Don told me about. Maybe there is an alternate part you could use? I'll attach a (crappy) picture of my limit switch - it's black and cube shaped, definitely different than yours. Sorry about the picture, but it's in the bottom left. MCD2711 - https://www.mouser.com/ProductDetail/Honeywell/MCD2711?qs=0x4sLrpp94KewLfSyp6k4A%3D%3D&gclid=CjwKCAjwitShBhA6EiwAq3RqA3nvmhMJynIznYPuCs0H7iLE9sKi8PtiUNmwOAOwZtTGgGje0yvq4hoC8iQQAvD_BwE DT-2R-A7 - https://www.grainger.com/product/24A126?s_kwcid=AL!2966!3!606773749412!p!!g!!__EFKW__&gucid=N:N:PS:Paid:GGL:CSM-2296:AB578S:20500731&gclid=CjwKCAjwitShBhA6EiwAq3RqA9tu1iox7sux-IPLhsfy64P0hAF2rVytkY-OTvqT4M5_rR5B5o4AFhoCNh4QAvD_BwE&gclsrc=aw.ds 1 Quote
moon_dog Posted April 11, 2023 Author Report Posted April 11, 2023 Turns out the Honeywell 1CH1-6 is also used in these airplanes and I was able to locate a used one at BAS. It's en route. We will see... 1 Quote
Ragsf15e Posted April 11, 2023 Report Posted April 11, 2023 5 minutes ago, moon_dog said: Turns out the Honeywell 1CH1-6 is also used in these airplanes and I was able to locate a used one at BAS. It's en route. We will see... What year is your airplane? The switch looks much different than my picture above? Quote
201Steve Posted November 2, 2024 Report Posted November 2, 2024 @moon_dog did you have luck with the 1ch1-6 as a down limit switch? The IPC calls out that part number as used for the gear squat switch (if so equipped). They appear identical to the 1ch116-6 which is the official down limit switch part number, but it seems some resellers call out the 1ch1-6 as a Mooney gear limit switch. Quote
FLYFST Posted November 2, 2024 Report Posted November 2, 2024 On 4/11/2023 at 5:54 PM, moon_dog said: Turns out the Honeywell 1CH1-6 is also used in these airplanes and I was able to locate a used one at BAS. It's en route. We will see... Moon_Dog, I've had similar issues with my 1990 J model, and what worked out best was adjusting the switch stop (tab secured to the push-pull rod) so that it contacts the plunger face flat instead of at an angle. My A&P previously tried lubing the plunger with CRC contact cleaner with immediate results that did not last much. As a sealed switch, about the only place the lubricant could be of some effect is on the plunger, and that actually looked very good and corrosion free in my case. My switch appears to have been replaced from the original and it is currently an Otto Controls P6-24014 alternate part number in the IPC. When I called LASAR earlier this year looking for a Honeywell 1CH116-6 switch they told me that switch was no longer available, but recommended alternate part number P6-24014 (what I have now), and which in March 2024 was $1,152 new but out of stock. They also suggested using another alternate part number 1EN1S priced at $1,768 and one was available then from the Mooney factory. Quote
201Steve Posted November 2, 2024 Report Posted November 2, 2024 @moon_dog did you have luck with the 1ch1-6 as a down limit switch? The IPC calls out that part number as used for the gear squat switch (if so equipped). They appear identical to the 1ch116-6 which is the official down limit switch part number, but it seems some resellers call out the 1ch1-6 as a Mooney gear limit switch. good feedback thanks! I just found the 1EN1S for a almost reasonable $460 Quote
A64Pilot Posted November 2, 2024 Report Posted November 2, 2024 (edited) Ref cleaning switches, by all means do so as a temp measure, but be aware it’s almost always a temporary fix as most switches have some kind of plating on them and most of the time they get intermittent when this plating wears off and cleaning won’t of course replace the plating. Switches that trigger a relay so that they are only carrying a tiny amount of power last a very long time as opposed to those that carry significant amount of current due to arcing of the contacts. Then all contact cleaners are not created equal, I’ve had the best luck with Deoxit, it’s not cheap but compared to the price of these switches it’s just pennie’s. Ref are there any other approved switches? Download and read this AC ref parts substitution for antique aircraft, ALL Mooney’s are antique aircraft and this AC covers every Mooney ever made, in particular electrical parts are about the easiest to substitute, many if not nearly all are Standard Parts. So look up Standard parts, I think if you could find a switch that would work and carry the amperage then yes it’s approved. I would quote this AC in the logbook entry though. This AC has been out since 09, so 15 years? Not likely to change and surely every FAA inspector is aware of it. https://www.faa.gov/documentLibrary/media/Advisory_Circular/AC_23-27.pdf On edit, I use contact cleaner as a troubleshooting measure, if the problem goes away when I clean a switch, then it’s likely that’s the problem so I try to find a switch. Edited November 2, 2024 by A64Pilot 1 1 Quote
FLYFST Posted March 20 Report Posted March 20 Has anyone confirmed that the 1EN1-6 or 1CH1-6 limit switch is a Mooney-approved replacement for the Honeywell 1CH116-6 switch listed in the Mooney IPC? Best research I have found so far was from Skip (PT20J) who noted the 1CH1-6 is essentially the same as the now obsolete 1CH116-6, but that circuit specification stated that one circuit must close slightly before another, presumably to make the motor shut down before the gear light comes on, and the 1CH1-6 does not include that feature. I'm searching for a replacement to the Otto Controls P6-24014 switch that I have and while the 1CH1-6 seems to be viable, I am concerned about the circuit difference that Skip found in the following post. Quote
PT20J Posted March 20 Report Posted March 20 I cannot imagine that the requirement that one set of contacts makes first makes a difference. According to the specification, the difference in plunger travel between the two sets of contacts making is only .010 +/-.005". If you are really concerned about it, you could call Frank Crawford. 2 Quote
EricJ Posted March 20 Report Posted March 20 Another potential strategy is to try it and see if it passes op checks. If the environmental (temperature, etc.) and electrical (current capability, etc.), etc., specs are suitable for the application that may be a reasonable way to proceed. Consult with your IA. 2 Quote
