Supercop0184 Posted February 20, 2016 Report Share Posted February 20, 2016 As I delve into everything Mooney, in an attempt to learn as much about the aircraft as I can before making the purchase, I have a question I want to ask all you Mooney Professionals. I fly to several fly ins with grass runways. They are, what I would consider, well maintained runways. I just know that there does not seem to be just a whole lot of prop clearance on these aircraft. My grass requirements will be taxi-ing on the grass at Oshkosh north 40 every year, A Texas Fly In called Critters Lodge, A Texas fly in called Reklaw, and the Triple Tree Aerodrome Fly In. I am looking at M20Cs if it matters. Any opinions on this would be helpful! THANKS for all your help!!! Quote Link to comment Share on other sites More sharing options...
Hank Posted February 20, 2016 Report Share Posted February 20, 2016 I've not yet been to Triple Tree, but only because of schedule conflicts or weather. I do visit other grass strips in my C, and know of other Cs that are, or have been, based at grass strips. If it's in good shape, it's not a problem. Taxiing and parking in GAC at the approach end of 9 for Sun n Fun wasn't a problem. If you're curious what a C is capable of in the right hands, search YouTube for "piperpainter" and his red C, flying into backcountry strips with his tailwheel friends. Myself, I'm not that capable. There's 10" of prop clearance, and I doubt the nose wheel shock discs will compress much over 1/2" unless you really slam it down. Just watch out for pot holes . . . 1 Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted February 20, 2016 Report Share Posted February 20, 2016 If you have the later model Mooneys with the second gear door, remove them before landing on a grass strip. 3 Quote Link to comment Share on other sites More sharing options...
Supercop0184 Posted February 20, 2016 Author Report Share Posted February 20, 2016 SO this wont apply to a 60s model C? Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted February 20, 2016 Report Share Posted February 20, 2016 No, yours doesn't have them. I have landed on dirt and grass with no issue. Just be careful of where you run up. If there is loose rocks, sand or gravel, you want to keep moving while you run up to lessen the damage to your prop. 1 Quote Link to comment Share on other sites More sharing options...
Supercop0184 Posted February 20, 2016 Author Report Share Posted February 20, 2016 cool!!!! thanks! Quote Link to comment Share on other sites More sharing options...
Mooneymite Posted February 20, 2016 Report Share Posted February 20, 2016 (edited) I've operated a C model off of grass for about 18 years....no problem, BUT not all grass strips are appropriate....caution is advised. Taxi slowly and avoid the "bobbing nosewheel". Our turf runway is home to several Mooneys....never seems to be a problem with the lower gear doors on the newer models.... A prop-strike is not the only issue when landing (or aborting a takeoff) on grass. Getting stopped can be difficult! The braking coefficient of wet grass is less than on snow (MU= .20). I can confirm that this is true. I think the FAA (somewhere?) advises to multipy your landing distance by 1.6 for wet grass. Based on my experience, this is too low. Depending on how wet and water depth, it might be closer to 2 X normal landing distance! Edited February 20, 2016 by Mooneymite Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted February 20, 2016 Report Share Posted February 20, 2016 A beautiful well groomed grass runway is no problem. I have damaged my lower gear doers taxiing at Oshkosh and landing at a grass strip in Minnisota somewhere. It was like clumps of grass. You all can do what you want, but I'm tired of straightening them out. If I'm planning to land at a grass strip I'm not familiar with, I'm taking them off. 1 Quote Link to comment Share on other sites More sharing options...
Supercop0184 Posted February 20, 2016 Author Report Share Posted February 20, 2016 I guess my concern is more about a prop strike been the gear doors. Especially since the older models don't have a lower gear doors. I wonder what the differences in prop clearance are between a Mooney and a Cherokee Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted February 20, 2016 Report Share Posted February 20, 2016 I've never had a prop strike landing on grass. I have got grass stains on my prop at Oshkosh. If you are on dirt, you can expect to lose a little paint on your prop. If you have one of those beautiful custom painted props, I would stay on pavement. Out here in the west, you find a lot more dirt strips then grass. Quote Link to comment Share on other sites More sharing options...
goterminal120 Posted February 20, 2016 Report Share Posted February 20, 2016 30 minutes ago, Supercop0184 said: I guess my concern is more about a prop strike been the gear doors. Especially since the older models don't have a lower gear doors. I wonder what the differences in prop clearance are between a Mooney and a Cherokee Sent from my iPhone using Tapatalk Its the same or more than a 172 1 Quote Link to comment Share on other sites More sharing options...
Supercop0184 Posted February 20, 2016 Author Report Share Posted February 20, 2016 No kidding?!?!? looks so much closer to the ground. Well then no worries! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
bradp Posted February 20, 2016 Report Share Posted February 20, 2016 Also be sure to review your insurance policy exclusions. Mine excludes unpaved or unimproved (language along that line, approximately, the key being the use of "or" instead of "and"). I don't mind right now, but this would be something that would need to be addressed if my flying habits change. 1 Quote Link to comment Share on other sites More sharing options...
Piloto Posted February 20, 2016 Report Share Posted February 20, 2016 One significant factor on grass taxing is weight. Keep the weight light to avoid getting stuck with a nose wheel dig in. Also keep the tires well inflated. José Quote Link to comment Share on other sites More sharing options...
Oscar Avalle Posted February 20, 2016 Report Share Posted February 20, 2016 Don't underestimate our mooneys. You have to be careful (watch out for insurance limitations and fly with an instructor familiar with the area)., but they do just fine. I flew out of a grass strip on several occasions and they are ok. Landings feel even "softer"...:+). I made a video that you may even enjoy about landing my mooney on grass. Oscar 1 Quote Link to comment Share on other sites More sharing options...
Hank Posted February 20, 2016 Report Share Posted February 20, 2016 I've never seen a real insurance limitation against grass strips, but I've heard about an awful lot of them. i don't have such a thing now, I didn't in the past, and my primary CFI made sure I landed their plane at a grass strip before my PPL checkride. Quote Link to comment Share on other sites More sharing options...
carl Posted February 21, 2016 Report Share Posted February 21, 2016 Piper painter lands everywhere in a m20c 2 Quote Link to comment Share on other sites More sharing options...
Supercop0184 Posted February 21, 2016 Author Report Share Posted February 21, 2016 My current insurance covers any field as long as it's published on a sectional. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted February 21, 2016 Report Share Posted February 21, 2016 I was based on a grass strip for years. (M20E) Taxi slowly with trim full nose up while holding the yoke back in your belly. Our Cs, Es are short coupled and a small dip can cause a nose dip. 1 Quote Link to comment Share on other sites More sharing options...
madjano Posted February 21, 2016 Report Share Posted February 21, 2016 FWIW I bought my E from a guy who had his own 2500' grass runway, with a 1500' crosswind on top of a hill NW of Omaha. He had new discs put on it and used it as his cruiser back and forth to AZ. As long as the rain didn't saturate it too much , he could get out no problem. No, tanks aren't leaking, knock on wood. Quote Link to comment Share on other sites More sharing options...
Supercop0184 Posted February 21, 2016 Author Report Share Posted February 21, 2016 thanks for all the responses. I always thought the prop clearance was was less than a Cherokee or 172. Very interesting points made for sure Quote Link to comment Share on other sites More sharing options...
carusoam Posted February 21, 2016 Report Share Posted February 21, 2016 Pot holes are bad... PiperPainter has demonstrated unimproved or little improved runways with his C. More than once... Even a full up O taxis around the North 40 or GAC at SNF. No professional skills required. Good practice greatly enhances your landings. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
steingar Posted February 21, 2016 Report Share Posted February 21, 2016 One of the posters here is designing a new cowl for our vintage Mooneys. He has claimed that a Mooney has 1inch less prop clearance than a Skylane, an airplane thought to be at home on turf strips. Quote Link to comment Share on other sites More sharing options...
Supercop0184 Posted February 21, 2016 Author Report Share Posted February 21, 2016 Well 1 inch is not that big of a difference in my opinion. I think I have less clearance than a Cessna on my current Cherokee. At Oshkosh I always grimace when I leave the runway and get on the grass. I think the only thing that would keep that grimace away is if I were in a tail dragger. lol Quote Link to comment Share on other sites More sharing options...
piperpainter Posted February 21, 2016 Report Share Posted February 21, 2016 (edited) I've measure my prop clearance and that of a 182 and it was about a 1/2 inch difference. Now if you have old donuts and old engine mounts you might have less. But you also shouldn't have those old and saggy! The M20C does great on non-paved surfaces. Also for insurance, you can probably save money if you choose no grass etc. But that's just boring. I pay less than $1000 a year and I have no exclusions listed that would impede me flying to whatever location I want. Edited February 21, 2016 by piperpainter 1 Quote Link to comment Share on other sites More sharing options...
