damcmurt Posted February 1, 2023 Report Posted February 1, 2023 I was recently having a fuel smell in the cockpit after the airplane sat for several days or more. My maintenance shop pulled the interior and found fuel stains coming down in front of the spar on the copilots side. This is just below and behind the entry door on a 80 M20K. Looking for advice on any shops recommended to patch or reseal tank. Also how much leakage would make it unairworthy. Here are some pics Quote
Ragsf15e Posted February 1, 2023 Report Posted February 1, 2023 Yikes. Usually it leaks out of the pickup gasket there, but that looks further aft. Maybe @N201MKTurbo or @M20Doc could give you an idea? Oasis aero is a common place to do tanks if you need a full reseal. Lots of mechanics have various patch skills. Look up Don Maxwell’s article about patching leaks. 1 Quote
ZuluZulu Posted February 1, 2023 Report Posted February 1, 2023 I had an absolute nightmare of an experience during almost all of 2022 dealing with one particular shop in California that failed multiple leak checks over the course of months and then started getting hostile and aggressive in their communications. It's never been right, it's still leaking from new locations on the wing, and now they refuse to reply to my calls. After all that, I would STRONGLY recommend you go to the pros: Troutdale if they're still doing it, Weep No More in Willmar, MN; or Wet Wingologists East. I wouldn't wish my experience on anyone. 2 Quote
Ragsf15e Posted February 1, 2023 Report Posted February 1, 2023 On 2/1/2023 at 3:45 AM, ZuluZulu said: I had an absolute nightmare of an experience during almost all of 2022 dealing with one particular shop in California that failed multiple leak checks over the course of months and then started getting hostile and aggressive in their communications. It's never been right, it's still leaking from new locations on the wing, and now they refuse to reply to my calls. After all that, I would STRONGLY recommend you go to the pros: Troutdale if they're still doing it, Weep No More in Willmar, MN; or Wet Wingologists East. I wouldn't wish my experience on anyone. Expand Yeah, you don’t want someone willing to experiment. You want someone who does it a lot. Those shops are good. 1 Quote
N201MKTurbo Posted February 1, 2023 Report Posted February 1, 2023 I’ve seen a lot worse. The corners are a common leak point. If you don’t top off your tanks unless you are going somewhere, you could put it off for a while. To properly repair it will require opening that cell. You can probably get away with just removing the bottom panel. As usual taking care of the access panel is more work than fixing the leak. The procedure is in the maintenance manual. If you follow it you will be successful. If you take shortcuts, you will probably fail. The Don Maxwell method isn’t about fixing the leak, it is about finding it. The fixing part is just by the manual. 4 Quote
Mufflerbearing Posted February 1, 2023 Report Posted February 1, 2023 I believe that Troutdale is no longer doing tank repairs. I would like to think I am wrong but I believe this is accurate. That really doesn't leave anyone out west to do this type of work that has a good standing reputation on this board. 1 Quote
Jim Peace Posted February 1, 2023 Report Posted February 1, 2023 On 2/1/2023 at 1:23 AM, damcmurt said: Road trip in your future....Willmar or FXE....warmer in FXE... Expand 1 Quote
damcmurt Posted February 14, 2023 Author Report Posted February 14, 2023 Thanks everyone for the feedback. I spoke to TopGun in Stockton and they mention FL and MN. Also they mention a shop in TX. I looked them up, Houston Tank Specialist. Anyone have any experience with them? Quote
Fly Boomer Posted February 14, 2023 Report Posted February 14, 2023 On 2/14/2023 at 12:23 AM, damcmurt said: Thanks everyone for the feedback. I spoke to TopGun in Stockton and they mention FL and MN. Also they mention a shop in TX. I looked them up, Houston Tank Specialist. Anyone have any experience with them? Expand Some here love the service they got. Others, not so much. 1 Quote
1980Mooney Posted February 14, 2023 Report Posted February 14, 2023 On 2/14/2023 at 12:38 AM, Fly Boomer said: Some here love the service they got. Others, not so much. Expand @damcmurt Here is a “not so much” And Quote
ZuluZulu Posted February 14, 2023 Report Posted February 14, 2023 On 2/14/2023 at 12:23 AM, damcmurt said: Thanks everyone for the feedback. I spoke to TopGun in Stockton and they mention FL and MN. Also they mention a shop in TX. I looked them up, Houston Tank Specialist. Anyone have any experience with them? Expand Will they patch tanks but not reseal? Or no touching tanks at all? Quote
hammdo Posted February 14, 2023 Report Posted February 14, 2023 Maxwells will do patches… -Don 1 Quote
GeeBee Posted February 15, 2023 Report Posted February 15, 2023 Just dropped mine off at WetWingologist in KFXE. Saw an Eagle and an Ovation opened up and curing. I was impressed with his work! 1 Quote
damcmurt Posted February 16, 2023 Author Report Posted February 16, 2023 @ZuluZulu My local shop wont touch even for a patch. Looking through logbooks though the left tank has had 2 small patches done and nothing else. Since its 43 years old it might be time to start fresh. Quote
ZuluZulu Posted February 16, 2023 Report Posted February 16, 2023 On 2/16/2023 at 2:35 AM, damcmurt said: @ZuluZulu My local shop wont touch even for a patch. Looking through logbooks though the left tank has had 2 small patches done and nothing else. Since it’s 43 years old it might be time to start fresh. Expand Thanks — I should have made it more clear I was asking about Top Gun. 1 Quote
