Hello I have an M20K s/n 25-0446.
I’m in need of the part number of the fuel transducer, it measures the gals per hour shown on the manifold pressure guage thank you Pete
If looking to buy one new...
Dan at Lasar.com is the goto guy of Mooney parts... he is also pretty good with part numbers...
Often, part numbers can be ascertained from the parts manual...
Parts manuals have been E-ed, and are available from Mooney...
PP thoughts only, not a mechanic or parts sales guy...
Your fuel pressure transducer measures your fuel pressure. Your manifold pressure transducer measures your manifold pressure. Your fuel flow transducer shows you gallons per hour on your Hoskins or Shadin or JPI or EI meter. Which do you need?
You probably need the fuel flow transducer. They go out pretty regularly on the M20K's. They are readily available from Aircraft Spruce or your favorite aviation parts vendor. They are not a Mooney specific part.
I’m thinking if it’s a combo manifold / fuel flow gauge, it’s actually a pressure transducer, most combo gauges are actually pressure gauges marked in GPH as pressure can be used to determine fuel flow, not as accurately as an actual fuel flow transducer, but accurate enough
Just to keep it all straight...
The OP @PEDRO is looking for a fuel FLOW transducer for an M20K which has a Continental TSIO360 engine.
Several posts lower down, @theflyingdoctoris looking for a fuel PRESSURE transducer for an M20J which has a Lycoming IO360 engine.
Any parts house will have either of these transducers. So any A&P ought to be able to make a phone call and have one on the way. Aircraft Spruce likely has them.
1 hour ago, theflyingdoctor said:
Yes, i meant re info as where to get parts... learning one thread at a time ..
Of it’s the electronic FP gauge that sender is a little more difficult to procure I think.  Out of production.
FF transducers are easy.  The Shadin had a large K-factor, an EI Red Cube is a good substitute.
