I’ve circled the links in question for you.  The SB kit includes everything required
Thanks @M20doc I surmised that was the linkage in question always good to get a second opinion!
I can't remember who but someone once told me if you don't  have washer between the bolt head or nut end of the rod end. it is possible for the ball of the rod end to pop out of rod end housing.  that cause me to double check anytime I see a rod end to verify there is washer at very least nut and bolt end of the assembly.
I believe you are referring to the practice of installing a large planform washer on a rod end where there is a possibility that if the socket came off the ball it could slip over the the nut or bolt head and become disconnected. I know some experimental builders do this, but I don't know how prevalent it is on production aircraft. And I have no idea how often rod ends fail in this way.
Skip
Skip
It’s depends on manufacturer and models.  Some add the penny washer and some don’t.  I’ll often add one where it doesn’t interfere with the installation.
Skip
My engine control cables all have them but I think one of them is installed wrong (probably by me).   Next time the cowl is off I'll probably fix it.
I just finished my annual and I looked at these aileron links while the belly was off.   Mine move quite a bit and there's a bare spot on the landing gear actuator tube where it's been rubbing, but it doesn't really seem to be problematic.   I suspect it's been like that for a loooong time.   I'll see what the kit costs and whether the local MSC has it or can get it and maybe put it in next year.
Since the kit give the dimesions of the spacers and the rest is common hardware, you could also just make the spacers.
Yeah, was looking at that.   Lasar lists the kit at $271 but says they don't have them.   The spacer material isn't indicated, though.   Nylon?
Pretty sure it’s steel or aluminum from the look of it. Mine was installed by the previous owner. Maybe @M20Doc knows.
In Vance's vid in this thread from a year ago last April they look like plastic of some kind.
Do you have a link to the kit on their website?
The three spacers are steel. If the kit is our of stock, see if the spacers are available individually. The bolt and nut are standard AN parts.
Lasar shows the spacers individually as well but all out of stock.   The I.D. seems to be much bigger than the bolt, too, so that seems to be an additional unknown.
Maybe Frank Crawford would share the details? Worth a call.
The spacers are essentially a steel washer that fits around and over the steel ball of the rod end bearing.  The centre spacer is twice as thick as the two outer spacers.
  • 2 years later...
43 minutes ago, lithium366 said:
Anyone know where to source parts in 2024? Lazar is out of stock but when they do these washers are $120 each
Each MSC maintains it's own stock, so you could call around.
You could probably have a machine shop make them cheaper than buying them from Mooney.
Do we know dimensions? I can create a cad file if dimensions known
Edited by lithium366
Pretty sure they are epoxy primed steel. The thickness is specified in the SB. The hole diameter is set by the bolt and would be the same as an AN960 washer. From Vance's video in the original post the function is clear (to restrict the twisting motion of the Heim bearings) and the outer diameter can be estimated. You could probably make them by modifying some AN970 washer to reduce diameter and thickness.
