Shawn26 Posted May 24, 2020 Author Report Posted May 24, 2020 [mention=16838]Shawn26[/mention], What are you doing with the KAP-150 once removed? I might be interested in some of the components. Sell it on eBay. About 18 month a go the flight computer KAP 150 was fixed by Mid-Continent Instruments and it comes with FAA authorization for the repair. The whole system works excellent. Never had any issues with the servos. Sent from my iPhone using Tapatalk 1
jonhop Posted May 24, 2020 Report Posted May 24, 2020 4 minutes ago, Shawn26 said: Sell it on eBay Let me know when listed. Maybe you'll get a sell. I'm specifically interested in the flight computer, as mine was repaired not too long ago but is still a little buggy.
HIghpockets Posted May 24, 2020 Report Posted May 24, 2020 I get the aural tone at 1000' to go and 200' to go as well as flashing digits.
Tim Jodice Posted May 25, 2020 Report Posted May 25, 2020 Why did you replace your KAP150 if it was working properly?
Shawn26 Posted May 25, 2020 Author Report Posted May 25, 2020 Why did you replace your KAP150 if it was working properly? I wanted to remove my vacuum system and install a second G5. KAP 150 will not work. Loosing your vacuum system in the soup is scary, I’ve been there Sent from my iPhone using Tapatalk
Tim Jodice Posted May 25, 2020 Report Posted May 25, 2020 I have a KFC150 do you know if that is the same? I was hoping to get rid of my vacuum system during a panel upgrade also.
Shawn26 Posted May 25, 2020 Author Report Posted May 25, 2020 Yes, they are the same! KAP or KCP 150 requires vacuum system. The autopilot works with your Bendix King Horizon Gyro. There is a module that you can install and remove your vacuum system, but I think it only works with Aspen. It’s about 2k for that module alone which transfer analog data to digital. Sent from my iPhone using Tapatalk
Bob - S50 Posted May 25, 2020 Report Posted May 25, 2020 39 minutes ago, Shawn26 said: Yes, they are the same! KAP or KCP 150 requires vacuum system. The autopilot works with your Bendix King Horizon Gyro. There is a module that you can install and remove your vacuum system, but I think it only works with Aspen. It’s about 2k for that module alone which transfer analog data to digital. Sent from my iPhone using Tapatalk Or a Garmin GI275. It will not give you 'native GPSS', but it will give you GPSS HDG emulation. With the KFC150 it will even give you a flight director. With the KAP150 it will not give you a flight director.
Shawn26 Posted May 25, 2020 Author Report Posted May 25, 2020 Or a Garmin GI275. It will not give you 'native GPSS', but it will give you GPSS HDG emulation. With the KFC150 it will even give you a flight director. With the KAP150 it will not give you a flight director. I wouldn’t know. I already have a G5 HSI, so for me another G5 Ai is more symmetricalSent from my iPhone using Tapatalk
Bob - S50 Posted May 25, 2020 Report Posted May 25, 2020 2 hours ago, Shawn26 said: I wouldn’t know. I already have a G5 HSI, so for me another G5 Ai is more symmetrical Sent from my iPhone using Tapatalk But a G5 will NOT run a KFC150 or a KAP150.
gsxrpilot Posted May 26, 2020 Report Posted May 26, 2020 12 hours ago, airtim said: I have a KFC150 do you know if that is the same? I was hoping to get rid of my vacuum system during a panel upgrade also. I have a KFC150 in my 252 and no vacuum system. (Well technically I still have a vacuum system but it's only connected to my speed brakes) Nothing in my panel is connected to vacuum. My KFC150 is driven by an Aspen E1000 Pro with the EA100 analogue converter. This is also connected to an IFD540 WAAS GPS. It's a great system and I've never had any problems with the KFC150. No vacuum pump needed. 1
Shawn26 Posted May 26, 2020 Author Report Posted May 26, 2020 I have a KFC150 in my 252 and no vacuum system. (Well technically I still have a vacuum system but it's only connected to my speed brakes) Nothing in my panel is connected to vacuum. My KFC150 is driven by an Aspen E1000 Pro with the EA100 analogue converter. This is also connected to an IFD540 WAAS GPS. It's a great system and I've never had any problems with the KFC150. No vacuum pump needed. I was leaning towards Aspen and the EA1000 last year before I install my G5 HSI. This would be a good system but the autopilot wouldn’t have a flight director. Sent from my iPhone using Tapatalk 1
gsxrpilot Posted May 26, 2020 Report Posted May 26, 2020 Just now, Shawn26 said: I was leaning towards Aspen and the EA1000 last year before I install my G5 HSI. This would be a good system but the autopilot wouldn’t have a flight director. Correct. The flight director is a function of the autopilot and the KAP150 doesn't have one.
Shawn26 Posted May 26, 2020 Author Report Posted May 26, 2020 Correct. The flight director is a function of the autopilot and the KAP150 doesn't have one. Don’t get me wrong. This is excellent setup and the flight director it’s not a huge thing for pilots trained to fly with old steam gauges and without any of this stuff! But I got to a point of my life that I like to have more redundancy and safety. Garmin GFC 500 autopilot has a lot to offer in my opinion. Sent from my iPhone using Tapatalk 1
carusoam Posted May 26, 2020 Report Posted May 26, 2020 it’s possible... A lot can happen in 26years of electronics development... A KAP150 was installed in my plane in 1994. I wouldn’t look back if I got a GFC500... installed in 2020. Sure... the KAP150 is very capable... holds altitude follows a heading Intercepts courses... from any angle... intercepts an ILS from either above or below... can climb Or descend at a set rate... In chunks of 100fpm... With a GPSS and a WAAS source... nothing gets much better... It even has a yaw damper available for it... It is a very powerful digital device working with minimal memory... That has lasted a long time... Best regards, -a- 1
Shawn26 Posted May 26, 2020 Author Report Posted May 26, 2020 it’s possible... A lot can happen in 26years of electronics development... A KAP150 was installed in my plane in 1994. I wouldn’t look back if I got a GFC500... installed in 2020. Sure... the KAP150 is very capable... holds altitude follows a heading Intercepts courses... intercepts an ILS from either above or below... can climb Or descend at a set rate... With a GPSS and a WAAS source... nothing gets much better... It even has a yaw damper available for it... It is a very powerful digital device working with minimal memory... That has lasted a long time... Best regards, -a- That’s how I look at it when I set the budget for the installation of GFC 500! Sent from my iPhone using Tapatalk 1
donkaye, MCFI Posted May 26, 2020 Report Posted May 26, 2020 On 5/23/2020 at 12:31 AM, Niko182 said: I'm flying an M20S, but you'll find that no matter what air frame it was installed on, everyone seems to love it. beechtalk has a ton of pireps on it too. Here is the price of the entire GFC500 price layed out, because other people reading are probably curious about it GFC500 AP control Panel: $2,800 GSA28 servo: 1400 x 4 = $5,600 Product Info Kit = $50 Basic Install Kit = $2,000 Pitch Trim Kit = $850 Yaw Damper Kit = $850 Labor for installation of GFC500 = $5,000 Labor for Yaw Damper = $800 Yaw Damper alone = 3,050 Total = $17,950 Definitely far from cheap, but you get what you pay for in the aviation world, and it is significantly better than the stec30 it replaced. hope this helps If you don't already have a G5 you'll need to add the price of the G5 plus labor, too. 1
Niko182 Posted May 26, 2020 Report Posted May 26, 2020 Just now, donkaye said: If you don't already have a G5 you'll need to add the price of the G5 plus labor, too. Realistically 2 or a g3x and a g5 2
rcwagner Posted May 27, 2020 Report Posted May 27, 2020 Just make sure your M20J is 100% M20J. Mine was rebuilt with an M20L tail cone, and Garmin would not create an STC for my aircraft. They found out about it after they were about 90% installed. Had to remove it and I ended up with an STEC 55X. The STEC works fine, but I was not happy with the shop that went down this road before looking into the paperwork.
Shawn26 Posted May 27, 2020 Author Report Posted May 27, 2020 Just make sure your M20J is 100% M20J. Mine was rebuilt with an M20L tail cone, and Garmin would not create an STC for my aircraft. They found out about it after they were about 90% installed. Had to remove it and I ended up with an STEC 55X. The STEC works fine, but I was not happy with the shop that went down this road before looking into the paperwork. Wow, I’m sure I got a J 1983. Sent from my iPhone using Tapatalk
aviatoreb Posted May 27, 2020 Report Posted May 27, 2020 Just now, rcwagner said: Just make sure your M20J is 100% M20J. Mine was rebuilt with an M20L tail cone, and Garmin would not create an STC for my aircraft. They found out about it after they were about 90% installed. Had to remove it and I ended up with an STEC 55X. The STEC works fine, but I was not happy with the shop that went down this road before looking into the paperwork. Wow - what a nightmare. :-( What is the difference between a M20L tailcone and a M20J tailcone and how did you end up with it?
ArtVandelay Posted May 27, 2020 Report Posted May 27, 2020 Just make sure your M20J is 100% M20J. Mine was rebuilt with an M20L tail cone, and Garmin would not create an STC for my aircraft. They found out about it after they were about 90% installed. Had to remove it and I ended up with an STEC 55X. The STEC works fine, but I was not happy with the shop that went down this road before looking into the paperwork. I have hard time blaming the shop, I’ve never heard of such a thing.
jonhop Posted May 28, 2020 Report Posted May 28, 2020 On 5/25/2020 at 2:50 PM, Bob - S50 said: But a G5 will NOT run a KFC150 or a KAP150. I thought a pair of G5's could drive a KFC or KAP 150 since Garmin's introduction of the GAD 29B. https://www.garmin.com/en-US/blog/aviation/third-party-autopilot-support-for-g5-expanded/ It's an old article but there are several avionics shops that advertises a G5, GMU 11, and GAD 29B DG/HSI combo that supports many third party autopilots. BK's KAP/KFC 150 autopilots are on the list. What am I missing?
Andy95W Posted May 28, 2020 Report Posted May 28, 2020 The G5/GAD-29 will interface with the KAP 150 for navigation only, not for attitude input. To get that you’d need a 275 or an Aspen. 3
Bob - S50 Posted May 28, 2020 Report Posted May 28, 2020 To add to that, that is to say, you can use a G5 as an HSI for those autopilots but it will not work as an ADI. 1
