On 2/25/2017 at 4:56 PM, N201MKTurbo said:
It's about 30K for a 4 cylinder so it would be about 180k.
And that era you'd probably expect to change at least one of those cylinders every 10-20 hours.
-Robert
-Robert
With that many cylinders, I wonder if you would even notice if one of them ate a valve, or went cold.
Can you imagine what the JPI screen would look like for this? Much less how many little round dials there would have been then . . . Don't think you'd be able to make heads or tails out if either readout set if flying single pilot IFR!  :huh:
Dad flew the KC-97 Stratotanker with P&W 28 cyl, 3500 hp engines and turbojets on the wing tips.
They carried a 55 gallon drum of oil. If an engine started taking oil, they would shut it down instead of using up their whole barrel.
