It helps if you have the model number and the manufacturer of the switch.
Aircraft Spruce has been able to get some from the switch OEMs.  The switch OEMs have their own outlets for selling switches singly...
expect that they are in the $200 bracket.  The specialized double switches will be dissapointingly more...
I have not found a way to just replace the plastic switch covers...
Does any of this sound familiar?
Hope that helps,
Superglue for the plastic portion works. I’ve had a few “new” superglue switches installed over the years. After that they seem to last forever and they are cheap!
  On 5/26/2016 at 10:48 PM, LANCECASPER said:
  On 5/26/2016 at 8:22 PM, Bravoman said:
2 hours ago, Bravoman said: Is there really an aviation aisle at Home Depot?
There is an aviation aisle at Home Depot, Lowes, True Value, etc . . .  Just kidding, the hangar elves many times do their shopping in these aisles.
No way - my Home Depot has an aviation aisle - in fact it's stocked by Santa himself every Christmas!
  • 7 months later...
  On 5/23/2016 at 11:15 PM, LANCECASPER said:
JB Weld from the Aviation aisle at Home Depot works well too
Expand
did you ever find a switch to replace the split rocker landing/taxi I have same problem but it's beyond glue needs replaced any info would be greatly appreciated been searching for a while
  • 2 weeks later...
I had great luck with LASAR today with getting replacements for my avionics master switch and my BAT 1/BAT 2 switch. If you have the part numbers they can look them up for you.
For aircraft serial numbers 27-0001 through 27-0257:
880052-521   switch, landing light
880052-523   switch, taxi light
