Ok everybody I need more assistance.I am needing a boot for the Johnson bar and don’t know where to find one.Does anybody have a direction to send me? I looked on aircraft spruce to no avail
Seems like around 50 bucks, but I can't be sure. The other place would be aero comfort in San Antonio. The one from LASAR is fabric while the one Aero Comfort is leather, I went fabric due to the lack of clearance between the J-Bar and the front wheel well
Years ago, I needed one and bought it from LASAR. It was fabric and one of (very) few things I did not like from them. I ended up returning it and had my wife saw one using soft leather from old jacket. I still have it in my plane and it is looking great. YMMV.
Bill,
Things to consider regarding the J-bar...
1) It is an opening from the outside, into the cabin...
2) Outside consists of possibilities of cold air, and CO...
3) To close the opening, while allowing the J-bar to operate, is something called a boot. A piece of fabric or rubber similar to the thing that goes around the base of a car’s stick shift... for the same reasons... and ties pretty tightly at the top.
4) it is functional first, and decorative second...
5) there are a few suppliers of this piece. They have taken into consideration shape and size, to not get in the way of the physical operation....
6) Select the best one... to keep the outside from coming in through that channel, and not get in the way of the J-bar operation...
7) Use caution selecting a too low cost fabric one that isn’t able to keep the outside from coming in... select a fabric that is coated or somehow keeps the outside, outside...
No really outside more like the belly of the beast. I think there are documented instances where something has fallen into the opening where the boot was missing or damaged and jammed the aileron control rods which are very close to the J-bar under the floor
I agree. I am doing the same thing. Was more like suit fabric but a Lasar is usually my go to source. Dan is great.
My number one concern with this boot would be how well does it prevent Wasps, hornets and bees out of my cockpit!
Since those insects are known for cutting through metal screens....
Consider soaking the boot in a proper anti-bug fluid...
Do you really have an insect problem there?
So far so good (3 years). Not sure what the material is but I'm sure if you contacted LASAR they would know
10 hours ago, ArtVandelay said:
You should carefully check your tail sometimes as well.
Tom
When one creeps out, do I strike up a conversation and ask
if they would kindly vacate the premises? I think I’d die
