ArtVandelay Posted December 16, 2017 Report Posted December 16, 2017 I had a conversation with Mr. Wheat many years ago and he related that he went into and held a spin for 6 turns in a Mooney and said he'd never do that again. You can't spin if you don't stall. Airspeed, airspeed, airspeed! Except during training? Quote
Hank Posted December 16, 2017 Report Posted December 16, 2017 7 hours ago, teejayevans said: Except during training? Now, in training and on checkrides, we are supposed to recover at the hirn or the onset of buffet, not hold it until it breaks. Quote
cliffy Posted December 16, 2017 Report Posted December 16, 2017 For my commercial ride I had a retired FAA GADO manager give it to me and all he wanted to do was spins in my Cessna 140. 3 spins and 1 eights on pylons and he said I was done and signed me off. But that was 5 decades ago. 1 Quote
aviatoreb Posted December 16, 2017 Report Posted December 16, 2017 On 12/9/2017 at 2:20 PM, Raptor05121 said: Hypothetical situation. You're in a spin in your Mooney. Disregarding ability to reach the gear, more pressing issues, altitude, etc etc etc: Would it be aerodynamically advantageous to lower the gear or leave it up? Back story on the Piper Forums, I've never heard of this: Why would a person be messing around with the gear lever while correcting an inadvertent spin. Might as well take a quick check of your pulse-ox during the spin too. Quote
Piloto Posted December 16, 2017 Report Posted December 16, 2017 18 minutes ago, aviatoreb said: Why would a person be messing around with the gear lever while correcting an inadvertent spin. Might as well take a quick check of your pulse-ox during the spin too. Or must likely use the pilot relief tube. 3 Quote
cliffy Posted December 16, 2017 Report Posted December 16, 2017 This is how a plane should handle spins! I've talked with these guys ( in fact the guy in the right seat) and this airplane may be a game changer when it comes out. BTW they got their butt in a little sling by doing this. 2 Quote
Piloto Posted December 16, 2017 Report Posted December 16, 2017 Nice video. Noticed the lag of the attitude indicator after spin recovery. This does not happens with a turn coordinator. José 1 Quote
aviatoreb Posted December 16, 2017 Report Posted December 16, 2017 35 minutes ago, Piloto said: Or must likely use the pilot relief tube. NAH - not me. If I inadvertent spin - then if I need to pee while I am working to correct the spin - ill either hold it. or Ill just pee. You can keep your relief tube eh.... haha Quote
Hank Posted December 16, 2017 Report Posted December 16, 2017 Interesting vapor trails coming from the wingtios starting in spin #8. What's up with that? Only noticed them on tbe view from the tail. 1 Quote
carusoam Posted December 16, 2017 Report Posted December 16, 2017 I couldn't tell... is there a lag on the AI or just so much data whizzing by every second the lag is more behind my eyes than in front... The last video from the tail is interesting... water vapor is streaming from the wing tips... a sign of low pressure (lift?) knocking water out of solution... With such a fast stall recovery, it looks as though the Pipistrel wing design keeps the wing tip section with airlerons from stalling, or recovers very quickly..(?) Four people riding in a stalling airplane takes a lot of planning and preparation and testing to prove the results...long before boarding... best regards, -a- Quote
EricJ Posted December 16, 2017 Report Posted December 16, 2017 1 hour ago, Hank said: Interesting vapor trails coming from the wingtios starting in spin #8. What's up with that? Only noticed them on tbe view from the tail. Descended into some humid air, I think. Or maybe that's where the exit is for the relief tubes. Quote
cliffy Posted December 16, 2017 Report Posted December 16, 2017 Probably tested with aft CG with weights BEFORE passengers Quote
Hank Posted December 16, 2017 Report Posted December 16, 2017 4 hours ago, cliffy said: Probably tested with aft CG with weights BEFORE passengers God, I would hope so!! This was supppsed to be after the airplane completed spin certification, anyone know the W&B range required for that? Quote
M016576 Posted December 16, 2017 Report Posted December 16, 2017 On 12/10/2017 at 3:36 PM, squeaky.stow said: If you are in a spin, you are stalled. Your priority is to reduce the angle of attack to get the wing flying again. That means full down elevator and some patience. Stopping the autorotation if you can with full opposite rudder and idle power will Sent from my iPhone using Tapatalk Full down elevator will not help in some aircraft... the F-15, for example, will not recover from a spin with full forward stick. Recovery procedures vary by airframe... most say to neutralize the controls, then apply full opposite rudder. In some aircraft, rudder may not help... and Aileron is required. It all depends on the jet/plane. To say “full down elevator and some patience” is a pretty broad statement, that isn’t very accurate. Quote
Piloto Posted December 17, 2017 Report Posted December 17, 2017 (edited) 8 hours ago, Hank said: Interesting vapor trails coming from the wingtios starting in spin #8. What's up with that? Only noticed them on tbe view from the tail. The wingtip trails are the fuel coming out of the wing tank vents due to centrifugal forces and low wind impact velocity on the vents.. When low on fuel the fuel may un port from the tank fuel pick up during a spin. Aerobatic planes have a flop fuel pick up hose that follows the fuel. José Edited December 17, 2017 by Piloto 1 Quote
squeaky.stow Posted December 21, 2017 Report Posted December 21, 2017 On 2017-12-16 at 5:54 PM, M016576 said: Full down elevator will not help in some aircraft... the F-15, for example, will not recover from a spin with full forward stick. Recovery procedures vary by airframe... most say to neutralize the controls, then apply full opposite rudder. In some aircraft, rudder may not help... and Aileron is required. It all depends on the jet/plane. To say “full down elevator and some patience” is a pretty broad statement, that isn’t very accurate. Agreed that fighters can require some very different techniques for spin recovery. This is partly because of the ratio of fuselage mass to wing mass (which is the opposite of GA aircraft design) and the partly because of the effect of fly by wire flight control computers on the pilot's control inputs. There is some good literature available on the topic of fighter aerodynamics, but none of this is really relevant to the question which this thread began with which is the discussion of spin recovery in a GA aircraft like the Mooney. The Mooney POH is pretty clear (at least for my K) Don't do them. But if you do end up in one: 1) Full opposite rudder. 2) Control wheel forward (as much as it takes to break the stall. 3) Ailerons neutral. 4) Throttle idle. Deviate from this advice and you are now a test pilot. But not the cool kind. Other than slight variations on the order of the above steps, I have never seen a GA aircraft (canards excepted) that had any other spin recovery procedure recommended by the manufacturer. Quote
M016576 Posted December 22, 2017 Report Posted December 22, 2017 22 hours ago, squeaky.stow said: Agreed that fighters can require some very different techniques for spin recovery. This is partly because of the ratio of fuselage mass to wing mass (which is the opposite of GA aircraft design) and the partly because of the effect of fly by wire flight control computers on the pilot's control inputs. There is some good literature available on the topic of fighter aerodynamics, but none of this is really relevant to the question which this thread began with which is the discussion of spin recovery in a GA aircraft like the Mooney. The Mooney POH is pretty clear (at least for my K) Don't do them. But if you do end up in one: 1) Full opposite rudder. 2) Control wheel forward (as much as it takes to break the stall. 3) Ailerons neutral. 4) Throttle idle. Deviate from this advice and you are now a test pilot. But not the cool kind. Other than slight variations on the order of the above steps, I have never seen a GA aircraft (canards excepted) that had any other spin recovery procedure recommended by the manufacturer. The F-15C is a mechanical flight control system, not digital fly by wire like the hornet and super hornet. I’ve flown all 3- the recoveries are similar for departure spin despite the fact the F-15 is mechanical and the F-18 is digital fly by wire. But you are correct, a fighter is different than a GA piston. pushing the yoke/control wheel/stick full forward will increase the rotation rate in many aircraft, light GA included. the mooney says “forward of nuetral” which does not say full forward. The bonanza A35 does say full forward, though. The baron says ease yoke back pressure , Seneca is similar (although with twins the cg and weight distribution changes things a little). Back to the original comment, though: you said “full down elevator and some patience.” That is not the written procedure in a mooney- and will actually increase your rotation rate, and could delay the spin recovery. Like you said- test pilot, but not the cool kind. Quote
Bob - S50 Posted December 22, 2017 Report Posted December 22, 2017 Off topic, and just as an aside, the F15 actually has both mechanical and fly by wire. If the stick gets jammed, you can still fly it by applying pressure to the stick. If the electrics die, you can still fly by moving the stick. I've been told that the fly by wire is quicker so that is what usually moves the controls. Agreed though that fighters often use different control inputs to exit a spin. 1 Quote
M016576 Posted December 23, 2017 Report Posted December 23, 2017 (edited) 10 hours ago, Bob - S50 said: Off topic, and just as an aside, the F15 actually has both mechanical and fly by wire. If the stick gets jammed, you can still fly it by applying pressure to the stick. If the electrics die, you can still fly by moving the stick. I've been told that the fly by wire is quicker so that is what usually moves the controls. Agreed though that fighters often use different control inputs to exit a spin. That is true- but it’s not really fly by wire... or at least it’s not reall digital fly by wire as it’s applied in the F-18. The system is called “CAS” or Control Augmentation System. The CAS is an overlay on the mechanical system which allows for slightly more rudder and stabilator deflection. Its applied through a force sensor in the stick. The CAS tends to “fall offline” during aggressive maneuvering of the jet.... if that were to occur in an F-18 or F-16, the jet would depart controlled flight- in the eagle, you just lose a little instantaneous turn performance and a little departure resistance. But you’re correct- my statement above wasn’t wholly accurate- the F-15 does have an augmentation system. the F-15E has a digital flight control system, similar to the F/A-18. I’ve never flown the E model eagle, but supposedly it flys very nicely. I can’t validate that the CAS moves the jet before the mechanical controls - but I do know that the CAS cannot fully deflect the stabs. Edited December 23, 2017 by M016576 Quote
Hank Posted December 24, 2017 Report Posted December 24, 2017 2 hours ago, Mcstealth said: What is PARE? Isn't it Power (to idle), Ailerons (wings level), Rudder (opposite spin direction), Elevator (to recover from dive when spin stops)? I don't do aerobatics and have no spin training, but that's what I recall. 2 Quote
Mcstealth Posted December 24, 2017 Report Posted December 24, 2017 If I was taught that, I don' remember it. Thanks. Quote
Hank Posted December 25, 2017 Report Posted December 25, 2017 17 hours ago, Mcstealth said: If I was taught that, I don' remember it. I've never been taught spins either, it is all ground-based self education. Judging by the reaction above, I got it right. It's certainly something to NOT practice in your Mooney! 1 Quote
squeaky.stow Posted December 25, 2017 Report Posted December 25, 2017 On 2017-12-21 at 8:17 PM, M016576 said: That is not the written procedure in a mooney- and will actually increase your rotation rate, and could delay the spin recovery. Do you have a reference source for this? The part about increasing your rotation rate I mean. I agree that my "full down and patience" was pretty generic. The actual Mooney POH says "Control Wheel......FORWARD of neutral in a brisk motion. Additional FORWARD elevator control may be required if the rotation does not stop." In other words Mooney appears to be saying that more nose down may be required to stop the rotation, not less. I have never spun a Mooney and don't plan to try, but I have done literally hundreds of spins in aircraft that are certified to do so, and one inadvertent one in an aircraft that was most emphatically NOT certified for spins. (F-5) What I can tell you from that experience is that the longer you remain in a fully developed spin, the more likely it is to flatten out due to rotational inertia, and the more it flattens out, the more forward elevator you will need and the longer it will take to recover, hence my generic comment about full down and patience. Whether or not an GA single is certified for spins depends largely on whether the flight controls can generate enough aerodynamic force to overcome the combined forces of CG location and the gyroscopic inertia functioning in a spin. A tail that is too small, has limited control surface authority, or is blanked aerodynamically by its position (some T-tails) may not be able to do this. For those interested in PARE and a great summary of spin aerodynamics, here is a good source with lots of additional references: https://en.m.wikipedia.org/wiki/Spin_(aerodynamics) M016576, you have me curious about how you ended up flying both the Eagle and Hornet/Super Hornet. Did you go from the USAF to Naval Reserves, or do an exchange or something? I have always been envious of the American Guard and Reserve programs. My F-16 time came courtesy of an exchange tour with the USAF, but you don't often meet someone who has flown both USAF and Navy types. Oh, and Merry Christmas to everyone on Mooneyspace! As a newbie Mooney owner, this forum has been an incredibly valuable source of information. I would never have known about WeepNoMore or LOP or so many other technical issues without you folks. And Happy New Year. Regards, Mark 1 Quote
M016576 Posted December 26, 2017 Report Posted December 26, 2017 (edited) 8 hours ago, squeaky.stow said: Do you have a reference source for this? The part about increasing your rotation rate I mean. I agree that my "full down and patience" was pretty generic. The actual Mooney POH says "Control Wheel......FORWARD of neutral in a brisk motion. Additional FORWARD elevator control may be required if the rotation does not stop." In other words Mooney appears to be saying that more nose down may be required to stop the rotation, not less. I have never spun a Mooney and don't plan to try, but I have done literally hundreds of spins in aircraft that are certified to do so, and one inadvertent one in an aircraft that was most emphatically NOT certified for spins. (F-5) What I can tell you from that experience is that the longer you remain in a fully developed spin, the more likely it is to flatten out due to rotational inertia, and the more it flattens out, the more forward elevator you will need and the longer it will take to recover, hence my generic comment about full down and patience. Whether or not an GA single is certified for spins depends largely on whether the flight controls can generate enough aerodynamic force to overcome the combined forces of CG location and the gyroscopic inertia functioning in a spin. A tail that is too small, has limited control surface authority, or is blanked aerodynamically by its position (some T-tails) may not be able to do this. For those interested in PARE and a great summary of spin aerodynamics, here is a good source with lots of additional references: https://en.m.wikipedia.org/wiki/Spin_(aerodynamics) M016576, you have me curious about how you ended up flying both the Eagle and Hornet/Super Hornet. Did you go from the USAF to Naval Reserves, or do an exchange or something? I have always been envious of the American Guard and Reserve programs. My F-16 time came courtesy of an exchange tour with the USAF, but you don't often meet someone who has flown both USAF and Navy types. Oh, and Merry Christmas to everyone on Mooneyspace! As a newbie Mooney owner, this forum has been an incredibly valuable source of information. I would never have known about WeepNoMore or LOP or so many other technical issues without you folks. And Happy New Year. Regards, Mark Mark- I should be clear on this: I’m not a mooney test pilot, nor have I spun a mooney. Upon reading my above posts- I come off as more of the “authority” on this subject than I am. However, like you, I’ve spun multiple aircraft, albeit all in a military setting. The only prop aircraft I’ve spun is the T-34C. here are two sources regarding elevator position in relation to spins, and spins in general- the first is very generic, the second is a NASA paper that is far more in depth. On the NASA paper, read the “elevator effectiveness” section, or just the whole thing- it’s a good read. https://www.aopa.org/news-and-media/all-news/2010/june/03/spin-myths the key I’ve found in my experience is to know the jet or plane you’re flying and to follow the written procedure. Full forward during the incipient phases can tighten up your spin (initially, although if rudder is applied, should in general break the stall, depending on the mode... but yes certainly not the first move), or worse: invert you. so I guess both of us have made some generalities in this topic- as it’s pretty much inevitable to do- but full forward and patience, is not the written procedure and would not be where I’d choose to start my recovery. Instead I’d go with the recovery procedure outlined in the book. I started in the US Navy- Flew Super Hornets, then Hornets for 12 years. I left the Navy and was “hired” by the Air National Guard as a F-15C instructor pilot. I’ve been doing that for just over 6 years now. The Guard is a pretty interesting operation: a mix between USAF, Navy, Marines and “guard babies.” Makes for a diverse cultural dynamic. I’m very lucky to be the “token” navy guy in my unit- it’s been a great ride! Edited December 26, 2017 by M016576 Quote
