flysamo Posted May 20, 2020 Report Posted May 20, 2020 GRAMIN 275 PLANS UPGRADE AUTO PILOT FUNCTION BY ADDING G500 auto pilot function SOME TIME IN AUGUST, NOT SURE WHAT ELSE will be added
aviatoreb Posted May 20, 2020 Report Posted May 20, 2020 41 minutes ago, flysamo said: GRAMIN 275 PLANS UPGRADE AUTO PILOT FUNCTION BY ADDING G500 auto pilot function SOME TIME IN AUGUST, NOT SURE WHAT ELSE will be added Did you mean adding GFC500 autopilot functions?
flysamo Posted May 20, 2020 Author Report Posted May 20, 2020 (edited) yep gfc 500, what else be available for hook up unknown Edited May 20, 2020 by flysamo added info
jamesm Posted May 22, 2020 Report Posted May 22, 2020 Why not have the GI 275 have a turn coordinator screen/ function that shows heading degrees per second and many other screens. Make STC or PMA to replace the Turn Coordinator so those of us that have the dual G5's could get rid of the mechanical gyro turn coordinator. The no more annoying mechanical gyro sound grinding sound .
jonhop Posted May 23, 2020 Report Posted May 23, 2020 Replaced my Turn Coordinator with one G5. Do you have your Turn Coordinator running an autopilot? If not, I don't see why you can't remove it.
carusoam Posted May 23, 2020 Report Posted May 23, 2020 James, The TC is dead... The reason we have it... AIs were too expensive to have two... Times have changed... TCs when they are new don’t make very good back-up devices... Stress + TC + IMC often = tragedy... (example V-tail sprinkled all over NY neighborhood) TCs when they have a few hours on them don’t work in turbulence.... impossible to follow as a primary device for keeping the clean side up... (try it with your own on a bumpy day) Lance Casper Recently posted an AI with a device that added a ball... You don’t need a TC if you have a second AI... The second AI is a much better device, over Time, and in bumps... The ball gets added so you can keep turns coordinated... As far as timed turns go... select the speed for standard rate turns and match the angle of bank as required... (Something like 90kias and 17°... 15 would be close enough...) nobody ever fell out of the sky when their timed turn ran long... TCs that run the AP often get mounted Out of view... if the panel becomes too full... PP thoughts only, not a CFI... stuff I read about on MS. Best regards, -a- 1
jamesm Posted May 23, 2020 Report Posted May 23, 2020 my point is that these newer devices are programmable and you can make them be what every you want them to be as long as sensors providing them into digital format to be display. I would agree that the TC is dead.... but as I understand it with a Dual G5 Setup you can't replace both primary AI and TC with dual G5's as I recall it is in the STC unless later revision(s) has changed that. I my case I see the TC position a wasted space . 1
louisut Posted May 23, 2020 Report Posted May 23, 2020 (edited) 16 hours ago, jamesm said: Why not have the GI 275 have a turn coordinator screen/ function that shows heading degrees per second and many other screens. Make STC or PMA to replace the Turn Coordinator so those of us that have the dual G5's could get rid of the mechanical gyro turn coordinator. The no more annoying mechanical gyro sound grinding sound . The GI 275 can replace the turn coordinator if the optional OAT sensor is installed. Two GI 275s with the OAT sensor and magnetometer installed can replace the whole six-pack. Edited May 23, 2020 by louisut 1
Hank Posted May 23, 2020 Report Posted May 23, 2020 1 hour ago, louisut said: The GI 275 can replace the turn coordinator if the optional OAT sensor is installed. Two GI 275s with the OAT sensor and magnetometer installed can replace the whole six-pack. Then what do you do with all of the empty space???
Ragsf15e Posted May 23, 2020 Report Posted May 23, 2020 10 minutes ago, Hank said: Then what do you do with all of the empty space??? I’m not fully versed in the stc, but I think you still gotta keep the asi, alt, vsi and tc (or backup adi for tc). Unlike the g3x which allows removing the old instruments.
Ragsf15e Posted May 23, 2020 Report Posted May 23, 2020 So sure, the gi275 can display all the info from all those gages (just like a g5), and you can even replace your altimeter or asi with one, but you’re still gonna have old school dedicated instruments. This from the stc on garmins website, but it’s still not 100% clear as it does make it seem another gi275 can provide required backup... “Except for installations that are limited to VFR, GI 275 systems require standby attitude, altitude, and airspeed instruments. Several types of standby instruments might be installed, including a standby GI 275 ADI, other ADI, or individual analog instruments. “
louisut Posted May 23, 2020 Report Posted May 23, 2020 (edited) 4 hours ago, Ragsf15e said: So sure, the gi275 can display all the info from all those gages (just like a g5), and you can even replace your altimeter or asi with one, but you’re still gonna have old school dedicated instruments. This from the stc on garmins website, but it’s still not 100% clear as it does make it seem another gi275 can provide required backup... “Except for installations that are limited to VFR, GI 275 systems require standby attitude, altitude, and airspeed instruments. Several types of standby instruments might be installed, including a standby GI 275 ADI, other ADI, or individual analog instruments. “ When one is installed as primary ADI and the second as a primary HSI/backup ADI, then the the standby instrument requirement is satisfied. With the OAT sensor, it can be primary turn coordinator as well; small markers for standard rate turns appear on the roll scale above a certain airspeed. So yes, it replaces all six instruments. I beat this to death with both my installer and Garmin support. It's not what the website depicts, but that's the text in the STC and installation manual. I haven't seen the installation manual myself, but that's not for lack of trying... 5 hours ago, Hank said: Then what do you do with all of the empty space??? We kept the airspeed and altitude indicators for lack of better use for the space, but they were not required. I use the ASI mainly as a TAS calculator now, which curiously the GI 275 does not display (though it does record). Done again, I'd remove the altimeter and keep the VSI. The speed and altitude tapes were easy to get used to. The VSI is clear but small. I think a standard gauge is easier to read and observe trends. Also, don't know if I'm a fan of how it displays 100 fpm in tenths, i.e. 500 fpm is displayed as 0.5. Edited May 23, 2020 by louisut 2
Ragsf15e Posted May 23, 2020 Report Posted May 23, 2020 30 minutes ago, louisut said: When one is installed as primary ADI and the second as a primary HSI/backup ADI, then the the standby instrument requirement is satisfied. With the OAT sensor, it can be primary turn coordinator as well; small markers for standard rate turns appear on the roll scale above a certain airspeed. So yes, it replaces all six instruments. I beat this to death with both my installer and Garmin support. It's not what the website depicts, but that's the text in the STC and installation manual. I haven't seen the installation manual myself, but that's not for lack of trying... We kept the airspeed and altitude indicators for lack of better use for the space, but they were not required. I use the ASI mainly as a TAS calculator now, which curiously the GI 275 does not display (though it does record). Done again, I'd remove the altimeter and keep the VSI. The speed and altitude tapes were easy to get used to. The VSI is clear but small. I think a standard gauge is easier to read and observe trends. Also, don't know if I'm a fan of how it displays 100 fpm in tenths, i.e. 500 fpm is displayed as 0.5. Nice! Yeah I read the stc several times and was still a bit unsure. I did dual G5s just before the 275 came out. I wish I would’ve known about the 275 because I would have liked to keep the round gages and flush panel. My G5s are great, but there’s always something just a little better. How much did the 2x275s cost installed?
louisut Posted May 23, 2020 Report Posted May 23, 2020 1 minute ago, Ragsf15e said: Nice! Yeah I read the stc several times and was still a bit unsure. I did dual G5s just before the 275 came out. I wish I would’ve known about the 275 because I would have liked to keep the round gages and flush panel. My G5s are great, but there’s always something just a little better. How much did the 2x275s cost installed? $16k altogether pretax with no synthetic vision. For reference, the same installer quoted $11.5k for dual G5s. I'm also not convinced we needed the autopilot interface on both units. If not, then it could have been $1k less. They're still new and so shops are still trying to figure them out.
Ragsf15e Posted May 23, 2020 Report Posted May 23, 2020 My dual g5s were ~$11k without tax. Removing all the old King hsi, wiring, and components was some of that. Yeah, I guess I wouldve been hesitant for $5k more, but I definitely like their look better in the panel.
flysamo Posted May 24, 2020 Author Report Posted May 24, 2020 (edited) Ovation with Garmin 275 up grade cost, ready in about 2 weeks, installing GI 275 pfd/AP and GI275 hsi w/gmu-11, hsi, remove ki-256 and kcs-55a systems, adapter plate for gi275, relocating kt-74 transponder, connecting inputs to GTN 750 and inpute's to kfc auto pilot and navagators, remove old clock install mid cont. md93h clock/usb charging port high power, remove vacuum and standby vacuum systems, add bose aircraft power outlet. price about 16K, we were told more auto pilot updates in August. Edited May 24, 2020 by flysamo added info 1
LANCECASPER Posted May 24, 2020 Report Posted May 24, 2020 22 minutes ago, flysamo said: Ovation with Garmin 275 up grade cost, ready in about 2 weeks, installing GI 275 pfd/AP and GI275 hsi w/gmu-11, hsi, remove ki-256 and kcs-55a systems, adapter plate for gi275, relocating kt-74 transponder, connecting inputs to GTN 750 and inpute's to kfc auto pilot and navagators, remove old clock install mid cont. md93h clock/usb charging port high power, remove vacuum and standby vacuum systems, add bose aircraft power outlet. price about 16K, we were told more auto pilot updates in August. Wow that's a lot of work for that estimate - good job!
flysamo Posted May 27, 2020 Author Report Posted May 27, 2020 in addition the gyro package KG 102 has also been removed, this was the second gyro package that was installed, about 10 years ago, think i paid paid $3600 for a new unit back then, when it was replaced. weight & balance change. looks a little bit empty in the electronics rack in the back of the aircraft. The advice is too wait for the GI275 interface for the auto pilots .
jamesm Posted May 27, 2020 Report Posted May 27, 2020 2 batteries wow that can't be light 28Vdc I am guessing. I guess I didn't realize that the Ovations had two batteries. Would it be great (but not cheap) we could switch over to Earth-X Batteries as replacement if they were STC'd/PMA'd.
LANCECASPER Posted May 27, 2020 Report Posted May 27, 2020 50 minutes ago, jamesm said: 2 batteries wow that can't be light 28Vdc I am guessing. I guess I didn't realize that the Ovations had two batteries. Would it be great (but not cheap) we could switch over to Earth-X Batteries as replacement if they were STC'd/PMA'd. You actually need the weight from the two batteries back there to help offset the big 6 cylinder engine up front on the M, R, S, TN and Ultras. 1
aviatoreb Posted May 27, 2020 Report Posted May 27, 2020 6 minutes ago, LANCECASPER said: You actually need the weight from the two batteries back there to help offset the big 6 cylinder engine up front on the M, R, S, TN and Ultras. And rocket. we have 19lb of lead in the far back too.
jamesm Posted May 27, 2020 Report Posted May 27, 2020 Wow I didn't know that, the long bodies carried so much dead weight in the back. So hypothetical speaking ..... From a design prospective and Money and FAA weren't part of the equation. If they had extend distance between the nose gear and the main gear would you still need the lead ? I am guessing it change the the pitch dynamic and handling of the airplane. Just curious.
carusoam Posted May 27, 2020 Report Posted May 27, 2020 James, Think of the design flexibility.... Do you want to install stuff back there? Would you like an O2 system? Swap out a lead brick... Would you like a Fiki system? Swap out some lead... How about A/C? More lead.... Did you put an MT prop up front? Better chuck some lead overboard... The engine mount at the front is extra long too... plenty of room up there. All the design add-ons that are possible... come after you have built thousands of similar planes before.... Like the refined M20C... The O is very similar to an M20C.... even more refined... Best regards, -a- 1
flysamo Posted May 28, 2020 Author Report Posted May 28, 2020 (edited) GI 275 unit has option for wiring for OAT probe, with this addition the turn coordinator , can be removed. addition of the sensor, wire and located under wing mounting runs about 1K. believe sensor is needed for min air speed signal, can any one up date need for this addition. looking at webinar from Garmin comparing the G5 size and the GI275. its easy to see just by the size difference that its a much different unit and the functions it does, as they state the 275 has a much greater growth capability. Edited May 28, 2020 by flysamo added info
