NotarPilot Posted October 16, 2019 Report Posted October 16, 2019 Does anyone know what would make this PFD have this red tint. Seems ready red upon turning on the master but goes reddish-pink as the unit warms up a bit. Quote
MIm20c Posted October 16, 2019 Report Posted October 16, 2019 Everything on the screens speed/position/attitude is still initiating so I’m guessing the pfd will turn red if enough systems are still off line. Probably to make sure the pilot starts looking somewhere else for the info. Quote
NotarPilot Posted October 16, 2019 Author Report Posted October 16, 2019 5 minutes ago, MIm20c said: Everything on the screens speed/position/attitude is still initiating so I’m guessing the pfd will turn red if enough systems are still off line. Probably to make sure the pilot starts looking somewhere else for the info. No, we have two AC with G500s and this one only started doing this recently progressively getting worse. The other one doesn’t do this on initialization and looks the normal colors. It also remains tinted red like this during flight. Quote
wishboneash Posted October 16, 2019 Report Posted October 16, 2019 Almost looks like a display driver hardware or software issue to me. Sent from my LM-V405 using Tapatalk 2 Quote
donkaye, MCFI Posted October 16, 2019 Report Posted October 16, 2019 Time to send it in for repair. 1 Quote
carusoam Posted October 16, 2019 Report Posted October 16, 2019 Typical color screen failure... Does it work normally and just suffer from bad color control? Or is there a larger problem, and the device isn’t working properly either? PP thoughts only, not an instrument tech... Best regards, -a- Quote
NotarPilot Posted October 16, 2019 Author Report Posted October 16, 2019 3 hours ago, carusoam said: Typical color screen failure... Does it work normally and just suffer from bad color control? Or is there a larger problem, and the device isn’t working properly either? PP thoughts only, not an instrument tech... Best regards, -a- Works fine except for the color issue. I’ll have to see if Garmin has a flat fee to fix the G500. 1 Quote
MIm20c Posted October 16, 2019 Report Posted October 16, 2019 12 minutes ago, NotarPilot said: Works fine except for the color issue. I’ll have to see if Garmin has a flat fee to fix the G500. Please share the cost when you find out. The Avidyne pfd’s are really expensive to repair, wondering where Garmin falls for repairs. Quote
NotarPilot Posted October 16, 2019 Author Report Posted October 16, 2019 5 hours ago, MIm20c said: Please share the cost when you find out. The Avidyne pfd’s are really expensive to repair, wondering where Garmin falls for repairs. Well one thing is for certain... it won’t be cheap. Quote
Baker Avionics Posted October 23, 2019 Report Posted October 23, 2019 On 10/16/2019 at 4:17 PM, NotarPilot said: Well one thing is for certain... it won’t be cheap. About $1500 flat rate repair per the Garmin Price Book Quote
Mark89114 Posted October 23, 2019 Report Posted October 23, 2019 45 minutes ago, Baker Avionics said: About $1500 flat rate repair per the Garmin Price Book I dont know if that is cheap or not anymore.... Quote
Baker Avionics Posted October 24, 2019 Report Posted October 24, 2019 On 10/22/2019 at 5:47 PM, Mark89114 said: I dont know if that is cheap or not anymore.... Not too bad!! Have your Avionics Shop go into Maintenance mode to see if it does it there as well. If not, have them replace the Config module. Weird issues like this can be caused by a bad config module. Just a shot Quote
NotarPilot Posted October 25, 2019 Author Report Posted October 25, 2019 15 hours ago, Baker Avionics said: Not too bad!! Have your Avionics Shop go into Maintenance mode to see if it does it there as well. If not, have them replace the Config module. Weird issues like this can be caused by a bad config module. Just a shot Thank you. Quote
jamesm Posted October 25, 2019 Report Posted October 25, 2019 On 10/22/2019 at 5:47 PM, Mark89114 said: I dont know if that is cheap or not anymore.... wow ... Garmin can't help a customer out :-O it is not as if that aren't making money off you already with nav data every 28 days. And to boot we the tax payers are subsidizing the data portion. I am certain that Garmin has some sort of data daemon the gets data formats puts it's on the server without human interaction. So only thing that Garmin is really paying for is the power and the server, network and maintenance. Oh I forgot some lawyer's salary and pension.;-] Quote
Baker Avionics Posted November 2, 2019 Report Posted November 2, 2019 On 10/25/2019 at 4:33 AM, jamesm said: wow ... Garmin can't help a customer out :-O it is not as if that aren't making money off you already with nav data every 28 days. And to boot we the tax payers are subsidizing the data portion. I am certain that Garmin has some sort of data daemon the gets data formats puts it's on the server without human interaction. So only thing that Garmin is really paying for is the power and the server, network and maintenance. Oh I forgot some lawyer's salary and pension.;-] I am sorry about that, maybe look at alternatives. There are some out there. Quote
