rbridges Posted November 30, 2017 Report Share Posted November 30, 2017 It's happened twice in the last handful of flights. Turn key and it sounds like it didn't "grab." Immediately turn key a second time and everything is normal. I just don't want to be left stranded and I don't know how fast they start going downhill. Quote Link to comment Share on other sites More sharing options...
RLCarter Posted November 30, 2017 Report Share Posted November 30, 2017 Lube the bendix 1 Quote Link to comment Share on other sites More sharing options...
201er Posted November 30, 2017 Report Share Posted November 30, 2017 Just now, rbridges said: It's happened twice in the last handful of flights. Turn key and it sounds like it didn't "grab." Immediately turn key a second time and everything is normal. I just don't want to be left stranded and I don't know how fast they start going downhill. Before you run and throw money at the starter, makes sure it's not the impulse coupling in the mag that's causing the problem. 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted November 30, 2017 Report Share Posted November 30, 2017 If you hear the starter spinning, but don’t have the engine turning it’s the Bendix not engaging, not the impulse coupling. If however the engine is turning but it won’t start it’s a different matter. Clarence Quote Link to comment Share on other sites More sharing options...
rbridges Posted December 1, 2017 Author Report Share Posted December 1, 2017 It's like a buzzing. Definitely doesn't sound like engine turning. Prop isn't moving if that matters. Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted December 1, 2017 Report Share Posted December 1, 2017 Starter relay would explain buzzing, Bendix not engaging is a distinctive whirring sound. 1 Quote Link to comment Share on other sites More sharing options...
Marauder Posted December 1, 2017 Report Share Posted December 1, 2017 It's like a buzzing. Definitely doesn't sound like engine turning. Prop isn't moving if that matters. Lube baby lube. Normally people are using silicon spray which I did for years. After a period of time I would need to spray it again. 3 years ago I used a little bit of Deep Creep and it has been fine ever since. Sent from my iPhone using Tapatalk Pro 1 Quote Link to comment Share on other sites More sharing options...
rbridges Posted December 1, 2017 Author Report Share Posted December 1, 2017 Thanks. I'll listen closer next time to see if it is a buzzing or whirring. Quote Link to comment Share on other sites More sharing options...
rbridges Posted December 1, 2017 Author Report Share Posted December 1, 2017 Silicone spray for the Bendix? Quote Link to comment Share on other sites More sharing options...
Guest Posted December 1, 2017 Report Share Posted December 1, 2017 7 minutes ago, rbridges said: Thanks. I'll listen closer next time to see if it is a buzzing or whirring. If your starter looks like this, then lube is a first step. Quote Link to comment Share on other sites More sharing options...
Marauder Posted December 1, 2017 Report Share Posted December 1, 2017 Lube it right here. 2 Quote Link to comment Share on other sites More sharing options...
EricJ Posted December 1, 2017 Report Share Posted December 1, 2017 So, the lube goes on the tip? 2 2 Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted December 1, 2017 Report Share Posted December 1, 2017 You want to get the lube into the guts. You want silicone because it doesn't attract dirt as much. Quote Link to comment Share on other sites More sharing options...
DXB Posted December 1, 2017 Report Share Posted December 1, 2017 2 hours ago, rbridges said: It's like a buzzing. Definitely doesn't sound like engine turning. Prop isn't moving if that matters. Isn't the buzzing just the shower of sparks most likely? If so, it would sound the same if you turn ignition without pushing in (i.e. sending power to starter). I suspect lube advice above is correct, but I had identical issue once from a loose contact on ignition switch. 4 Quote Link to comment Share on other sites More sharing options...
rbridges Posted December 1, 2017 Author Report Share Posted December 1, 2017 The more I think about it, it may have been the bendix not engaging. I'm going to lube the area and pay more attention if it happens again. Quote Link to comment Share on other sites More sharing options...
BKlott Posted December 1, 2017 Report Share Posted December 1, 2017 I’m on my second starter for this airplane which I have owned for sixteen years and counting. Like everyone has suggested, there are a number of other components which could be the cause of your issue other than the condition of the starter itself. My last starter gave no indication that it was about to go and I got stranded on a $100 hamburger run. “Honey, can you come get me?” Boy did that turn out to be an expensive hamburger! Short of picking some arbitrary replacement interval like 8 to 10 years or a certain number of starts / flights, I don’t know how else you could do it. There is some advantage to building in reliability to try to avoid inconveniences but that can get real expensive too. Quote Link to comment Share on other sites More sharing options...
Marauder Posted December 1, 2017 Report Share Posted December 1, 2017 So, the lube goes on the tip? Nope. Look for the shaft with the gear on the end of it. That is the shaft you want to lubricate. Sent from my iPhone using Tapatalk Pro 1 Quote Link to comment Share on other sites More sharing options...
EricJ Posted December 1, 2017 Report Share Posted December 1, 2017 2 minutes ago, Marauder said: Nope. Look for the shaft with the gear on the end of it. That is the shaft you want to lubricate. Lube the shaft, not the tip. Got it. 2 4 Quote Link to comment Share on other sites More sharing options...
Piloto Posted December 1, 2017 Report Share Posted December 1, 2017 Check battery connections and no load voltage, it should be at least 12V. 2 Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted December 1, 2017 Report Share Posted December 1, 2017 1 hour ago, BKlott said: I’m on my second starter for this airplane which I have owned for sixteen years and counting. Like everyone has suggested, there are a number of other components which could be the cause of your issue other than the condition of the starter itself. My last starter gave no indication that it was about to go and I got stranded on a $100 hamburger run. “Honey, can you come get me?” Boy did that turn out to be an expensive hamburger! Short of picking some arbitrary replacement interval like 8 to 10 years or a certain number of starts / flights, I don’t know how else you could do it. There is some advantage to building in reliability to try to avoid inconveniences but that can get real expensive too. Fortunately most starter failure modes include a while of poor starting before they die. Usually you get a bad spot on the motor and have to try a few times. I replaced mine with a SkyTech about 15 years ago. When I've had issues I send it back to them and am always amazed how inexpensive their repair service is. So maybe this is the last starter Ill buy, just send it to them every 5 years or so to give it the once over. When I'm flying the Cessna fleet with their 24 volt systems its always amazing how much better the starters are. I think you could fly on the speed it spends the prop! Even the T206H spins I'm sure it registers on the tach. -Robert Quote Link to comment Share on other sites More sharing options...
Sean S Posted December 1, 2017 Report Share Posted December 1, 2017 For factory starter on my F, the correct lube is a mix of kerosene and graphite on the shaft. Quote Link to comment Share on other sites More sharing options...
carusoam Posted December 1, 2017 Report Share Posted December 1, 2017 My 65C lived outdoors... a couple of times per year you would hear the whizzzz of the starter but nothing else was happening... Spray the Bendix shaft with the lube... you will probably see some rust in the area as well. See rust? Spray it with lube... At annual, that gets lubed... Funny memories of a PP only, not a mechanic... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Raptor05121 Posted December 1, 2017 Report Share Posted December 1, 2017 17 hours ago, 201er said: Before you run and throw money at the starter, makes sure it's not the impulse coupling in the mag that's causing the problem. C's don't have impulse couplings. Those peasant systems are reserved for Cherokees and some of you silly J models 2 2 Quote Link to comment Share on other sites More sharing options...
201er Posted December 1, 2017 Report Share Posted December 1, 2017 Just now, Raptor05121 said: C's don't have impulse couplings. Those peasant systems are reserved for Cherokees and some of you silly J models Are you serious? What is it? Shower of sparks? Quote Link to comment Share on other sites More sharing options...
ShuRugal Posted December 1, 2017 Report Share Posted December 1, 2017 Mine does this about once every 4-5 starts. Solved it by hosing the bendix gear down with TriFlow. Quote Link to comment Share on other sites More sharing options...
