RLCarter Posted April 18, 2021 Report Posted April 18, 2021 5 minutes ago, ltdriser said: Another update! Went to the field. Turns out the starter does work woohoo! But she still won’t start. Boo! I cannot engage the SOS and starter at same time. The starter will turn when I turn the key all the way to the right. As soon as I push in the key for spark the starter stops. The two need to work together and it seems I can only get one or the other. Mine is key fully clockwise (SOS is the spring loaded portion) while holding in the spring loaded section you PUSH in to engage the starter 1
ltdriser Posted April 18, 2021 Author Report Posted April 18, 2021 (edited) Mine is definitely spring for starter engagement and push for SOS. I’m assuming SOS is the sound I’m hearing. I just double checked in the owners manual. Push to engage starter - spring for SOS. That’s concerning. Edited April 18, 2021 by ltdriser
RLCarter Posted April 18, 2021 Report Posted April 18, 2021 12 minutes ago, ltdriser said: That is a little concerning as I just had the plane in for a new starter contractor and starter. Makes me question if there was a rewiring problem. this is from Don Maxwells website The ignition switch has 6 positions. “Off” which grounds both magnetos and makes them both inoperative. “Right” allows the right magneto to operate and makes the left magneto inoperative. “Left” allows the left magneto to operate but makes the right magneto inoperative. “Both” allows both left & right magneto to operate. The other two positions are “turning the key just to the right of the both” position activates the shower of sparks vibrator, and “pushing in” on the ignition key at this position activates the engine starter.
N201MKTurbo Posted April 18, 2021 Report Posted April 18, 2021 50 minutes ago, ltdriser said: Another update! Went to the field. Turns out the starter does work woohoo! But she still won’t start. Boo! I cannot engage the SOS and starter at same time. The starter will turn when I turn the key all the way to the right. As soon as I push in the key for spark the starter stops. The two need to work together and it seems I can only get one or the other. Something is wired wrong. The SOS should be on with the key turned to the right. The starter should run when you push the key in. The SOS should keep running with the key pushed in. 2
RLCarter Posted April 18, 2021 Report Posted April 18, 2021 4 minutes ago, N201MKTurbo said: Something is wired wrong. The SOS should be on with the key turned to the right. The starter should run when you push the key in. The SOS should keep running with the key pushed in. Agreed, you can even see the placard on the switch in his video
ltdriser Posted April 18, 2021 Author Report Posted April 18, 2021 I’m pretty well convinced that it’s a wiring issue. However, I’m curious why with this particular set up I cannot run both the SOS and starter in parallel. You’d think that should still function as that’s how it would operate when wired normally. I’d just expect my inputs to activate the wrong things. I’m missing a bit of the “how it works” info. The mx manager and I are becoming quite acquainted.
RLCarter Posted April 18, 2021 Report Posted April 18, 2021 Yes they operate at the same time when the starter is engaged but it is 2 separate circuits, my guess is if they were on the same circuit the SOS would suffer from the draw of the starter
steingar Posted April 18, 2021 Report Posted April 18, 2021 This is the fault of the mechanics, and not us. This is MY airplane! I tried to fly this weekend and got bubkiss. The saddest thing is this is the squawk that sent the airplane to the shop in the first place, and it looks like the pilots have to do the diagnosis instead of the mechanics! Pretty pathetic in the Book of Steingar. Hopefully with us leading the way they'll get it fixed this time. Third try is always the charm, right? If I had time I'd go to the maintenance hangar and watch while they start the thing.
Andy95W Posted April 18, 2021 Report Posted April 18, 2021 I think it’s much more likely that your ignition switch failed internally rather than automatically blaming the mechanic. Changing starters or relays is incredibly straightforward, take wires off then put wires back on. Ignition switch failures are more common. Unless the mx mgr or mechanic specifically says they messed with the switch wiring itself (not likely). Rebuild kits are available. New switches are like $460. 1
Guest Posted April 18, 2021 Report Posted April 18, 2021 First rule for pilot/owners, blame maintenance. First rule for maintenance, blame the pilot/owners. I’ve encountered pilots who don’t know how their plane works as often as maintainers who don’t know how planes work. Clarence
RLCarter Posted April 18, 2021 Report Posted April 18, 2021 @M20Doc some truth right there..... and if you ask both at the same time, no one knows what happened
47U Posted April 18, 2021 Report Posted April 18, 2021 5 minutes ago, M20Doc said: First rule for pilot/owners, blame maintenance. First rule for maintenance, blame the pilot/owners. Clarence In a previous life I was a crew chief/flight mechanic on a C-135. We were a pax hauler and based at Offutt AFB. I cannot tell you how many times I had to ‘translate’ discrepancies that the pilots had written into the aircraft forms into mx-speak post mission at the debrief table.
cliffy Posted April 19, 2021 Report Posted April 19, 2021 At this point you'd be doing well to find the CORRECT wiring diagram for you switch/starter system and trace out the wiring to make damn sure everything is wired correctly It may have been wired backwards for some time and you didn't notice it because it started. Its just detail wire tracing Get it right. One of the hardest things to teach new airline pilots is how to write up discrepancies (and how to do it so they keep their butt out of the sling) Many A&Ps have very limited wiring and electrical ability. I know a couple that won't go near wiring or electrical. 2
Ragsf15e Posted April 19, 2021 Report Posted April 19, 2021 2 hours ago, cliffy said: At this point you'd be doing well to find the CORRECT wiring diagram for you switch/starter system and trace out the wiring to make damn sure everything is wired correctly It may have been wired backwards for some time and you didn't notice it because it started. Its just detail wire tracing Get it right. One of the hardest things to teach new airline pilots is how to write up discrepancies (and how to do it so they keep their butt out of the sling) Many A&Ps have very limited wiring and electrical ability. I know a couple that won't go near wiring or electrical. Yes, that last part is true for sure. The ones that do go near it often don’t know how to troubleshoot, but are happy to throw parts at the problem. I have a new alternator and VR and field wire and alternator wiring. After none of that fixed my low voltage, I taight myself basic electrical and talked to a friend who does it for a living. $2k worth of new parts/labor and the problem turned out to be a corroded connection that I found and fixed myself. 2
ltdriser Posted April 28, 2021 Author Report Posted April 28, 2021 Final update, I hope. A&P did some investigation and found a misplaced wire when the relay was installed. They fixed and I am told everything is back to operating properly! 2 1
jaylw314 Posted April 28, 2021 Report Posted April 28, 2021 1 hour ago, ltdriser said: Final update, I hope. A&P did some investigation and found a misplaced wire when the relay was installed. They fixed and I am told everything is back to operating properly! Thanks for the follow up! Egads, that doesn't instill a lot of confidence in the shop, no?
RLCarter Posted April 28, 2021 Report Posted April 28, 2021 1 hour ago, ltdriser said: Final update, I hope. A&P did some investigation and found a misplaced wire when the relay was installed. They fixed and I am told everything is back to operating properly! So what did he find on your switch where the SOS & starter is reversed?
ltdriser Posted April 29, 2021 Author Report Posted April 29, 2021 (edited) When we originally spoke it was sounding like a bad switch. I was adamant that they tone the switch out and confirm or reject it’s operation as i started to get the feeling we were about to throw parts at it. The switch toned out good which led them down the path of investigating the wiring and found there was a wire tied to 12vdc where it should have been to 0vdc. I didn’t ask much further as to how that would explain how the switch was acting. I suppose I could take a look at the circuit with what they explained then try to tie that back to what was occurring. It would be really cool to get some schematics with red marks but in my experience those are as rare as hen’s teeth. Edited April 29, 2021 by ltdriser
RLCarter Posted April 29, 2021 Report Posted April 29, 2021 1 hour ago, ltdriser said: When we originally spoke it was sounding like a bad switch............ Didn't you say that all the way to the right engages the starter and pushing in activates the Shower of Sparks? If this is the case the switch is wire incorrectly? That is just the opposite of the design, full right activates the SOS and pushing in engages the starter
ltdriser Posted April 29, 2021 Author Report Posted April 29, 2021 Correct, that is how it was acting when I took it in for repair. 1
carusoam Posted April 30, 2021 Report Posted April 30, 2021 That is one strange occurrence... Sounds like somebody could have gotten injured by being in the wrong place at the wrong time... Is it all back together properly now? Best regards, -a- 1
ltdriser Posted May 1, 2021 Author Report Posted May 1, 2021 All back together and purring like a kitten. Got a good XC in today, feels good to be back in the saddle after over a month of back and forth. 1
